Old 08-17-2009, 01:44 AM   #51 (permalink)
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
Gascort,
Bummer on the water issue. Did you seal the crack you got earlier? I would bet that's where you are getting water. It would wick in there pretty quick.
Over this winter, I plan** on doing alot of work to Cara.
5 speed swap, alternator delete, full frontal grille block with 3rd gen T&C bumper cover, wheel skirts, wiper cover, mild weight reduction, few other things.
Did I hear alternator delete? SA-WEEET! More converts to the cult. ohmmmm...ammmmp...ohmmmm...ammmmp (alternaughter chant)
Misery loves company.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
Old 08-17-2009, 02:33 AM   #52 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Originally Posted by orange4boy View Post
Gascort,
Yeah, I plan** on doing it... but it's all getting done over the winter while I'm not driving it, so I won't be testing anything until the following seasons, which makes for an interesting first drive, for sure.
Good thing I can drive it on back roads until I put a plate back on it. First thing to get changed is the 5 speed swap, though. I WANT GEARS!
It's a good thing that gascort here is going to make it to his test phase long before I even think about putting this system together, eh?
Old 08-17-2009, 08:42 AM   #53 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 50.16 mpg (US)
Originally Posted by Christ View Post
How flexible are the solar cells? Will they easily bend into non-complex shapes, or will I need to hammer out my roof?
I don't care, I'll do what I gotta do if I decide to do this, but if the cells will flex and fill in the areas between the rises in the roof line, I'd rather do that.
You've got about three square metres on the roof of your Caravan. And I can't help but think about just how much space there is in the back - "Alternator? No, no...I just rely on these batteries and a remote-mounted fusion generator."
Old 08-17-2009, 02:55 PM   #54 (permalink)
Every one of the earlier mods listed leads up to** (see above post) an engine delete.
A very small TD generator will provide alternate power for longer trips, though they won't really be necessary. The rear floor pan, I intend to cut out and put a flush mount battery box into. There's 48" of usable space between the rear plastics, and excellent ground clearance to sink 8" tall batteries into the floor.
I measured it out once, I can fit 120V at least back there with normal car-sized batteries. (I can't remember what size battery I have, but it's a 1000CA from wally world - I can pretty much fit 10 of them behind the axle.)
Then, with two more boxes, I could fit 10 more on each side of the car near the sliding door sills, for a total of 360VDC, or 3 banks of 120VDC, etc.
I just don't like to postulate on it, because the more I talk about it, the more ideas that I can't afford pop into my head.
Old 08-17-2009, 07:22 PM   #55 (permalink)
chuckm's Avatar
Exploder - '02 Ford Explorer xlt
Rolla - '02 Toyota Corolla ce
90 day: 44.43 mpg (US)
Umm... not to rain on your EV dreams, but 30 lead batteries will weigh an awful lot. Even Optima Yellow Tops would add about 1350 lbs, without the battery box and cables. Ouch!
I think your suspension would need an upgrade.
"Jesus didn't bring 'Natty Lite' to the party. He brought the good stuff."
Old 08-17-2009, 08:28 PM   #56 (permalink)
Well, of course it would.... like leaf springs from an late model Ram, air shocks (which follow another plan I have, but haven't implemented yet).
This is part of the reason I don't really talk about it too much... I don't want to think about it yet, it might contaminate the idea.
Old 08-17-2009, 09:45 PM   #57 (permalink)
How about using the extra string of cells to run a ventilation fan? Could also use it to charge your GPS, MP3 player, various other 5 volt gadgets...
"...and a remote mounted fusion generator."
"How remote?"
"About eight light minutes."
Old 08-17-2009, 10:01 PM   #58 (permalink)
orange4boy's Avatar
90 day: 57 mpg (US)
In other words: Don't let the bean counters in your head get anywhere near your dreams! They don't know beans about fun.
Old 08-17-2009, 10:10 PM   #59 (permalink)
gascort's Avatar
Gascort RIP - '93 Ford Escort Wagon
90 day: 43.01 mpg (US)
WifesCruze - '11 Chevrolet Cruze LT
90 day: 31.1 mpg (US)
Originally Posted by SVOboy View Post
Have you discussed yet where you got the cells and how much you paid?
Ben, I did so only on my blog, sorry. They were from Fred480V on Ebay and cost $2.50 apiece. Now they're cheaper - this was in March '09.
Christ, I forgot about those dumb ridges on top of the van... have you pulled the headliner out yet to see what support structure is underneath?
Orange4boy, it wasn't the cracks, or not solely them. It appears to be capillary action between the silicone and the plexiglass. They're both super smooth and really close together, wicking the water right in. Anyone have an idea? Something that adheres to plexiglass that won't slip off/peel off?
Gasoline, Wind, Solar, Gravity Hybrid-to-be! http://www.scientificmethodfueleconomy.blogspot.com/
Old 08-17-2009, 10:12 PM   #60 (permalink)
We're still off topic...
I plan basics - when it really comes down to getting dirty, if I plan it, the plan goes out the window at step 2 anyway, when the real world comes into play, so I just stopped wasting my time on the "planning stage" of any of my projects.
Almost every idea that I post as a solution to anyone's problem on here, or in real life (like.. not on the internet) is a spur of the moment thing. I think of stuff in my head like that, but I need to be prompted by a problem first. As I encounter problems, I solve them. That way, I know that it works in the real world. Never been too much of an agenda person, honestly.
Once again, gascort has done a great job on this car... *hint hint*.
Commercially produced aerodynamic pickup bed cap MetroMPG Aerodynamics 636 01-09-2022 06:21 PM
Replacing alternator with solar panel array on roof? blackjackel EcoModding Central 91 01-19-2012 09:19 PM
xB Solar panel roof trikkonceptz EcoModding Central 10 02-28-2009 03:27 PM
Solar cell panel on the roof..?. Xringer EcoModding Central 5 09-07-2008 01:51 AM
