Old 08-04-2010, 05:37 PM   #11 (permalink)
you definitely don't want to pull spark plugs with injectors working,, raw fuel goes out exhaust.
Spark plugs need to spark no mater of cylinder is working or not . you need way to disable injectors and valves .
Old 08-04-2010, 06:02 PM   #12 (permalink)
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 26.69 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
My wiring diagram shows injectors 1,3,5 on one wire and 2,4,6 on another. They all have common positive so I could switch the positive and turn off the ones I want. My question is how does only one injector fire when three are on the same wire?
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
Old 08-04-2010, 06:52 PM   #13 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
it could be that there is one pump for 1,3,5 but the valves (run off the crank shaft) determin which one gets the fuel.
Old 08-04-2010, 07:06 PM   #14 (permalink)
Team Pontiac
It's not a diesel. This is the 4.9 liter. I was thinking maybe there are three small bursts per cylinder and the first two sit on the valve until it opens and then the last one fires? Just thinking out loud....
1991 F-250:
Old 08-04-2010, 07:33 PM   #15 (permalink)
Wiki Mod
time for a google search on how fuel injection works (your car).
Old 08-04-2010, 08:37 PM   #16 (permalink)
If you don't have sequential ECU injector firing (most 90 an older use simple 2 bank firing ). That is the way injectors set up to fire ,there not timed with firing order like spark timing .
Old 08-04-2010, 09:15 PM   #17 (permalink)
comptiger5000's Avatar
RaceJeep - '98 Jeep Grand Cherokee (ZJ) 5.9 Limited
90 day: 13.62 mpg (US)
DO NOT run it with the plugs disconnected and injectors still pushing fuel. You'll wash fuel down the cylinder walls, killing lubrication and wearing the engine, as well as diluting the oil with gas. Plus, all the raw gas going out the exhaust will kit the cat.
Call me crazy, but I actually try for mpg with this Jeep:
Typical driving: Back in Rochester for school, driving is 60 - 70% city
Old 08-04-2010, 09:32 PM   #18 (permalink)
Hyperlurker
daring4's Avatar
D-max - '04 Chevy Silverado Ls
Notch - '65 Volkswagen 1500 S
MTCHBX - '05 Scion XB
90 day: 40.41 mpg (US)
It sounds like all your injectors fire at once, common on older systems. In my car I have two injector fuses, one for each bank of cylinders. I have made a 3 cylinder Fiero but it was terrible to drive! Thats where I wired my injector kill switch for EOC, I never tried to kill just one bank at cruise speed! I could wire it to kill one bank for cruise at speed but It's really hot here now
Old 08-04-2010, 10:21 PM   #19 (permalink)
Team Pontiac
Sorry...I thought it was sequential injection. not sure why. I am going to try shutting down half the injectors tomorrow and see what happens. Maybe it was running different because there was still fuel going out the exhaust. One way or another I will find out if it gives any gains. It would be nice to run on 3 cylinders in town and while cruising empty.
1991 F-250:
Old 08-04-2010, 10:56 PM   #20 (permalink)
Disabling an injector would likely set off the check engine light, although it might be possible to reprogram the controller or replace it with an aftermarket one. But then I don't think there'll be any real economic benefit.
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
1996 Ford F150 4.9L (300ci) I6 5MT 4x4 Christ EcoModding Central 136 09-24-2010 08:47 AM
Think you can hypermile? Ford contest will give the winner a car * MetroMPG Hypermiling / EcoDriver's Ed 6 08-04-2010 08:31 PM
2010 Ford Fusion Hybrid: Built for Ecodriving SVOboy EcoModder Blog Discussion 0 04-15-2009 05:50 PM
Ford Motor Company Johnny Mullet General Efficiency Discussion 5 07-27-2008 06:39 AM
Ford, making money? It must be a mistake... SVOboy General Efficiency Discussion 3 04-28-2008 09:28 PM
