Old 02-11-2009, 05:12 AM   #11 (permalink)
The Atomic Ass's Avatar
Overland - '24 Nissan Versa S 5MT
90 day: 38.64 mpg (US)
Originally Posted by Gustavo.Almeida View Post
These were my plugs. The problem? My thermostat was cooling in excess, making the mixture too rich.
I can't tell from the pictures, but are the threads wet? That's my problem, is the threads are wet the entire way up the shaft. My tip certainly wasn't clean, but it wasn't quite as bad as yours looks.
I know I'm running rich right now on startup on the really cold days, and there's no way around that, as the radiator is already 100% blocked. Runs much better if it gets past the "summer" line on the coolant gauge, as I then have in effect a heated intake.
Platinum NGK Spark Plugs vb_bn General Efficiency Discussion 22 05-05-2010 10:03 AM
DIY - Spark Plug Indexing SVOboy DIY / How-to 40 05-21-2009 12:58 PM
New set of Denso Iridium Spark Plugs ... cfg83 Success Stories 11 02-20-2009 04:33 PM
Green spark plugs? WhenGrantAttacks EcoModding Central 3 07-11-2008 05:10 PM
Halo Spark Plugs DifferentPointofView EcoModding Central 1 01-28-2008 11:13 PM
