Old 06-25-2008, 02:25 PM   #11 (permalink)
EP3
EP3's Avatar
02WhiteEp3 - '02 Honda Civic Si
90 day: 28.35 mpg (US)
Send a message via AIM to EP3
I should have not used that word "Pop". Yeah I have pushed started before and I know the crazy surge you are talking about. I will try to do it a little smoother today. Yeah it must have been the cat then that I heard of. But hey I just got a brand new cat a month ago..under warranty. Yea I like the ideal of the engine not burning any gas but are the gains with engine off say on a mile strip marginaly better. Say my RPMs in idile turn 900 vs 0. I just think this could cause some serious crashes. But hey what do I know. I know we don't reccommed doing this, just curious how it should be done properly and some input.
Thanks all
"There is no such thing as a dumb question.. Just dumb people".
Old 06-25-2008, 02:32 PM   #12 (permalink)
Why do you think this would cause crashes?
Old 06-25-2008, 07:01 PM   #13 (permalink)
EP3
EP3's Avatar
I am speaking about if done wrong thats all. If someone was to lock there column and panic. If someone put it in the wrong gear. If someone had to stop real fast and did not have full assist of brakes. This one is reaching...If you have early airbags they may not fire off if the solinods lost they energy stored up =) reaching I know. I have faith in all of our driving skills, and when it would be approaite if used cautiously it would proably be fine. And ofcourse this is mainly an agruement if someone did it wrong acidentaly. If you just pulsed and glided in neutral you wound have all the benefits of the safety. But I guess not as good if it were cut off completely.
Old 06-25-2008, 07:04 PM   #14 (permalink)
I totally agree. If you don't know how to P&G you shouldn't be doing it in traffic. Same goes for driving in general. If you don't know how to drive, you shouldn't be driving in traffic. Hypermiling techniques are no different from learning how to drive. Both can be dangerous if the driver doesn't know how to properly do them.
Old 06-26-2008, 12:09 AM   #15 (permalink)
Modified Driver
Twerp's Avatar
Location: South Western middle of nowhereish New Hampshire
Frozen Tundra - '03 Toyota Tundra 4WD SR5 Access Cab
90 day: 26.51 mpg (US)
Red Skateboard - '91 Honda Civic DX
90 day: 45.49 mpg (US)
My safety concern would be steering lockup. On my truck, it's not an issue because the "Acc" position is right below "Run." On my fiance's Ford, the "Acc" position is below the "Lock" or "ACK!" position. So if she was to kill her engine in a turn, the wheel could lock. Should be simple enough to turn the key back and unlock it, but that little "WTF!" moment as the car seems locked into a collision course with a huge boulder might prevent an otherwise rational brain from figuring that out.
Brakes though, not a problem on most vehicles I've driven. There is usually enough power left in the brakes to effectively stop the vehicle at least twice. After two presses on the pedal, it starts requiring more muscle, but the right amount of adrenaline usually does the trick... Or just turn the vehicle back on after the second brake press.
That's my two cents.
Old 06-26-2008, 12:17 AM   #16 (permalink)
EP3
EP3's Avatar
Yeah just that WTF second is what I am talking about...True the brakes will still work but if you push like heck it can stop. I just relized how spoiled we are now in these day with all the assist things. My first car was a 76 Datsun 280z. No A/C, no power steering, no power windows, no power locks. Just a sweet car with a inline 6 and a 4 speed man.
Old 06-26-2008, 02:36 AM   #17 (permalink)
Modified Driver
Twerp's Avatar
Sounds like my Civic but with more power and less gears... Except I've got tilt steering for some reason. Oh and a broken cassette deck and multi (meaning more than one but not more than two) speaker stereo system.
Old 06-26-2008, 08:43 AM   #18 (permalink)
EP3
EP3's Avatar
Oh yeah The Datsun had AM FM sterio with two box speakers. No Tape Deck??? Do you 16 year olds even know what a Tape deck is? Back in my day in the 90s..we had to walk 10 miles in the snow...Both ways..
Old 06-26-2008, 10:57 AM   #19 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 Scion xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '10 Honda Insight EX
90 day: 51.5 mpg (US)
Since this thread is about P&G, how about you experienced guys give us a quick tutorial on how its done. By that I mean, please answer the following questions;
-What is the optimal speed variation; 10,15,20 mph?
-What would be the best LOD for increasing speed during a P&G
-What is the Benefit of P&G over long distance?
-Does your FE plateau or will it continue to increase over distance?
And a couple of my observations; P&Ging in my car I notice that I get to the optimal FE in no time flat, but once I am there it plateaus, therefore should I stop at that point? Or am I gaining the benefit of FE while traveling at faster speeds?
Thanks in advance for sharing the knowledge ..
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 06-26-2008, 11:47 AM   #20 (permalink)
I normally use a 10 mph delta when P&Ging. 15 is nice when traffic allows. I rarely do 20 unless its a totally abandoned road and I'm really in no hurry at all.
I normally accelerate around 70-85 LOD.
The benefit of P&G is better mileage over a long distance.
Your FE will plateau. However, if you go back to driving normally it'll go down. P&G is just more efficient.
Pulse and Glide with hills Tango Charlie Hypermiling / EcoDriver's Ed 19 07-08-2013 03:53 PM
Pulse and Glide Fuel Economy Calculator 4 valve / Cylinder newtonsfirstlaw DIY / How-to 25 11-04-2008 03:32 PM
Old School hypermiler PULSE AND GLIDE Dragonova Hypermiling / EcoDriver's Ed 13 07-08-2008 07:26 PM
Pulse and glide with Caravan automatic (actually EOC) popimp Hypermiling / EcoDriver's Ed 20 12-29-2007 01:10 AM
Re-attempting Pulse and Glide (with an automatic) Lazarus Hypermiling / EcoDriver's Ed 6 12-11-2007 08:06 PM
