Old 04-27-2013, 07:31 PM   #191 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
Good idea. haha
Decided to put the mirror on anyway.
I also pulled off the door panel again and managed to get the window down. Turns out the crank mechanism's bolts were loose so it was slipping front to back when the handle was turned. I tightened them down and while the window still doesn't line up quite right, at least it opens and shuts.
Pics.
Aero Mirror by Tyler Linner, on Flickr
Also, in an attempt to reduce weight, I removed the rear seats I have never used. Estimated about 10-15lbs. Going to perforate the fiberboard trunk floor with a 1-1/2" forstner bit for hopefully an extra pound. I don't own a scale so it's hard to tell for sure.
Weight Reduction by Tyler Linner, on Flickr
Plasti-dipping the trim back to stock
Plasti-dip by Tyler Linner, on Flickr
The Following User Says Thank You to Sven7 For This Useful Post:
California98Civic (05-05-2013)
Old 04-27-2013, 09:49 PM   #192 (permalink)
Sven7's Avatar
Done
Back in Black by Tyler Linner, on Flickr
Thinking the cargo tray, though perforated, could be replaced with some solid 2" thick styrene insulation sheet. The weight would be a fraction of the fiberboard and probably about as strong.
Tip: always drill a pilot hole when using a forstner bit. I muscled through it but it is uncomfortable and quite honestly unsafe.
Wool blanket came out; it's not winter anymore. About a pound. Took some stuff inside that I don't need while driving around. 3lbs.
I've got a good 5 lbs in the emergency kit in the tire well but that's going to stay. It's got tire goo, jack, tow strap, jumper cables, crescent wrenches, a bright safety vest and more.
Busted out the windshield sun shade too.
Old 04-28-2013, 10:44 AM   #193 (permalink)
EcoMod Proof of Concept
WD40's Avatar
WD-40's Insight - '00 Honda Insight
Gen-1 Insights
90 day: 56.04 mpg (US)
WD-40's Mirage - '15 Mitsubushi Mirage ES
90 day: 46.05 mpg (US)
WD-40's Sonata Hybrid - '17 Hyundai Sonata Hybrid Limited
Love the mirror, whats it made of?
2000 Insight MT 106K Citrus A/C
Old 04-28-2013, 11:16 AM   #194 (permalink)
Sven7's Avatar
Thanks. Just a 20# urethane foam block- a material I worked with in design school.
California98Civic (05-01-2013)
Old 04-28-2013, 04:22 PM   #195 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
Mirror is awesome, regardless broken parts. Great job!
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
The Following User Says Thank You to AndrzejM For This Useful Post:
Sven7 (04-28-2013)
Old 05-01-2013, 08:39 PM   #196 (permalink)
Sven7's Avatar
just playing around
uforb by Tyler Linner, on Flickr
HydroJim (05-01-2013)
Old 05-01-2013, 08:50 PM   #197 (permalink)
The Dirty330 Modder
Gealii's Avatar
CruzeRS - '15 Chevy Cruze LT RS
90 day: 41.29 mpg (US)
i like the wheel covers being black over brown =)
"The only real mistake is the one from which we learn nothing."
- Henry Ford
Old 05-02-2013, 08:06 PM   #198 (permalink)
Sven7's Avatar
Eh, it's a glossy bronze color in real life. I'm kind of fond of it. Apparently, though, if you plastidip a car without waxing the paint first the plastidip will never, ever come off. So, no UFORB... other things for now.
Ordering the upper control arms the alignment guy was wiggin' out about, and springs too. The springs have little level hatches so I should be able to level out the car and finally have it low-ish.
The new muffler is banging on something back there so this weekend will include some work trying to install the rest of the new stuff and reduce contact with the body.
Gotta get an oil filter and change the oil this weekend too.
Old 05-03-2013, 11:11 PM   #199 (permalink)
Sven7's Avatar
new low mpg. 20mpg. not even a single f*ck was given
Old 05-05-2013, 01:17 PM   #200 (permalink)
Sven7's Avatar
Full exhaust system installed and oil/filter changed yesterday. couldn't get the old O2 sensor off. drove to woodward meet without o2 sensor. apparently blew mani gasket because i torqued in the wrong order. a few exhaust hangers need to be hooked up (somehow) and rattles due to imperfect fitment to be dealt with.
mo parts mo problems
