Old 06-10-2013, 01:23 AM   #51 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
As good as JB Weld is...I don't believe it will be a secure method of securing the bolts to attach yer belly pan to. Keep in mind that these bolts will be subjected to more than just vertical forces as the belly pan will exert more forces than up and down.
I would see what available attachment points are available under yer vehicle now. Even using some bracing or brackets you can attach the belly pan to. I ended up using existing fasteners or holes in my truck frame to attach a framework to. To remove my belly pan only requires the removal of a minimal number of fasteners.
If I didn't post it before...here's my thread.
Under belly pan... - Toyota Nation Forum : Toyota Car and Truck Forums
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following User Says Thank You to BamZipPow For This Useful Post:
California98Civic (06-10-2013)
Old 06-10-2013, 09:04 AM   #52 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Very nice. Thanks for posting it. I like the simplicity and finish, but it must have been heavy. Did you ever take it past the rear axle and spare tire? Every bolt it with security bolts to "discourage the CAT thieves"?
Old 06-10-2013, 05:21 PM   #53 (permalink)
Diabla - '09 Renault Laguna Hatchback
Guys, how about using the template on the underside of the car, does it make any theoretical sense?
I don`t want to lower my car but want better aerodynamics, so I was thinking something like this
I was thinking of bending some coroplast and putting it on this way, its height somewhere around a good inch. Am I a total idiot or does it make any sense?
Old 06-10-2013, 07:55 PM   #54 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
The main belly pan is the heaviest part...I'm guessing about 40lbs? The key to my setup is the 3 sections (engine/front belly pan, main belly pan, rear belly pan) and the crossbeams.
Yes, I've built a rear belly pan (initially called a rear axle pan) and an adjustable rear diffuser section as well as rear skirts. The rear belly pan and rear diffuser build starts on page 6 of my thread. I've even added an extension to my rear diffuser.
I didn't use any security bolts yet as this is still a trial setup. We'll see about that in the future.
California98Civic (06-11-2013)
Old 06-10-2013, 08:03 PM   #55 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
The template would only make sense under the vehicle if the airflow was clean and smooth. The airflow under the vehicle would be disturbed with the ground as well as the tires/engine/low hanging parts.
Old 06-10-2013, 09:15 PM   #56 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
no templet on the bottom
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Honda Fit Belly Pan Project Fit Aerodynamics 17 08-10-2015 08:29 AM
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 41 02-27-2014 09:22 PM
Free belly pan in kansas city! lovemysan Aerodynamics 16 07-02-2010 10:22 PM
Air dam and belly pan wildfire8 Aerodynamics 2 05-01-2010 12:04 AM
Belly pan + Fan concept? meanderingthemaze Aerodynamics 13 02-08-2010 01:09 AM
