Old 03-02-2009, 07:56 PM   #11 (permalink)
90 day: 51.82 mpg (US)
Originally Posted by jamesqf View Post
was under the impression that they apply various algorithms to estimate fuel consumption from the OBDI-accessible info, while the Honda OEM display computes fuel consumption by adding up the amount of fuel the ECU tells the injectors to deliver.
Yes, that's what the SG does (and why it doesn't do as well with lean-burn equipped engines).
The MPGuino directly monitors an injector signal, so it's more like your car's MPG system. Lean burn doesn't faze it, since it's just counting injector pulses.
Scangauge II vs cruise control rjacob Instrumentation 10 06-02-2011 02:36 PM
Dealer says ScanGauge ruined my PCM and I can't use ScanGauge anymore Markmysite EcoModding Central 55 05-06-2010 06:31 AM
Woohoo, this place is worth more than CleanMPG dcb The Lounge 4 10-16-2008 10:24 AM
Scangauge 1 - Some help please! jdubbs_scort Instrumentation 6 06-17-2008 03:26 PM
scangauge coolant temp accuracy? Daox Instrumentation 12 05-03-2008 01:09 PM
