Old 09-11-2009, 01:21 PM   #1 (permalink)
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 18.97 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
Taked to the dealer today....
They said the TCC sol. enables the PWM sol. so I don't know who to believe. They also said to just turn on both at the same time and see what happens.
But what really surprised me is that they said the clutch is even slipping a little when it is locked up.....ON PURPOSE!!!! WHY????? Does anyone here know which one to use and which one to unplug or if i should use both?????
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
Old 09-11-2009, 05:21 PM   #2 (permalink)
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
PWM = pulse width modulated? Does this mean it's a variable voltage solenoid? I always thought solenoids are on/off
If so you would need to know the operating voltage range and if it's within the 12 area then you could probably just give it full voltage so it's fully on thus least slippage. BUT i'm assuming a lot here. You would need to fully understand how all this works.
I imagine it slips a bit under high torque. It is in an oil bath after all. I doubt it slips "all the time"
I think dealerships and politicians are about equal in terms of "reliable source" material.
Have you tried an Olds forum?
By the way: It would be better if you kept all this under one thread so you can find it later, we who are trying to help can find you and others who are following can find the info. Thx.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
Old 09-11-2009, 09:02 PM   #3 (permalink)
Driving the TurboWeasel
Try your luck over on pontiacbonnevilleclub.com. They're a great group of folks. More into power than fuel economy, but they've broken everything on your and my car (both on the H-body chassis) at least 10x and put it back together. Search around there for a bit, then register and ask if you still can't find the answer.
3800 Series II and 4T60E on your car. My bet is you need some Auto-RX, a fluid and filter change, and an adjustable shift modulator or replacing some cracked vacuum lines.
2012 Chevrolet Cruze Eco 6MT
Old 09-12-2009, 12:06 AM   #4 (permalink)
wagonman76's Avatar
Red Car - '89 Chevrolet Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 Pontiac 6000 LE Wagon
90 day: 28.26 mpg (US)
I have a service manual for my 92 Trans Sport van. The 3800/4T60E section may be very similar to yours. Don't have a functional scanner here so I'll do my best in words.
It says if the PWM is stuck open, TCC will not engage. Stuck closed and it will engage harsher. The regular 440T4 (which every other of my vehicles has) has no PWM, sure you can feel the engagement rather than the butter smooth engagement of the 4T60E, but it's not bad.
It also says that certain conditions must be met with the VSS, CTS, TPS, and by comparing engine speed and vehicle speed it is supposed to know what gear it is in.
The PWM should run at the same time as the TCC, but they are separately controlled. Here is what my book says regarding the transaxle connector.
Yellow/Black - Shift Solenoid B to ECM (ECM grounds it to energize solenoid)
Light Green - Shift Solenoid A to ECM (ECM grounds it to energize solenoid)
Tan/Black - TCC Apply Solenoid to ECM (ECM grounds it to energize solenoid)
White - TCC PWM Solenoid to ECM (ECM grounds it to energize solenoid)
Pink/White - 12v+ w/ignition (powers Shift A, Shift B, and PWM solenoids)
Purple - TCC Brake Input (12v+ w/ignition, sends 12V+ w/ignition into this wire to ECM and to TCC solenoid, cuts power when brake pedal is pressed)
A 7th wire is not used and may or may not exist, it is for temperature sensing on the higher powered models (3.4 DOHC, Caddy V8, maybe 3800SC)
Shift Solenoid A - 20 ohms
Shift Solenoid B - 20 ohms
TCC Solenoid - 20 ohms
PWM Solenoid - 10 ohms
1st gear - A energized, B energized
2nd gear - A open, B energized
3rd gear - A open, B open
4th gear - A energized, B open
What I would do is cut the wires to the solenoids. On the trans end use your homemade shift box. On the car end I would wire in the appropriate resistor to make the ECM think it is running the solenoid. Just leave the PWM wire disconnected on the trans end, and it should keep it full power, but connect it through a 10 ohm resistor on the car end to make it think it is still there. Seems intuitively backwards for the PWM, but the book says open (no engage) is 100% duty cycle (I would think means full power) and closed (harsh engage) is 0% duty cycle (I would think means no power).
It still might get discrepancies since it compares vehicle speed and engine speed with what gear it thinks it should be in. Hopefully it does not throw a code, but if it does it will be easy to go back to where you were. Or if the code does not affect mileage or driveability, leave it.
Winter daily driver, parked most days right now
Summer daily driver
The Following User Says Thank You to wagonman76 For This Useful Post:
IsaacCarlson (09-12-2009)
Building an HPV Fairing trebuchet03 Alternative Transportation 73 01-19-2012 02:50 PM
Dealer says ScanGauge ruined my PCM and I can't use ScanGauge anymore Markmysite EcoModding Central 55 05-06-2010 06:31 AM
Interviewed and Drive Test with Newspaper Reporter Today! Matt Herring Success Stories 21 08-03-2009 09:12 PM
mpguino acted up today, lost mpg during fuel cut wagonman76 OpenGauge / MPGuino FE computer 9 06-17-2009 12:25 PM
Put in Mobil-1 and tufoil today regor EcoModding Central 11 08-26-2008 02:09 PM
