Old 07-19-2010, 11:23 AM   #21 (permalink)
lol true. Thank you very much for the help.
Old 07-21-2010, 02:31 PM   #22 (permalink)
So, I purchased some time and downloaded a ton of small PDFs last night. I've been reading through them and am blown away with the level of technology they are putting into these engines. Here are a few things:
- low friction coating on piston skirts
- smart charging (low voltage on acceleration, high voltage on deceleration, - uses current and temperature sensors on the battery)
- variable vane turbocharger
- hollow camshafts for reduced weight (and used for oiling)
There is more but I can't remember it all. Overall, very cool.
I was also able to download some of the 2008 specs. This uses a redesigned engine which is much more complex IMO. It uses electronics in a lot of areas where vacuum controlled things before. So, it sounds like the older engine will be easier to work with.
Old 07-21-2010, 04:50 PM   #23 (permalink)
The PRC.
Where can I buy time ?
Thats a reasonably cool engine for a swap. Japanese diesel tech tends to be half a generation behind the latest Euro ones - German and French mainly - but only half a generation and not a full one. Even the Koreans have some pretty cool Diesel engines - 110 bhp from a 1.5 isn't bad even now.
Old 07-21-2010, 05:18 PM   #24 (permalink)
Vtec-e posted it earlier:
Toyota Service Information
Porsche 911 engine swap - ideas? beatr911 EcoModding Central 20 11-17-2013 12:20 PM
1951 Diesel Beetle ~~~ 40MPG Laurentiu The Lounge 3 07-23-2010 05:43 PM
1997 Toyota Tercel Turbo Diesel (Surrey BC) Daox For Sale 15 06-01-2010 09:32 PM
Who / How Can a Toyota Van Gas Engine be Switched w/a Diesel Engine? ecosun EcoModding Central 7 05-21-2010 08:29 AM
Diesel engine braking puzzle Crazyrabbit EcoModding Central 20 03-11-2010 10:43 PM
