Old 12-16-2008, 05:57 PM   #11 (permalink)
AMSOIL is the premier manufacturer of synthetic oils, gear lubes, filters, diesel products, gasoline additives, etc. Their catalog is free: AMSOIL - Synthetic Oil, Motor and Engine Oil, Lubricants, Air Filters, Oil Filters and Greases. The oil that I run only needs to be changed every 25,000 miles or 1 year, whichever comes first. Their air filter is high efficiency (better air flow) and can be cleaned over and over. AMSOIL has been proven at the race track and on the street for several decades. It is better for your vehicle (including motorcycles) and you will save money to boot.
Old 12-16-2008, 06:08 PM   #12 (permalink)
P.S. AMSOIL is NOT expensive. You can buy a one year discount card for $20. It is cheaper to use AMSOIL than to get your oil changed every 5,000 miles at the local Firestone. Get a catalog and check it out yourself.
Old 12-16-2008, 06:50 PM   #13 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Originally Posted by Christ View Post
Royal Purple is also very expensive, and very effective... that's gotta say something for efficiency too.
Feel like putting together a critical summary of Royal Purple's efficiency claims? Most of it is "on road" comparisons which we can discount straight off the bat. I had a quick look at one of the two university studies that compared RP to dino oil, and they weren't even comparing the same viscosity in the dyno tests.
Old 12-16-2008, 07:52 PM   #14 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Honestly, that post may have come out wrong - I've only used it once, personally, and I never specifically tested it, although I did notice a MPG (not specifically miles per gallon, but more like gallons per trip) improvement in my old Jeep with it, and it SEEMED to have more power/torque as well. (1979 J20 4x4, 360CI V8, 3 speed manual)
I used the engine oil, trans oil, and rear diff oil all at the same time, like they suggest.
I'm sure part of those claims are eaten by the idea that changing all those fluids would give you a gain anyway, but it seemed to work for me. Also, none of those fluids have been changed since then, and the engine oil is still purple-ish, almost 3 years later. (It's a mountain use truck, never sees the road, but it gets BEAT ON... in fact, it's the only 8 cylinder I've redlined religiously, and it never sees 3rd, seldom sees 2nd gear, with 200k and no problems thus far.)
I'm sure their claims are probably somewhat bogus, but I can't dispute that it's a good product. You'd have to test it personally to see what I see.
3 years and oil is still good, that says something to me.
Efficient alternator modification? Blue Bomber Man EcoModding Central 1 09-18-2008 07:06 AM
Your best modification gasti_ako EcoModding Central 30 09-17-2008 03:10 PM
Metro hood modification? an0nymous DIY / How-to 1 07-21-2008 02:59 PM
Proposed gas log modification TomO Forum News & Feedback 0 02-05-2008 02:56 PM
