Old 05-17-2010, 07:05 PM   #91 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
computers are good at very specific/limited domain/timing critical issues. I can see them playing a role in a more efficient "manual transmission" even, i.e. http://ecomodder.com/forum/showthrea...tml#post148999
where a computer controls shifting to avoid breaking gear teeth, though it would be a simple thing to put a solenoid on the clutch and hit the "I'm feeling lazy" button, but where it is primarily a thing designed for efficiency.
Computers (and frequently their programmers) do not have "judgement", and when they do it will be a short trip to singularity
But I did read an article, where average chess players are beating pros and computer alike by taking advice from, but not submitting total control over to, computers. There seems evident that technology can improve various aspects of performance, but we have to remember that they are all glorified "toasters" and not panaceas.
The point is that technology is neither good or bad, but that it is a toolkit, and knowing when/how to use such a toolkit is the key to improvement/optimization.
Old 05-20-2011, 10:06 PM   #92 (permalink)
FumeSniffer
cookie96civic's Avatar
FumeSniffer - '96 Honda Civic DX
90 day: 46.19 mpg (US)
Big Gulp - '06 International 8600-375 Twin Turbo
90 day: 7.15 mpg (US)
My driving is 95% highway. I'll take the auto with the longer ratio. We all know you can hypermile with the manual, but coasting to 25mph and shutting off and bump starting the car 25 times per trip gets real old in a hurry. I had to add 6 minutes to each leg of my work commute using those techniques. It is fun to see what the car can do....but very impratical.
Old 05-21-2011, 09:52 AM   #93 (permalink)
90 day: 51.82 mpg (US)
Re: extended pulse & glide...
Agreed.
Depending on a person's driving regimen, I'd recommend a taller-geared slushbox if it made sense (ie. vast majority of their driving is highway).
Old 05-21-2011, 10:50 AM   #94 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
A manual with properly planned gear ratios and an intelligent driver is always better, IMHO. Automatics throw too much away with TC slippage during acceleration and climbing hills. A MT driver runs away on downhill coasts and coasting to stops. If someone's drive is 95% highway, both AT and MT are in top gear 95% of the time, so what's the point in paying $1000 more for the AT? Because it saves four tedious manual gearshifts per day?
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
Old 05-23-2011, 09:20 AM   #95 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
Re: pulse and glide on the highway is impractical.
I just finished a cross-country trip in the new Fiesta. It has poor gear ratios (2600 rpm @ 60 mph). The two of us pulsed and glided the whole way from LA to Savannah. We estimated it took about 5000 p&g cycles.
Yeah, that's a bit extreme. It works, though. We ended up with 63.5 mpg with a load of gear and two bodies on board, upsized "sport" tires and sticky rubber.
Give me a manual any day, even with bad gear ratios. I'll P&G the heck out of it. That's what I do every day. (about 25 times each way )
Old 05-23-2011, 03:28 PM   #96 (permalink)
Andrew - wow, epic P&G trip!
I've largely given up P&G for longer trips, though I'll do it on shorter ones (and portions of longer ones).
Partly because I find it tedious, partly because it's got to be harder on the mechanicals. EG: 5000 clutch applications vs. a couple dozen! Even if they're expertly done (I'm sure yours are/were), that clutch, internals & linkages have to have more wear on it.
Goes without saying!
Answer would depend on the fuel consumption difference and the amount of driving. Easy formula. No cookie cutter answer. Anyone seriously weighing the options has gotta do the math.
Old 05-23-2011, 03:54 PM   #97 (permalink)
Hypermiler
Wagons
It was Mike Sefton and I driving.
We did encounter a little grinding at first when reengaging 5th with the engine off. Solution: hold the clutch in for a few seconds first, then it pops in with no trouble. We speculate there are some spinning parts that need to slow down.
Old 05-23-2011, 04:09 PM   #98 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 80.56 mpg (US)
Send a message via MSN to jakobnev
I've noticed this too, and i'd say it's the input shaft that needs to spin up after being stopped by the engine while the clutch pedal was up.
Old 05-23-2011, 04:15 PM   #99 (permalink)
Hypermiler
Wagons
That sounds plausible. Whatever the case, it prevents grinding the gears. That's a good thing.
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
98 Honda civic - automatic - what to expect fuel mileage EcomilerChristopher General Efficiency Discussion 8 12-17-2009 06:58 AM
Honda Insight Concept to Debut at Paris Int. Auto Show SVOboy EcoModder Blog Discussion 32 04-17-2009 10:45 AM
Free Factory Honda Manuals... justpassntime Off-Topic Tech 0 07-16-2008 05:17 AM
Honda Motocycle/auto Service Manuals here FEET_ EcoModding Central 0 05-12-2008 01:13 PM
