Old 08-02-2009, 05:12 AM   #31 (permalink)
Chug - '96 Volkswagon Polo CL
90 day: 49.42 mpg (US)
L'Autre - '03 Renault Megane Sport Tourer Expression
Diesel
90 day: 45.02 mpg (US)
I call all the 1.9s PD , may be factually incorrect but there are so many crossover bit I class them as the same
good things come to those who wait, sh*t turns up pretty much instantly
twitter.com/bertchalmers
Old 08-02-2009, 05:25 AM   #32 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Here is my current setup which gives me +70MPG.
The car is Cordoba vario 98 pictures can be found at:
http://cid-acb1f13bac776768.skydrive...se.aspx/seatti
Mods:
- Rear wheel skirts (aero effect)
- Rear muffler delete (-4.4kg)
- Catalysator delete ( -2.5 kg)
- Towing bar delete (-16 kg)
- Spare tyre and jack delete (-10.8 kg)
- Roof rack and rails delete (aero effect) and (-4.1 kg)
- Rear seats delete (-9.5kg)
- 13" rear aluminium wheels (-4 kg
- Rear tyres Toyo 350 165/70/R13
- 14" front aluminium wheels (-2 kg each) rotational mass effect!
- Front tires Toyo 350 175/80/R14 (ca. 10% taller gearing)
- Tire pressures 50 PSI
- Flat hubcaps (aero effect)
- Smaller sidemirrors (aero effect) and (-2 kg)
- Aero fornt bumber
- Flat engine bay cover
- Tinted windows
- Engine oil Valvoline Syn power III 5w-30
- Transmission oils Mobil 1 VS200
- EGR delete
- Lowering springs 60/40 (aero effect)
- Other small weigth saving inside the car.
I think those are most of the mods done so far, still ahead:
- Glasfibre hood
- Better front bumber
- flat undertray
- sideskirts
- more weigth savings etc.
I think mods make half of the high mpg results driving habits the other half. I use at least these all the time:
- Drive without brakes
- Push and glide
- engine braking
- early gear changes (under 2000 rpm)
- lights off on motorways
Thats the current setup .
Old 08-02-2009, 02:13 PM   #33 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
The link seems to be broken. Wrong address?
Old 08-06-2009, 07:37 AM   #34 (permalink)
AJI
Rallye - '98 Peugeot 106 Rallye
90 day: 31.93 mpg (US)
RX-7 - '94 Mazda RX-7
90 day: 20.76 mpg (US)
NC - '09 Mazda MX-5
90 day: 32.68 mpg (US)
Nice to hear the progress of the car. Apart from anything, the weight savings should be nice for some extra performance. As above though, your link to the pictures seems to be broken or incomplete. It'd be interesting to see what you've done to the car visually.
I'm all the more interested in this thread at the moment as I recently test-drove a 1999 SEAT Cordoba 1.9 TDi with 90bhp. It was a really nice car to drive, loads of shove from the engine, fairly quiet once you were moving (noisy as hell when you start it up!) and felt very solid. The EU average fuel consumption for the car is 57mpg, which is 47mpg US and around 5 litres/100km. Very impressive as standard so I'm not surprised you're achieving close to 3l/100km at the moment. Yours is probably a little more aerodynamic than the saloon I drove:
Old 08-06-2009, 12:37 PM   #35 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
Links on page two works and you can see the other pictures by clicking seatti button on the picture page. There arent yet ready picture of the hood but some new pictures. However the new glassfibre hood is now in place and wind noise is lower than before. I will tell how the coast down test results are and also my "test" leg consumption.
On next week I will begin to manufacture the new front bumber of glasfibre, it will be more aerodynamic and also much lighter...
Old 08-06-2009, 12:38 PM   #36 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
seatti - Windows Live
Old 08-29-2009, 04:11 PM   #37 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
Glasfibre hood and flat undertray done. Also have changed new rear wheel bearings.
Picture of the flat undertray:
29082009638.jpg - Windows Live
I put thermo tec tape around the front part of the pipe and also make some venting holes. After todays 500 km of driving I can close some of the venting holes in the back, because the pipe didint get so hot as I imagined.
Next will be new front headlights with DRL,s and the new front bumber.
Also had my best tank so far. So the direction is going towards the 80 MPG mark
Old 08-29-2009, 05:03 PM   #38 (permalink)
X-Frenchy: very
groar's Avatar
scenic - '01 renault scenic
90 day: 43.09 mpg (US)
megane - '97 renault megane classic
Diesel
90 day: 72.53 mpg (US)
dennisius - '06 Toyota Prius
90 day: 69.27 mpg (US)
Congrats for your second kilo-tank and your new mods.
Does your car is feeling differently with your last mods ?
Denis.
Save money & CO2 at home : http://ecorenovator.org/
Created and managed by the creators of http://ecomodder.com/
Earth and health are priceless, so are kilotank and AT-PZEV
Best Mégane tank: 1268.9mi @ 77.847 MPG(US)
2008/06-2011/10 saving:
  • 5725.5 kg CO2 (5342.6+382.9)
  • Diesel / Money: 42.17% = 2446.25€ = 3357.26$
megane : thread - kill switch.
Old 08-30-2009, 04:58 AM   #39 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
The scangauge showed me little better results at higher speeds so I think the undertray works. No noticeable changes in driving behaviour. Maybe little less wind noise from the back at higher speeds. Tomorrow I will do my usual coastdown test and also the regular trip consumption test so I will know more then.
That undertray weigths ca. 15 kilos so its very stiff, but maybe too heavy :/ Next move is to make and connect side skirts to that undertray.
I have also plans for smaller altenator swap because the current is a whopping 120A one.
Old 08-31-2009, 01:45 AM   #40 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
Results of todays tests:
Coastdown test:
120-85 km/h (2km/h) better than the last two tests and second best result overall.
I should get a second clock so I would get more accurate results :/.
My usual test leg:
Second best result, without almost any drafting help.
AVG consumtion 2.4 l/100km AVG speed 78 km/h. 0.15 litres better than the previous two tests.
Best is currently 2.3 l/100km with 78 km/h, but this was behind a big truck.
YOU should also notice that my SG is now calibrated so that it show ca. 0.2 litres too low litres consumtion for tank calculations. Last tank SG showed me 3.0 litres, but the result was 3.25 litres/100km. Those results are still comparable for each other because I havent chanced the SG calibration value.
What do you think is it worth to recalibrate the SG because it starts to show more and more too low (l/100 km) figures compared to actual figures?
The Following User Says Thank You to Vekke For This Useful Post:
Piwoslaw (03-17-2010)
Starting My A/C Seat project dremd General Efficiency Discussion 83 07-26-2015 03:04 PM
EG seat swap Del Sol n2 EG Civic Nden DIY / How-to 6 04-02-2010 02:30 AM
Cheap man's AC! (beaded seat cover) swoody For Sale 1 09-17-2008 04:15 PM
Do Metros have back seat belts & do child seats need to be installed on a seat Wayneburg General Efficiency Discussion 8 05-07-2008 01:11 PM
