Old 10-14-2012, 02:14 PM   #241 (permalink)
HydroJim's Avatar
Aerofocus (retired) - '00 Ford Focus ZX3
90 day: 44.66 mpg (US)
The Red Baron (sold) - '93 Geo Metro
90 day: 44.1 mpg (US)
Sven-no problems with clearance. If I find the time, I was going to make a sort of flap that hangs down at the right angle and then flips back up when it makes contact with the ground and then goes back down to the right angle.
tru-I haven't been driving it too much, but if my memory serves me correctly, my MPG keeps increasing until I get to about 65 mph and I have yet to surpass that speed so I'm not really sure what happens after that.
Aerospace Controls Engineer.
Currently driving a mostly stock 2014 Mitsubishi Mirage DE hatchback.
The Following User Says Thank You to HydroJim For This Useful Post:
aerohead (11-03-2012)
Old 11-01-2012, 04:03 PM   #242 (permalink)
tru
tru - '05 Ford Focus ZX3
90 day: 39.46 mpg (US)
the truck - '02 GMC Sierra Denali
what are your actual mpg's at those speeds?
like my car right now
40mph -55ish mpgs
50mph - 50ish mpgs
60mph - 40 mpgs
70mph - 35mpgs
Old 11-13-2012, 11:14 PM   #243 (permalink)
Grey Goose - '09 Honda Fit Sport
90 day: 39.44 mpg (US)
I have the same transmission issue you describe in my 2002 Focus. I'm pretty sure it was caused by the clutch master cylinder leaking fluid down the clutch, making it slippery. My foot slid off the clutch and slammed it into gear while it was revved too high. I believe my motor mount broke at the same time (since replaced that). I've been driving with the problem for a couple years. I don't think you have to worry about it becoming undriveable.
Some tips.
If you get the right rpm there will be very little grind. (the same way you would if shifting without using the clutch)
If you start in 2nd off the line you'll eliminate the shift to 2nd grind.
According to the focusfanatics forum, there's a better transmission oil than what ford stuck in it stock, and they've even switched recommendations. It supposedly helps eliminate some of the grinding people have had.
Just by driving carefully I've increased my focus's mileage to 36 mpg and after inflating my tires to max sidewall psi I'm looking to possibly get 38 mpg on this tank. It would be interesting to see what it would do with all your mods.
Originally Posted by HydroJim View Post
This is good information. Definitely something I will take into consideration when I'm rebuilding my transmission.
Any guess what kind of MPG improvement I would get, or is it pretty random?
Old 11-14-2012, 09:33 PM   #244 (permalink)
HydroJim's Avatar
I haven't been driving the car much because my clutch is on it's last legs and I leave for Tennessee on Wednesday. I definitely want to be able to make it there so I can replace my transmission and clutch
I've been averaging 35 mpg in all city driving according to my ultragauge which isn't too shabby considering all the cold starts. I've only burned about half a tank in the past 2 months!
The trip from cleveland to clarksville is 9 hours according to google but at my speed it'll be more like 10 or 11 plus time for stopping.
But what I'm getting to is what is the most efficient way to drive? I don't want to be going in and out of 5th gear for 10 hours. especially with my clutch the way it is.
So do you think it's better to drive at a constant 60 mph or should I pulse from 65 to 55 in gear the whole time?
Old 11-14-2012, 09:45 PM   #245 (permalink)
GRU
GRU's Avatar
silver bullet - '00 Honda Civic
90 day: 34.41 mpg (US)
if your clutch is on it's last leg then put it in 5th and cruise...the more you shift the more friction/heat you make and that will make it slip...just drive smooth in top gear as much as possible
Old 11-14-2012, 10:28 PM   #246 (permalink)
HydroJim's Avatar
That's what I figured. Not really sure why I asked, but it's good to get second opinions
Old 11-15-2012, 07:47 AM   #247 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
Put it in 5th and hold it there. Pick the best speed for the mpg you want.
Old 11-16-2012, 06:59 AM   #248 (permalink)
EcoModding Alien Observer
suspectnumber961's Avatar
highcountryexplorer - '86 Nissan 720 KC 4x4 ST with fiberglass cap
90 day: 21.78 mpg (US)
Elroy - '03 Ford Focus ZX3 w/Zetec DOHC engine
90 day: 32.89 mpg (US)
Sounds like you have oil on the clutch.
Best bet? The faster you go the more likely the clutch will start to slip. The higher the gear you are in the more likely it will slip. Basically...the more load on the clutch the more likely it will slip.
So...if it starts to slip...reduce speed and drop to a lower gear. Depending on how bad it is...biggest problem will be going up hills in 5th? You might have to drop into 4th for these....
You can always drop down into 1st and 2nd (almost no load) ....you'll get there eventually.....
Carry on humans...we are extremely proud of you. ..................
Forty-six percent of Americans believe in the creationist view that God created humans in their present form at one time within the last 10,000 years. GALLUP POLL
Old 11-16-2012, 07:15 AM   #249 (permalink)
HydroJim's Avatar
no oil on the clutch. the clutch just has 85,000 miles on it from the previous owner which i assume weren't the best considering the transmission synchro problems. Plus me learning how to drive a stick shift in it and 500 miles of riding the clutch and getting the feel for it. Not the best combination for clutch life.
Old 11-16-2012, 08:46 AM   #250 (permalink)
If you have a "smooth slip" as with oil...you probably have a weak pressure plate? Same driving parameters as with oil on the clutch....except spinning it might overheat it pretty fast. Might check your clutch adjustment to be sure it is releasing all the way?
