Go Back   EcoModder Forum > Events & Meet-ups
Old 07-02-2010, 07:41 AM   #1 (permalink)
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
UK Meets?
Hi,
I know this site is mainly US/Canada, but I was wondering if there were any UK memebers up for a meet? Would be great for a novice like me to see the adaptations etc first hand...
thanks
Neil
Old 07-02-2010, 09:29 AM   #2 (permalink)
Chug - '96 Volkswagon Polo CL
90 day: 49.42 mpg (US)
L'Autre - '03 Renault Megane Sport Tourer Expression
Diesel
90 day: 45.02 mpg (US)
I'd like to do meets - but My car is standard , except for tyres pressures!!
good things come to those who wait, sh*t turns up pretty much instantly
twitter.com/bertchalmers
Old 07-02-2010, 11:36 AM   #3 (permalink)
Team m8
true, but you have experience of ecodriving-and i'd welcome the chance to glean knowledge!
i could see everyone competing to get the highest mpg for the trip to the meet..
Old 07-03-2010, 04:49 PM   #4 (permalink)
Yamaha - '83 Yamaha MJ50 Towny
90 day: 95.51 mpg (US)
Charlie - '87 Reliant Rialto SE
90 day: 50.72 mpg (US)
Van2 - '99 Peugeot Expert
90 day: 40.65 mpg (US)
I would but I can't afford the petrol until I've got a job.
Old 07-24-2010, 02:58 PM   #5 (permalink)
Heidi - '85 BMW 325e M20B27
Hey 320, are you driving an E91 or E46 or...?
Old 07-24-2010, 03:21 PM   #6 (permalink)
Team m8
none of that modern tat:-)
E30 ftw.
I have two but none are drivable at the moment..
Old 07-24-2010, 04:52 PM   #7 (permalink)
E30 FTW for sure!
Like talking to a mirror, I've got one on jackstands and the other getting lighter at the moment. Mine's penciled in for the Green Grand Prix at Watkins Glen next year or the year after. It's going to be funny when people go from hating the E30 as a track car to hating it as a fuel efficiency rally car.
Have you torn out the Bosch Failtronic yet?
Old 07-25-2010, 05:26 AM   #8 (permalink)
Team m8
E30 FTW for sure!
My320i will be staying as a road car, probably with an lpg kit. I may build a tasty m20b20 for it if time and funds allow.
My 325i is awaiting track prep and a rebuilt m30 3.5 with some mods.
the 320 gives about 35-38mpg uk on a run which is not bad for a totally stock car.reckon i'd go for megasquirt control and some subtle body mods if i was going to eco mod it.
I'm currently on a hunt for a tdi as a daily runner-have a higher startpoint.
What mods you planning for yours?
Old 07-25-2010, 06:16 PM   #9 (permalink)
LPG sounds like quite a project. Were you going to go full LPG or leave yourself the option to run on petrol?
I bet the M30 would haul some ass in that car. Over here the most popular swap is to the S52 but I gather that was only for the US/Canada market.
First I've got some general restoration/repair stuff to do. The previous owner installed the driveshaft with all the bolts facing the same way on the guibo and no collar to keep the two halves together. What a dumbass. So that started vibrating and ripped the center support bearing apart. The front hubs need replacing and I'll do the brakes while I'm at it. Clean the injectors, new vacuum hoses, etc.
After that, I'll put it on H&Rs and Bilsteins for a ~30-40 mm drop. Do a little aero cleanup: wheel spats, side skirts, grill block, clean up the area around the spare tire, and steal the rear wing off a 325es. I know the car's popularly known as 'The Flying Brick' but I don't think the aero's that bad to begin with, otherwise they wouldn't have gotten the mpg they did when stock. Then Megasquirt it with wasted spark ignition and run it as lean as I can get away with. The cooling system is so over-engineered I've never seen mine above the middle tick on the temp gauge.
From what I've read about the rallies, if your car's got too much kit on it they shove you in a 'modified' class and you're not really competing with anyone. So I'll probably do my resto/repairs and drop it for next May and then go from there.
Best of luck to you. They're so rewarding to work on, and great fun to drive, but it becomes an addiction very very quickly. More people must be getting wise to it, too; a clean 325is can now run you $5-5.5K here. The one saving grace is that since so many people have destroyed theirs on the track there's a lot of cheap parts available.
Old 07-30-2010, 07:59 AM   #10 (permalink)
Team m8
THe LPG setup will be in addition to the petrol setup- I spent too much time on single track roads where there is no phone signal, nevermind GPS or LPG stations!
The s52 was the smogproof version of the m52 made for the US e36m3.. its not a patch on the euro s50 3.2 but is a pleasant enough lump.
I'll be keeping mine as an m20b20 though- i like that lump and annoying folk cos I wont change it
The m30 on the other hand should be pushing 240bhp once its built, and the car will be down to 1100kgs- it certainly should go and will ahve coilovers to keep it planted.
On your 325i be VERY careful with the cooling system- the 885 head on the m20b25 likes to crack between cam journals- leading to mixed coolant and oil, and a bill of several hundred.
Your drop sounds good- the front hubs/bearings are best done on the car- need seriouse torque to loosen/tighten them. takes about 7 mins a side inc wheels and brake removal. rears are a barsteward!
I'd be interested to see the aero you have planned- I'll need to investigate options for me
Ecomoder from the UK hougtimo Hypermiling / EcoDriver's Ed 11 05-04-2012 01:07 PM
Hello! Another UK person... colonelk Introductions 6 03-29-2010 06:28 PM
UK version of VW Polo gets lower MPG due to different exhaust routing MetroMPG General Efficiency Discussion 4 11-02-2009 04:32 PM
Why is diesel so expensive in the UK? Eddles Off-Topic Tech 17 10-01-2009 10:50 AM
OpenGauge/MPGuino in the UK eamonn OpenGauge / MPGuino FE computer 0 09-13-2008 02:50 PM
