Old 05-29-2013, 06:16 PM   #1 (permalink)
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
Is There a Benefit to Heavy Wheels?
I've been doing some reading on old threads about the benefit of minimizing the weight of the wheels. The two reasons is obviously just reducing the overall weight of the vehicle, but also because the lighter the item that you are trying to spin the easier it will be to spin it, therefore, requiring less energy. (Do I have this right?)
My question, which I can't seem to find, is if there is ever a time that heavier wheels are actually a benefit. For example, in rainy/wet conditions or snow, sand, or gravel, etc.
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
Old 05-29-2013, 06:25 PM   #2 (permalink)
...beats walking...
...inertia is good for flat-land coasting, but you pay a price getting up to speed.
Old 05-29-2013, 07:04 PM   #3 (permalink)
Lots of Questions
Makes sense, your basically using your wheels like a fly wheel.
Best EM Quotes:
Old 05-29-2013, 08:35 PM   #4 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
If you could figure out a way to drive on train tracks then wheel weight wouldn't matter much, but as it is every time you hit a bump or pot hole your wheel has to be lifted up and over that bump, the lighter the wheel the easier it is for it to move with the suspension.
The ONLY time that I can think of that you want heavy wheels is on very very slow heavy equipment when you want very low ballast weight to keep the tires on the ground, in those situations you also want the weight as far out at each corner as possible to keep from tipping over or flipping forward or backwards so the tires get filled with fluid to make them heavy.
Old 05-29-2013, 09:15 PM   #5 (permalink)
Lots of Questions
So what your saying is that any large equipment should have heavy wheels. So the heavy vehicles that have those large beams come out of each side to help hold it down should have heavy wheels. Basically for any passenger vehicle used for normal use, heavy wheels aren't really necessary.
Is this correct?
Best EM Quotes:
Old 05-29-2013, 10:32 PM   #6 (permalink)
In an ideal driving situation without any forced stops of any kind, heavier wheels would help you coast further using P&G (engine off). It would take more energy to get the vehicle up to a given speed, versus lighter wheels, but coasting distances would be longer.
Unfortunately few of us experience those ideal conditions, therefore lighter wheels are better.
regards
Mech
Old 05-29-2013, 10:38 PM   #7 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
the answer is no.
You can try and create all the exceptions you want.....the answer is still no. It's the wheel.
No, you dont 'need' heavy wheels on heavy equipment.
why?
just add a weight, the exact amount you want.
why make the turning of the weight a drain???
why stress the tranny and bearings.
A wheel is designed to roll and move, not weigh down the load.
if you want to stick to the road, put weights in the trunk or the foot wells.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
The Following User Says Thank You to mcrews For This Useful Post:
freebeard (06-04-2013)
Old 05-29-2013, 10:41 PM   #8 (permalink)
mcrews's Avatar
regards
Mech
what about stopping.....odd thing.....we all have to stop.
now you have 4x the weight (dynamic, moving, swinging) and you are using the wrong pads and bushing to stop.(you didnt upgrade for the greater weight) So they wear out much quicker. But you got to coast a little longer.
the answer is no.
ECO MODS PERFORMED:
First: ScangaugeII
Old 05-31-2013, 12:33 PM   #9 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
And the way physics are, you can never get that energy back for the full 100%.
So, it'd pay not to put in this extra energy in the first place, and use lighter wheels.
There is of course a practical limit to this, as very lightweight wheels come with a very heavy price tag ...
Old 05-31-2013, 12:44 PM   #10 (permalink)
euromodder's Avatar
The original 15" wheels were 7 kg.
In 2006-2009 I had been running 10.2 kg 17" wheels.
Since early 2009 I h've been running 7.5 kg wheels - which became the winter wheels after summer 2010.
Since August 2010, I've been running heavy (10.9 kg !) 16" wheels on Hägar in summer.
While the extra weight can be felt in the steering (even despite power steering), there are no signs of drastically increased brake wear - pads and disks have done 192.000 km.
