First off, this thing is pure BS (
rational response, I know...
Secondly, I don't know why anyone would want to pay $150 for a stainless steel tube with a bunch of fiberglass mesh wound up inside. The profit margin that thing must command keeps me disinterested, even if did what it claims.
Exhaust throttling sounds interesting, but can't the same be done through the EGR valve? Causing a restriction in the exhaust line is going to increase pumping losses.
I'm also lost as to how a restriction will increase VE. The only theoretical way would be utilizing Helmhotz resonance, but the catalytic converter already creates significant backpressure and the constriction would have to be sized ("tuned") to every vehicle individually. Generally, scavenging is already done through early opening of the exhaust valve.
If you want your catalytic converter to heat quickly, hack it off and reweld it so the intake tube is positioned obliquely. An angled intake tube will increase the surface area the exhaust gas strikes as it first enters the converter.
- LostCause
