Old 04-27-2008, 07:31 PM   #11 (permalink)
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
Smile
spring loaded flapper
Oh, you mean like this one on my F250.
The jury is still out on any MPG improvement.
Old 04-27-2008, 09:48 PM   #12 (permalink)
Weight Reduction
ankit's Avatar
4x4 - '06 Nissan Altima 2.5 Special Edition
90 day: 29.04 mpg (US)
Mom's Van - '99 Plymouth Voyager SE
90 day: 25.62 mpg (US)
Send a message via AIM to ankit
Could you tell us your results with this mod?
Live Simply So Others Can Simply Live
-Ed Begley Jr.
Old 04-27-2008, 10:13 PM   #13 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Originally Posted by hondaworkshop View Post
Howdy neighbors - bastrop/austin here
Keepin' Austin wierd ? I'm doing my part.
Old 04-28-2008, 08:19 AM   #14 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
Exactly, but with a one inch or so hole in it and a spring tuned to let the flapper gradually open from 3000 or so rpm.
My bet with this thing is to affect the flow during valve overlap. If there is more restriction in the exhaust, hopefully more of the gasses with stay in the chamber.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 04-28-2008, 10:13 AM   #15 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
Originally Posted by jpgmtech View Post
On my diesel I can pick up almost 10% highway economy by opening the VVT right up for cruising over and above the factory settings.
How did you achieve this? Pull the vacuum line? I'm interested in testing/ using this myself.
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
Old 04-28-2008, 11:25 AM   #16 (permalink)
duramax - '05 Chevrolet Silverado LT
The D-max has a fully electronic controlled VVT. I did this in software. Does the VW TDI have a VVT turbo? And if so, how is it controlled?
Old 04-28-2008, 12:22 PM   #17 (permalink)
EV OR DIESEL
The MKIV+ TDI (99.5 and newer) do have VVT Turbo's.
They are controlled in software. Basically the ECU tells the N75 (vacuum switching valve) to open/ close and the vacuum actuator moves the vanes.
I don't know of an easy way to do this in software, but I'd like to give it a shot by manually actuating it.
The chip tuners can probably do this, and probably do . . . Most people claim about 5~10% increase in FE, I'll bet that this is one place that they find that extra economy.
2016 Tesla Model X
2022 Sprinter
2012 Nissan LEAF SV
Old 04-28-2008, 01:01 PM   #18 (permalink)
dremd, I would look more deeply into the electric bleed mod performed on the the ALH, it might be akin to this mod. Chances are you can achieve what you want, to some extend, with just a resistance.
Old 04-28-2008, 01:36 PM   #19 (permalink)
Been there, tested that... at least in principle. Less exhaust backpressure is almost always better, with the exception of very specific circumstances, i.e. modifying the sound pressure wave tuning of the exhaust to optimize efficiency at a specific RPM. This is assuming the vehicle has equal-length headers too... and the tuner has an understanding of Helmholtz resonators.
Typically though adding backpressure effectively "throttles" the exhaust. Why not just throttle the intake, like we always do???
BTW, on a variable-vane turbocharged diesel, the vanes act as an exhaust restriction at higher vane angles. On my diesel I can pick up almost 10% highway economy by opening the VVT right up for cruising over and above the factory settings. The factory settings are there to intentionally create some backpressure for the EGR as well as making the turbo spool much quicker.
As for this "fuel economy" device - smoke and mirrors....
So does opening up the VVT result in less boost then or more?
Old 04-28-2008, 02:51 PM   #20 (permalink)
Who's got a dual exhaust on his N/A daily driver and can keep it below 3000 rpm and light/mid loads most of the time?
Could you please plug one of the ends real good and drive for a while like that? Then report back with results on low end torque (seat of the pants) and FE.
Thanks
Driving with FE in mind, hard on emissions system? Chris D. General Efficiency Discussion 5 03-27-2008 12:32 AM
