Old 12-05-2023, 11:09 AM   #81 (permalink)
Here in Reno the bottom dry rots or is insect damaged after about 4 years. I found painting the bottom in roofing cement allows even a dry hole dirt set to survive. 10 years so far on some I did this way even re using the existing concrete. My new favourite is concrete filled 2" galvanized water pipes
Old 12-05-2023, 07:58 PM   #82 (permalink)
Seyz the guy parked almost directly under the equator :P
That would be the case if I still lived in Amazon
