Old 09-01-2009, 07:45 PM   #11 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
The transmission in the Electro-Metro is actually not the original, but rather a second one that I picked up at a salvage yard.
One reason why I got a good deal on the car originally was that it couldn't shift - the clutch plate was all messed up.
I also found out later that there was a bad bearing as well. Unfortunately, I had already modified the transmission before I found that out.
That means that I have a spare transmission with a bad bearing that is really only useful for spare parts.
I'll take a look at it and see if maybe providing Darin with parts is actually the highest and best use for the thing anyways.
-Ben
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 09-01-2009, 09:05 PM   #12 (permalink)
EV test pilot
bennelson's Avatar
S10 - '95 Chevy S10
I took the black sheet metal end cap off my original transmission.
Are either of these 5th gear? If so, is it the one I am pointing at, or is it the other one hidden under that slidery-thing?
My YouTube Videos
Old 09-01-2009, 09:07 PM   #13 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
They both constitute 5th gear.
Old 09-01-2009, 09:15 PM   #14 (permalink)
dcb
needs more cowbell
dcb's Avatar
And put the gears for 2nd in the care package too (he probably needs both 5th gears and 2nd gears) Darin might have to put a hump on his 5th cover somehow, no biggie compared to getting the gears modded though. Might as well send the cover too
Old 09-02-2009, 12:08 AM   #15 (permalink)
90 day: 57.73 mpg (US)
That's it - the 5th gear pair.
The slidery thing is what's attached to the shift lever. If I'm not mistaken, the sprocket underneath it also contains the synchro that actually engages the pair of gears (otherwise, its hub just freewheels when another gear, or neutral, is selected).
I'm not sure if the 2nd gear pair is on the shaft via splines, or if they ARE connected to the shaft. I've never been inside a transaxle myself.
Old 09-03-2009, 10:42 PM   #16 (permalink)
Renaissance Man
Formula413's Avatar
Aegean C - '17 Honda Civic LX
90 day: 38.66 mpg (US)
Probably a dumb question, but you do have an XFI cam, right?
Old 09-03-2009, 10:53 PM   #17 (permalink)
The Geo - '93 Geo Metro
90 day: 45.16 mpg (US)
Goodness 1300 RPM's is awfully low.
Old 09-04-2009, 12:29 AM   #18 (permalink)
I do have an XFi cam, so more torque down low. 1300 would probably not work well at all in a non-XFi Metro. I've been making a point while driving around of upshifting at ridiculously low (for a 50hp 3-cyl) RPMs, like 1400-1500.
I can "accelerate" (got an egg timer?) on level ground from 1000 RPM without lugging - even in the upper gears - but as I said it's neither fast nor smooth.
Old 09-04-2009, 12:32 AM   #19 (permalink)
I've been talking to Ben - I think he wants to keep his spare transmission for other projects.
Anyone got an extra one they're willing to part out to me?
I have my original 6k miles transmission I could sacrifice to the cause, but I was keeping it just in case. Maybe I'll start looking for another one.
Old 09-04-2009, 12:45 AM   #20 (permalink)
dcb
needs more cowbell
dcb's Avatar
hmm, maybe upgrade forkenswift a bit so it doesn't need a transmission? Maybe there is simpler transmission for the forkenswift (two speeds via reversing motor? series switchable parallel motors?)
Metro taller transmission swap thread: +5% efficiency gain (taller final drive) MetroMPG EcoModding Central 36 02-11-2015 12:08 PM
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 44 12-09-2014 12:22 AM
Another Metro to get taller final drive & XFi cam Frederick EcoModding Central 19 01-26-2012 01:32 PM
Met an unhappy Aveo owner today MetroMPG General Efficiency Discussion 24 10-10-2010 08:03 AM
Home made hybrid (using access to 5th gear on FWD transaxle) AXMonster Hybrids 17 10-19-2008 06:35 AM
