Old 05-24-2011, 02:33 PM   #81 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
That's the turbo I intended to use for the 4.9L diesel conversion I wanted to work on... But I'll probably never do it.
Old 05-24-2011, 02:36 PM   #82 (permalink)
Diesel Addict/No Cure
cleanspeed1's Avatar
StolenHoopty - '90 Honda Accord EX
HvyDrnkr - '93 Cadillac Seville
You know I'm late to the party for that one, what's up with the 4.9L diesel?
Volvo WIA42 VED-12 / 335 hp / 1300 ft/lbs / 9 mpg
Big n' Boxy, Never met a Hill it Didn't Like
Old 05-24-2011, 02:41 PM   #83 (permalink)
4.9L = 300 c.i.
Ford "big six" conversion I wanted to work on. I have most of what I need, but idi will be very difficult to build, and di requires expensive parts and controls.
I know the engine could handle it, but can't prove it just yet.
Old 05-24-2011, 02:49 PM   #84 (permalink)
I thought you found a 4.9L diesel to put into something from the way it sounded.
Sounds interesting; but heck, give Herbie that turbo!
Get the PM?
Old 05-24-2011, 03:23 PM   #85 (permalink)
NHRABill's Avatar
Tahoe - '95 Chevrolet Tahoe LT
90 day: 13.22 mpg (US)
SRX - '04 Cadillac SRX AWD
XL - '05 Harley Davidson Sportster XL
90 day: 49.97 mpg (US)
Alero - '02 Oldsmobile Alero GLS
Corvette - '75 Chevrolet Corvette Stingray
I didn't get through every post in the thread short on time but for you application I would have looked at a low pressure turbo setup from a Saab they are useless over 3,000 rpm for the most part but very effective in getting the car moving saving on fuel . Low boost under 7 will not need many changes to most cars setup at all. I am not a Diesel guy so it may not apply to you.
Saabs are dirt cheap for parts and plentiful more so than a DSM setup from a eclipse talon to many fast and furious junkyard scrappers looking for those parts and as you found out the parts are beat to heck.
Last turbo car I had was a 85' Buick Grand National hot air non intercooled car that I recently sold the last few parts I had in my garage. they used a garret T3 for the 3.8l v6 and stock pressure was about 12-15 psi under full boost. the manual waste gate required the turning of one nut to adjust the PSI up or down. If you were to go over 20PSI the rule was an upgrade to the fuel pump wiring harness to flow more volts and a in line Walbro fuel pump is what everyone used . Big boys that wanna go fast needed to upgrade injectors and remap the computer I would run 18PSI with a upgraded wiring harness cause factory model was good for stock setting only
I recently sold a garrett T3 turbo for $100 that is what you would get for a core or close to that.
propane injection look at turbo buick and Grand national forums there used to be several easy to install and use kits with basic settings. they would add a 7th injector and pump the propane in conjunction with gas to get more power not sure if there is a method of using the same type of setup of to compensate for the turbo PSI instead of reworking the cars computer to increase the flow of fuel as boost builds.
2012 Chevrolet Traverse *active*
2002 Oldsmobile Alero GLS *active*
2002 S10 2wd p/u 139,000mi. *active*
1975 Corvette Stingray *active*
1994 Camaro Z28 Convertible 149k *Sold 2013*
1998 Blazer ZR2 189k *Sold 2012*
1995 Tahoe LT 250k *Sold 2011*
