Old 06-28-2015, 06:56 PM   #1 (permalink)
Not bad for a machine
dirtydave's Avatar
Maechunbu - Retired - '00 Kia Sephia 1.8I4 16VDOHC
Last 3: 45.28 mpg (US)
Slasher - '96 Chevy Corsica 2.2L 3speedauto
Duct Tape Aero Crew
Team Chevy
90 day: 34.76 mpg (US)
simple muffler question.
Well my muffler fell off (rust) and Midas replaced it last in 2010.
I'm almost positive I have a warranty but if not I was looking for one at a major chain autozone, advanced auto, pep boys, salvo, and napa.
I might need to buy one tomorrow.
How are they any different from each other??
the $45 one and the $90 one look the same.
Old 06-28-2015, 07:00 PM   #2 (permalink)
Valerie - '03 Honda Civic DX
90 day: 55.79 mpg (US)
I don't think that any choice would have a significant effect on mpgs...
maybe sound, but not fuel milage.
I'd go with the cheaper of them.
The Following 3 Users Say Thank You to whatmaycome14 For This Useful Post:
dirtydave (06-28-2015), mcrews (06-29-2015), The donkey CRX (06-28-2015)
Old 06-28-2015, 08:04 PM   #3 (permalink)
dirtydave's Avatar
Duct Tape Aero Crew
Team Chevy
great thanks
Old 06-28-2015, 10:24 PM   #4 (permalink)
dirtydave's Avatar
Duct Tape Aero Crew
Team Chevy
would a $27 glass pack be a bad choice? looks like it would fit nice under a belly pan
http://m.advanceautoparts.com/mt/sho...983%7CL3*15335
Old 06-28-2015, 10:33 PM   #5 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Ah, the Cherry Bomb--that takes me back to high school. It will be a lot louder--a lot louder--but that will work, sure. Those are a 2.5" inlet/outlet, bigger than the stock exhaust on both the cars listed in your garage, so you'll need to weld in an adapter before the muffler.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
Old 06-28-2015, 11:56 PM   #6 (permalink)
Spaced out...
spacemanspif's Avatar
The New Focus - '07 Ford Focus ZX5
90 day: 32.44 mpg (US)
Cheaper one will fall apart faster. I put 2 on my saturn. 1st was a steel replacement that rusted out in a couple years, second was the more expensive stainless steel replacement and held up better but still needed to be replaced if I had kept the car. Either way you look at it I needed to buy 2 mufflers for a car I drove for 110k miles and needed a 3rd. My experience is buy the cheap one and plan to replace it often because the expensive one is not going to last long enough to warrant the extra cost.
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
Old 06-29-2015, 03:09 AM   #7 (permalink)
09 Toyo Yaris HB (Huevos)
That's a little surprising, but I guess it depends on the car. Mine did increase over stock. It was modest, but as the little 4 cylinder breaths a much better. The effects may bigger on a smaller engine. I went with TRD, which in my case was actually Borla exhaust.
Old 06-29-2015, 02:02 PM   #8 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
A glasspack will work fine and wont be too loud if you are sure to install about 18-24 inches of pipe behind the unit. The reason "fart cans" are so loud is that they don't have enough pipe behind them to smooth the raspiness of the larger diameter. Think of a trumpet... it quickly transitions from a small diameter to a large diameter.
Old 06-29-2015, 02:50 PM   #9 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
FWIW, this debate about MPG and muffler choice has come up often and repeatedly. I did a summation post, with the crowd-source editorial assistance of the forum (it as links to the best dscussions): http://ecomodder.com/forum/showthrea...tml#post289125
(Upshot is that most likely mufflers have little or no effect on MPG unless the whole exhaust system is tuned along with the muffler or pipe-diameter changes.)
james
whatmaycome14 (06-29-2015)
Old 06-29-2015, 04:18 PM   #10 (permalink)
dirtydave's Avatar
Duct Tape Aero Crew
Team Chevy
this shouldn't have been posted in here should have been in off topic tech. (sorry)
Midas didn't stand by the warranty so I went and got a $30 thrush turbo and gave my brother $40 to replace a section of pipe put a tip on the end and new hangers.
