Old 07-19-2013, 01:32 PM   #11 (permalink)
justme1969's Avatar
Oh forgot another one for all ya pizza pan modders. first go of it back in 1995? I tried pizza pans on my Metro xfI It was simple job because the car had aluminum wheels and lip was close enough to drill n tap 3 holes and done.
Did that and drilled each hub to match the stem and pulled them through.
The holes wer too large to hold stem still and too small to prevent movement.
But just rite to act like mini saws cutting through the valve stems slowly unnoticed untill one failed. Non issue I thought if was a road hazzard and loaded on spare.
At tire shop 2 days later I got to pay for 4 dismount replug and remounts.
A simple and stupid thing but it could have killed me too.
The Following User Says Thank You to justme1969 For This Useful Post:
101Volts (08-13-2013)
Old 07-30-2013, 08:08 PM   #12 (permalink)
101Volts's Avatar
Woody - '90 Mercury Grand Marquis Wagon LS
Last 3: 19.57 mpg (US)
Brick - '99 Chevrolet K2500 Suburban LS
Last 3: 12.94 mpg (US)
M. C. - '01 Chevrolet Impala Base
90 day: 18.73 mpg (US)
R. J. - '05 Ford Explorer 4wd
90 day: 16.66 mpg (US)
On subject of poorer-grade gasoline:
Before I get into this far, I will mention that there's a local gas station which sells pure gas but on the few occasions we got it, It ran worse for a lawnmower and even the van and their ethanol-grade gas was cleaner.
Anyway, I don't know for sure which grade of gas the gas station attendant pumped into the van the last time (I did say "Regular" and not "Pure Gas" but he seemed to be in a rush) but as of late the ScanGauge has been reading that we've been getting 16 MPG or so in it even with the way I drive, We should be getting over 20 at least. The ScanGauge II hasn't been calibrated for a long time, So I have no idea if it's quite accurate but the gas we got from that one station did go through the car faster according to the fuel gauge.
Also, My Mother used to get gas at that same small station and was getting about 17.5 in her Dodge Caravan which is a 3.3 litre, *According to her on-board FE meter which may or may not be quite correct*. I recently pumped gas into it from Sheetz instead and so far, The on-board average meter (Since a stop near the gas station to calibrate the odometer and F/E meter) says the van got over 18 so far.
So, Keep fuel quality in mind.
EDIT - The section between the asterisks was added at this time.
Last edited by 101Volts; 08-06-2013 at 04:43 PM.. Reason: Added some info about how I got the FE reading.
Old 07-31-2013, 11:29 PM   #13 (permalink)
The 'Vic - '96 Honda Civic DX
90 day: 39.3 mpg (US)
Coroplast isn't really tht stiff and will sag if it isn't supported enough on the underbody. Mine started scraping after about 80 miles on the highway and I ended up removing everything after just a few hundred miles. Version 2 is much smaller than the first attempt, only for the rear bumper and much more rigidly attached. I haven't had any problems after several thousand miles.
Civic Build Thread
Your grammar is appreciated.
3.788 Civic CX final drive, air dam, 1st gen HCH 14" wheels and Michelin Defender 175/65R14 LRR tires
The Following User Says Thank You to hawk2100n For This Useful Post:
Old 07-31-2013, 11:54 PM   #14 (permalink)
101Volts's Avatar
Removing the Pizza Pans was quite a drag and caused me to hold down the accelerator pedal more. Putting them back on helped, Though I don't think the van is getting quite the same FE as it was just yet.
Old 08-13-2013, 09:52 PM   #15 (permalink)
101Volts's Avatar
Yesterday another pizza pan fell off. The two which remain are attached in a way as to not modify the hubcap, So perhaps I should modify the hubcap to attach them or put something else on the hubcaps that won't fall off so easily.
Also, This is a lesson for me: Driving at night. Another thing which happened yesterday is I took a long time to get out of whole foods; I took nearly an hour to eat my small meal starting at about 5:09 PM EST (I chewed my food a lot and sampled olives!) and then I had a long detour on the way home (Which is where the pan fell off,) And then before long I was driving at night. I went below the speed limit in a lot of places and on a road near home I was going at about 25.
By the time I woke up at about 10 AM this Tuesday morning, My arms were tired and my eyes were tired and my legs were tired. I'm not saying negative things about driving at night, Just that it was much more difficult to do than driving in the day and perhaps others are more used to it, But I'm not and it tired me.
Old 08-13-2013, 10:22 PM   #16 (permalink)
The smooth wheel covers that have failed on my car are all because the stupid springs that hold them on are crappy. I think I've lost five or six, and my wife lost one? The stainless steel moonies have decidedly rust-prone steel springs, and those failures cost me over $125.
I tried smoothing over the trough along the windshield at the 'A' pillar and it did absolutely nothing.
My rear belly pan sagged and "kited" and fell off and dragged on the road, and I pulled it the rest of the way off.
The rear wheel strakes have been beat up a fair bit, and right rear one got knocked off on a deep dip at an intersection with four people in the car. I retrieved it and repaired and reattached it, and it has been fine.
The first set of LCD monitors I used failed in hot sunlight. And I've had at least 3 video cameras fail, one because the wiring chaffed on the steering column and shorted out - which blew a fuse and the car would not restart, and I had to have it towed. That was embarrassing and a pain...
But, I've saved probably well over $1,500 on gas, so it has been well worth it.
101Volts (08-14-2013), Xist (01-08-2015)
Old 08-13-2013, 10:27 PM   #17 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
Knock knock
who's there.
WAI with too much grill block. Thought I was going to be lose the engine.
The Following 2 Users Say Thank You to ksa8907 For This Useful Post:
101Volts (08-13-2013), Xist (01-08-2015)
Old 08-13-2013, 10:58 PM   #18 (permalink)
Sport Compact Driver
Celica Gts - '84 Toyota Celica Gts
Sports Cars
90 day: 26.32 mpg (US)
The Bee - '96 Mazda B4000 4x4 Base
Pickups
90 day: 20.39 mpg (US)
How avout driving without a thermostat for the last 1000+ miles? Is there a emoticon for beating your head on the wall?
Old 08-14-2013, 12:09 AM   #19 (permalink)
101Volts's Avatar
Originally Posted by justme1969 View Post
So far just changing the front spoiler into an air dam. I had it rite the first time when I tilted out the conveyor material at the bottom.
It worked really well but when I added side skirts I figured air dam and it dropped mpg 1.5its still that was 2 months later because I threw away the bracketts required to angle it forward at the bottom. Air dams work for some people but my sephia is pretty aero and it is just a big speed brake infront of the bumper now.
Could you explain this more? I'm curious.
Old 08-14-2013, 12:34 AM   #20 (permalink)
I see a few people are having problems with aero hub caps.
My aero hub caps have worked great for more than a year now, several cross country trips later.
http://ecomodder.com/forum/showthrea...eel-22003.html
