Old 01-14-2010, 12:55 AM   #31 (permalink)
Tank - '76 Chevy El Camino Classic
90 day: 25.89 mpg (US)
Sabrina - '91 Mercedes Benz 190 E
90 day: 37.07 mpg (US)
Angel - '88 Mercedes-Benz 420SEL
Last 3: 23.01 mpg (US)
Quicksilver - '04 Mercedes-Benz CLK55 AMG Cabrio
I DO NOT believe this if anything less than 1MPG Did anyone actually ever try this or are we still goin from the test of their Supporters?
Tank:
(No actual EPA numbers for car just used F/E numbers when i first got it)
Old 01-14-2010, 01:56 AM   #32 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Domman56 -
Saw one in 2008 :
Originally Posted by cfg83 View Post
Hello -
Saw this last week :
Cellphone camera, so the image is bad, but those are definitely blades.
Two tips means $200 a pop. For a chrome tube. With a screen on the end.
I think the best way to do a test would be to pony-up for the $16 cartridge and make your own housing. I think there's enough info/pictures on the site to make your own "home-blade", so to speak. Look here :
Blade: How To Install
It sucks that they'd make $16 off you, but I think we need to know the "details" of the material.
What is interesting is that in 2008, you could buy it from their website. Now you have to go through an intermediary like an Amazon store or a muffler shop.
CarloSW2
American Solar Energy Society
Old 01-14-2010, 02:41 AM   #33 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Toyota Echo 4D Auto
90 day: 34.45 mpg (US)
New Galaxy - '07 Toyota Prius
90 day: 42.15 mpg (US)
$199?
try "free" with a wrench and your 5 finger discount
ill pass
Past Present Future?
Old 01-14-2010, 05:39 AM   #34 (permalink)
epic stock master
luvit's Avatar
86 Accord LX (carb) - '86 Honda Accord LX
90 day: 35.57 mpg (US)
my thoughts are, and i'm not a mechanic, but my thoughts are, if partially blocking your tailpipe increases fuel efficiency, maybe you have other issues?
i'm thinking simple things like a tune-up, exhaust leak, etc, not a major overhaul of the engine.
single person car thread
Old 01-14-2010, 11:13 AM   #35 (permalink)
EcoModding Alien Observer
suspectnumber961's Avatar
highcountryexplorer - '86 Nissan 720 KC 4x4 ST with fiberglass cap
90 day: 21.78 mpg (US)
Elroy - '03 Ford Focus ZX3 w/Zetec DOHC engine
90 day: 32.89 mpg (US)
The solution? TEST IT....
Cast-Iron Exhaust Cutout - JCWhitney
Install this...totally block one side...use the control to vary exhaust blockage and test mpg effects at cruise speed using a scangauge or mpg meter.
Not sure if the ECU would need to adjust mixture based on restriction.
Carry on humans...we are extremely proud of you. ..................
Forty-six percent of Americans believe in the creationist view that God created humans in their present form at one time within the last 10,000 years. GALLUP POLL
Old 01-14-2010, 01:11 PM   #36 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
suspectnumber961 -
Een-tay-rest-ink. That's a good idea. I seem to vaguely recall a (concept?) car with dynamic exhaust restriction. But my human brain is too small to store information accurately, so I can't remember the details.
CarloSW2
Old 01-14-2010, 02:31 PM   #37 (permalink)
Calibration Engineer
Subie - '00 Subaru Impreza STi JDM
90 day: 22.49 mpg (US)
Absolutely it improves your fuel economy. By removing $200 in cash from your wallet the vehicle is now lighter and the amount of energy taken to move it is less. Snake oil added to the engine should help too.
-Michael
Old 01-14-2010, 03:26 PM   #38 (permalink)
That VX guy!
TomO's Avatar
The VX - '92 Honda Civic VX
Send a message via AIM to TomO Send a message via Yahoo to TomO
Originally Posted by alohaspirit View Post
$199?
ill pass
Yeah, if anyone is cray enough to spend that amount of money on one part that just bolts to the outside of your car and does nothing, they deserve to have it taken away from them. At least take it to a shop and have aomeone weld it on.
Saw one in 2008 :
"Sucker born every minute" is supported by that 500 driver. that dual tip is fed by a single outlet from the exhaust. He could have trimmed it back to the single pipe and put just one "blade" on and saved $200
Old 01-14-2010, 03:45 PM   #39 (permalink)
Little known fact but unless it's stainless a clamp _can_ be better. Welding an aluminized piece will end up destroying the corrosion resistance where you've welded it. Ever notice where an exhaust tends to fail? Yes at the welds! The clamp deforms the pipe for a mechanical fit. Removing it isn't as easy as you think! I'm sure anyone else experienced in this area can chime in to confirm what I've said.
-Michael
Old 01-14-2010, 05:30 PM   #40 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
Wink
hackish -
-Michael
Hmmmm, I think you have a point there. I pay for *everything* in pennies. Let's see :
$200 => 20,000 pennies
~145 pennies per lb => 20,000 / 145 = 137 lbs!!!!!!!
Jeepers, my wallet needs to go on a diet!
CarloSW2
Driving with FE in mind, hard on emissions system? Chris D. General Efficiency Discussion 5 03-27-2008 12:32 AM
