Old 02-14-2012, 02:48 PM   #31 (permalink)
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 26.69 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
I need to have all 6 cylinders on tap because this truck works hard. 3 cylinders might have a little trouble pulling 13,000 lbs up a hill. I want to be able to turn off three cylinders when running empty or near empty.
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
Old 02-14-2012, 02:51 PM   #32 (permalink)
Honda Civic - '91 Honda Civic DX
90 day: 40.65 mpg (US)
I see, didn't read that part!
Old 02-14-2012, 03:50 PM   #33 (permalink)
Team Pontiac
OK, here it is. The noise is my bed flopping around.
300-6 on 3 cylinders - YouTube
1991 F-250:
Old 02-14-2012, 04:34 PM   #34 (permalink)
Buggie - '01 Vw Beetle TDI Gls
Put the feed on a toggle switch. On off. Done. Try it and let me know if it works
Old 02-14-2012, 04:39 PM   #35 (permalink)
Team Pontiac
You mean the O2 feed, right?
1991 F-250:
Old 02-14-2012, 07:10 PM   #36 (permalink)
Team Pontiac
I pulled the codes:
172
225
Now I have to work on it again.
1991 F-250:
Old 02-14-2012, 09:46 PM   #37 (permalink)
No. Injector feed. They're strung like an Xmas tree lights. Find one side , cut the wire, connect two wires and run them into the can and hook to a switch. You can do both side so you can alternate
Old 02-14-2012, 09:50 PM   #38 (permalink)
Dont worry about codes. Your sensor will read lean with extra air in the exhaust from cylinders not firing Could eventry disconnecting 02 sensor. Just run in open loop. Does it need much more throttle to get going?
Old 02-14-2012, 09:52 PM   #39 (permalink)
Or wire in a resistor to give a constant reading to the 02 circuit so it will maintain proper fuel ratio. May not need it, check your plugs that work to see if they're black
Old 02-14-2012, 09:59 PM   #40 (permalink)
Team Pontiac
I retrieved those codes after clearing the system and driving with all 6 cylinders firing.
1991 F-250:
1996 Ford F150 4.9L (300ci) I6 5MT 4x4 Christ EcoModding Central 136 09-24-2010 08:47 AM
Think you can hypermile? Ford contest will give the winner a car * MetroMPG Hypermiling / EcoDriver's Ed 6 08-04-2010 08:31 PM
2010 Ford Fusion Hybrid: Built for Ecodriving SVOboy EcoModder Blog Discussion 0 04-15-2009 05:50 PM
Ford Motor Company Johnny Mullet General Efficiency Discussion 5 07-27-2008 06:39 AM
Ford, making money? It must be a mistake... SVOboy General Efficiency Discussion 3 04-28-2008 09:28 PM
