Old 06-07-2020, 01:33 AM   #161 (permalink)
Ecomodding Apprentice
Hi thanks for the reply, the tensile strenth is 5 times higher, however the issue would be strain strenth, also like you say compressive strenth is compromised. 50% would ensure 0 flex. I will keep them steel, I've figured a way to make the exhaust mainly from titanium without welding. This saves way more weight and lots of time without any calculations or risk.
also as mentioned by others reducing the radiator size and such, there are many larger items easier to fabricate to replace with less structural significance
Old 06-16-2020, 03:03 PM   #162 (permalink)
I was going to replace the busbars with copper but hey, they were so cleaned and annealed them
ID:	28454   Click image for larger version
Old 06-16-2020, 03:05 PM   #163 (permalink)
T & S
Old 06-16-2020, 03:07 PM   #164 (permalink)
Its more done than the pictures, I may make clear sections that blend with the headlights and leave no turbulence at all
ID:	28457   Click image for larger version
Old 06-16-2020, 03:10 PM   #165 (permalink)
ID:	28459   Click image for larger version
ID:	28460   Click image for larger version
Old 06-16-2020, 03:16 PM   #166 (permalink)
This weeks surprise was not how light titanium was but how heavy the sawn off bolt ends weighed, 9g a piece
ID:	28463   Click image for larger version
ID:	28464   Click image for larger version
ID:	28465   Click image for larger version
ID:	28466   Click image for larger version
Old 06-16-2020, 03:23 PM   #167 (permalink)
By making the replacement parts I'm largely avoiding the front bumper bonnet assembly which will be the far most taxing and emotionally disturbing of all the proceedures
Old 06-22-2020, 02:09 AM   #168 (permalink)
I figured if I buy spoke spoke spoke wheels and swap the spokes for carbon tubes
ID:	28509   Click image for larger version
ID:	28510   Click image for larger version
ID:	28511   Click image for larger version
ID:	28512   Click image for larger version
Old 06-22-2020, 02:12 AM   #169 (permalink)
Also the kevlar has to be painted out of the sun or it turns to bran flakes
only was going to have yellow on black I weave on the roof with wood veneer
mould nearly done on the nearside but will use an easier process on the other side
n.b, once day temps are below 15c I may mould my 5.5j wheels for a carbon kevlar mix. May be quite easy I think. 65% mass ratio, after all it's mindless light
also buying more carbon for the roof, hatch structure, the roll bars will only be kevlar. A seperate work equipment rack, toilet roll tubes covered in 3k
ID:	28521   Click image for larger version
Old 06-28-2020, 04:17 PM   #170 (permalink)
It will only require one mould. I will use one of the wheels and change the front to maybe a flat or flat wide spoke, make the outer bevel simpler so they can be wet out from inside easier
Battery cover will just need trimming. Next time it will only need 3x200g thickness it's quite strong
Sanding the mould, but waiting for gelcoat on that, also ordered lots of kitchen towel empty cardboard rolls
ID:	28538   Click image for larger version
ID:	28539   Click image for larger version
