Old 10-01-2009, 12:26 AM   #41 (permalink)
2003 Ninja EX250 - '03 Kawasaki Ninja EX250
90 day: 78.57 mpg (US)
Saturn - '99 Saturn SL1 Base
90 day: 47.27 mpg (US)
Meh.....
I like the looks of the EV-1 much better.... such a shame what they did to that masterpiece....
They should have took the EV-1 and made it a little more flashy for all the modern high maintenance Americans out there. Hell, even if it added .1 Cd in flash, I'd be happy with a .20 Cd production car.
For me, function first, how it appears second...
This should be the Chevrolet Volt ....
GM Unveils Concept Car That Gets 80 Miles A Gallon
Doing my part to reduce dependence on OIL
Doing my part to reduce congestion
And enjoying it!
If you have to use your brakes, you are driving too fast!
My 101.5 MPG 2003 Kawasaki Ninja 250
Crude Oil Price Today
The Following User Says Thank You to theycallmeebryan For This Useful Post:
mikeyjd (08-07-2013)
Old 10-02-2009, 11:40 PM   #42 (permalink)
gascort's Avatar
Gascort RIP - '93 Ford Escort Wagon
90 day: 43.01 mpg (US)
WifesCruze - '11 Chevrolet Cruze LT
90 day: 31.1 mpg (US)
Nice in that video how it shows the mirrors in the smoke - Old Bob Lutz told us those were "aerodynamically neutral". Obviously not true. Insignificant? Maybe. I bet at 80 mph those become pretty significant.
Gasoline, Wind, Solar, Gravity Hybrid-to-be! http://www.scientificmethodfueleconomy.blogspot.com/
Old 10-04-2009, 09:56 PM   #43 (permalink)
Mirrors
Looking at how they changed the way the mirrors mount on the volt from the show car to the production car reminded me of some of the discussions about how, removing the mirrors on the Chevy Caprice from 1991 would make the aerodyamics worse. GM had mounted the mirrors in the "pocket" of the front door window (were there used to be vent windows back in the 60's and 70's) for years; and still do on most of their cars today. HOWEVER, on the 91 Caprice they used a little pedestal mount down on the shoulder of the door.
So maybe removing the mirrors on those big rounded Caprice's would actually make the aero worse... or maybe what some people were replacing them with made it worse.
Apparently the Caprice could have used the squared rearend of the earlier models though; that might have improved the land barge aero even more.
Now if I could just get one of those Freightliner Cascadia “Innovation Truck” camera wings for my 72 pickup; I know to try attaching them at the door shoulder instead of trying to replace my vent windows with aero mirrors.
Old 12-27-2012, 06:23 PM   #44 (permalink)
90 day: 56.29 mpg (US)
I'd like to comment on the sharp edge on the rear bumpers corners.
There is a reason why this is seldom done. The reason is that the sharp edge does not always benefit drag reduction compared to riounded corners. Also rounded corners allow the bumper to be stronger and lighter.
I own a 2011 Honda Insight. One of the complaints sometimes heard about that is its side wind behaviour. And I have experienced that too; but only in very specific conditions. Which ultimately led me to figure out (or so I believe) what is really going on.
First of all you have to know about the Coanda effect. Air, water, anything flowing in a steady motion along na edge will follow that edge if it bends away. If it didn't a vacuum would be created between the edge and the stream (and indeed, in the bend the pressure is lowest close to the edge; this is the force that bends the stream, or more precisely, the higher outside pressure does that)
The more stable the flow is, the stronger the Coanda effect will be. The Coanda effect destabilizes laminar flow; disturbances in the flow will thus be enlarged, as the parts of the disturbance that least follow the curve of the edge will have lower pressure than those that do, so they grow while the other parts of the stream dwindle.
When a laminar airflow along the side meets the rounded edge of the rear bumper it will curl around it, inducing a vacuum that pulls the car back and maybe even creating a horizontal vortex roll which low pressure center also pulls the car back.
A sharp edge makes the laminar flow continue in its original direction, creating a sharp divide between the air behind the car moving at more or less the speed of the car and the air just aside of that, which is pretty much stationary. The air behind the car would have pretty much the ambient pressure, so it won't pull the car back.
So why is the sharp edge so uncommon? Where's the snag?
The snag is that the airflow on the sides is usually not laminar at all. Straight against the wind, the same air that is close to the side at the front fender will still hug the rear fender. It will have met 2 wheel wells and creases at the door panels etc. It will be turbulent. It will pass the rounded edge without much interest; it is an unstable system to begin with.
With a very strong sidewind that all changes. The air close to the side body panels gets flattened like dough under a roller, and so are any disturbances in it. Now the airflow at the rear edge will be laminar and happily curve around the bumper. This will cause drag but it still does not explain the constantly jerking disturbances I feel when hit by sidewind.
The jerking behaviour stems from the sidewind being just not strong enough to produce constant laminar flow. The Coanda effect will kick in and break off violently, due to its instability enhancing nature.
The highways in Holland are designed not to follow straight lines for long but use very mild curves, sometimes deviating more than 45 degrees over several kilometers, to raise locational awareness and fight boredom. They also make for conditions to study a cars reaction to varying angles of wind at high speed.
What I noticed in my Insight doing 95 km/h (58 mph) was that with high wind (6 Bft) almost straight aside fuel consumption was at about 5 liter per 100 kilometer. While my direction slowly turned against the wind it suddenly increased to 5.5 to 6 l/km while shaking the car. Turning further against the wind, the shaking stopped and the FC went back to 5.0. Straight against the wind it even dropped to 4.5.
So the Insight is a nice example of a windtunnel optimized car that suffers in real world conditions. I believe the rear bumper is the main culprit here, especially its smooth rounded edges. Even just detaching it seems to help mpg.
What to do? I've got kids in the car so the bumper stays on. Reshaping it is a bridge too far for me.
Anything that breaks the Coanda effect should be good enough.
A small ripple (like created by a thin zigzag tape) could do the job.
I plan om sourcing colorless zigzag tape and stick it on just where the curve starts. If I can't get it then maybe a stripe of clear sticky tape encasing a nylon guitar string in the middle will do.
Of course there are many questions still to be answered about this, like G, B or E?
E obviously is the lightest but might not be enough to disrupt the flow.
My apologies for this lenghty reply, especially from an aerodynamical layman like me but I got this in my head and start to really believe it.
As I lack the skills to disprove my theory, I hope that someone who knows points out my errors and stops me from ruining my car and its mpg efficiency.
Nathan jones (07-11-2022)
Old 12-27-2012, 06:55 PM   #45 (permalink)
90 day: 51.82 mpg (US)
Just as an additional note, the sharp vertical edge/corner on rear bumpers has become more and more common on "high efficiency" production cars in the last few years. You can now also find them on:
- 3rd generation Prius liftback (prominent)
- Prius "C"
- 2013 Honda Accord Hybrid (very prominent)
- Honda Fit EV (very prominent)
- 2012 Toyota Camry Hybrid
And probably others I haven't noticed.
Old 12-28-2012, 05:41 AM   #46 (permalink)
There are also several examples of a slight crease before bending, like on my wife's Hyundai I10. It does less than 30 mpg btw because she never leaves town; the crease is wasted on this one
The reason I want to deal with this is that I also plan on covering the rear wheels. As the air flow becomes less turbulent by that, it will increase this very problem.
The Following 2 Users Say Thank You to RedDevil For This Useful Post:
betasniper (07-15-2013), Nathan jones (07-11-2022)
Old 01-25-2013, 01:44 AM   #47 (permalink)
VWCw
VWCw's Avatar
10 Jetta V - '10 Volkswagen Jetta
90 day: 34.76 mpg (US)
This has been on a back burner in my mind for awhile (the thread is 4 1/2 years old now), of how to make a faux "crease" down the trailing edge of my sides. And then I found self-adhesive rubber door sweeps for about $3.00 in the weatherproofing section of the hardware store. The kind you put at the bottom of your (house) door to prevent drafts. The adhesive is pretty strong, and there would be about 3/4" of thin rubber sticking straight out from wherever attached, creating a sharp trailing edge for airflow separation, versus following the rounded side of the bumper and hatch. From earlier in the tread, it sounds like 15 degrees past the beginning of the curve would be ideal.
Luck is probability taken personally.
Old 01-25-2013, 07:40 AM   #48 (permalink)
I think 15 degrees is too far back.
The turbulence or vortices created by the ridge will take some distance to build up before they break the boundary layer and influence the airflow beyond it.
I'd put them right where the bend starts.
But maybe it has to be moved even further up front. Only testing can tell, I'm afraid.
Nathan jones (07-10-2022)
Old 07-11-2022, 12:26 AM   #49 (permalink)
Ecomodding Apprentice
Thanks for your information Red Devil. I will redesign my gen II Prius with sharper edges too
Video: active aero (grille block) via shape memory alloy MetroMPG Aerodynamics 7 01-30-2010 11:21 PM
Video: recently "resurrected" GM EV1 - fresh news! MetroMPG Fossil Fuel Free 11 01-03-2009 08:04 PM
GM admits the Volt concept car's aerodynamics suck MetroMPG Aerodynamics 16 12-13-2008 01:16 PM
Video: Weird chevy volt ad SVOboy General Efficiency Discussion 10 09-18-2008 03:08 PM
Video: worth a watch - Jay's Garage looks at GM Challenge X vehicles MetroMPG EcoModding Central 4 02-27-2008 12:10 AM
