Old 12-15-2020, 09:08 PM   #571 (permalink)
It reminds me the Fiat Coupé somehow.
Old 12-16-2020, 10:29 AM   #572 (permalink)
Next-gen 911 GT3 secrets revealed! Race car aero and more variants
By Andy Enright, 20 Aug 2020 News
https://www.whichcar.com.au/news/202...crets-revealed
WHY A SWAN NECK?
Ever wondered why aircraft sling the engines under the wing instead of on top? That’s because on a plane, the top side of the wing is the important part, speeding the air, creating low pressure and thus lift. That area needs to be uninterrupted. Think of a racing car wing as an inverted aircraft wing and you begin to wonder why it took so long for items with unencumbered undersides to appear.
Swan neck, check.
Squiggle in rear diffuser - odd.
Old 12-16-2020, 10:41 AM   #573 (permalink)
3/2/2020
Shaping Up
https://www.samgadkar.com/blog/shaping-up
The Porsche Exclusive Manufaktur shapes up the 911 with two aerodynamic and styling packages.
The new Aerokit has been engineered at Porsche’s development centre in Weissach where experts spent months optimizing the design and function. Prototypes were carefully honed in Porsche’s wind tunnel to ensure that the Aerokit fully delivers on its striking visual promise of reducing the uplift forces over both front and rear axle.
Old 12-16-2020, 07:14 PM   #574 (permalink)
The rear engine layout seems to make things more challenging to some extent, but how could anyone not love the Porsche 911?
Old 12-17-2020, 10:50 AM   #575 (permalink)
I think some of the magic is that under full brake load there is a near 50/50 weigh balance.
2010
Stop and weight! A 50/50 weight distribution is not optimal
Having this weight in the back naturally uses all of the tires more efficiently during braking, instead of overloading the front tires which is what tends to happen in a front biased car.................
With more weight over the rear axle, its obvious that there is going to be more traction. Thus, the car can put down more power without spinning the tires..................
Fun cars that reward precision execution.
Some people like the challenge, and the engagement.
freebeard (12-17-2020)
Old 12-17-2020, 01:50 PM   #576 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
I was a rear-engine booster all my life until Mercedes had their blowover crashes at Le Mans. Then, I realized that any fast, light, streamlined vehicle should have a stable glide. Even if it won't get airborne, it could hit a patch of wet ice with a strong crosswind. It should only slide, not yaw.
The 911 is a triumph of engineering to adapt a VW bug for sport. I'd say that it looks distinctive handsome, but not beautiful.
Old 12-17-2020, 03:30 PM   #577 (permalink)
I was a rear-engine booster all my life until ...
...I found out you can set up a Beetle for terminal oversteer, just like a Porsche.
Photochopped, obvs...
justacarguy.blogspot.com/2020/12/sure-why-not.html
The ambler 500 signage is a nice touch.
The older I get, the better I was -- John Fogerty on Joe Rogan
Old 12-17-2020, 08:16 PM   #578 (permalink)
Considering how the good old VW Beetle outperforms some modern SUVs while off-roading, I still appreciate the rear-engine layout. On a sidenote, due to the popularity of the Beetle in my country, I have already seen some front-engined cars rebuilt around Beetle frames, also becoming rear-engined in the process. Sometimes I still consider to do a similar hack into some Japanese econobox from the '90s or a compact SUV.
No doubt it's distinctively handsome, but I actually consider the 911 beautiful.
Old 12-17-2020, 09:40 PM   #579 (permalink)
Bicycle Bob — The case I can think of was aerodynamics gone bad.
If eyes were made for seeing, then beauty is it's own excuse for being— Ralph Waldo Emerson
edit: That Power Wagon could have a Tesla motor in the rear driving all four wheels. ....and pass-though front seats.
Old 12-18-2020, 07:15 AM   #580 (permalink)
eagle's Avatar
rozy - '09 Ford Fiesta Zetec S
I added a hose starting from the fog lamp in the front bumper and ending inside the bumper in front of the oil cooler
with the magnehelic instrument connected and the high tube placed in front of the fog light and the low tube at the end of the tube the instrument showed 0 even at a speed of 80 km / h
I just changed the connection method and put the tubes upside down on the instrument and started showing a little bit
so either the air goes from to the oil cooler outside the front bumper opposing incoming air or something is wrong
shorturl.at/fhpq0
