Old 02-29-2008, 12:50 AM   #41 (permalink)
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
Smile
I wish my car looked like this
Name:	oct05 fall 2005 001c.jpg
Old 02-29-2008, 05:26 AM   #42 (permalink)
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
Originally Posted by SVOboy View Post
fix the dang thing
Yup. And steal everyone else's ideas.
Old 02-29-2008, 08:32 PM   #43 (permalink)
Awesomeness personified
AndrewJ's Avatar
Harold - '94 Honda Civic CX
90 day: 54.51 mpg (US)
Margot - '08 Surly Big Dummy
Send a message via AIM to AndrewJ
Variable grille-opening
SuperMID
Lots of SuperMID aero-testing
Battery/charger upgrade for alternator unbelting.
Side-mirror upgrade.
65mpg. Hopefully.
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
Old 03-01-2008, 01:30 PM   #44 (permalink)
I"m not lurking!
s2man's Avatar
Porthos - '96 Chevrolet Cavalier
90 day: 31.3 mpg (US)
Originally Posted by s2man View Post
So this weekend the plans include:
1. install flat windshield wipers and cowling.
2. install Taurus chin tray on my Cavalier.
3. not indexing the plugs.
4. test alternator disable.
1 - Flat wiper blades - done. I like them. They lowered the arm 1/2", and eliminate the nasty frame. The rubber cowling is wavy from being wadded up in my shop. We'll see if it straightens out after a few days in the sun.
4 - Alternator disable - success. The engine ran fine on 11.5 volts. I'm going to test it on the road, to make sure it does well under load, then install the switch and ammeter. I located a good place to run wires through the firewall, too.
2 - Well, I got off track on this one. The plan was to remove the air dam, install the chin tray, then fasten it down with the air dam screws. But the air dam is riveted on. I figured If I"m going to remove the air dam, I may as well start the belly tray. Then I realized the belly tray will be in the way for the a/c removal. So I jsut removed the a/c instead. 26.5 lbs of junk and one rotating mass (the pully) removed from the car. While installing the new serpentine belt, I decided a shorter belt will still work with the tensioner, and omit the power-steering pump.
EDIT: 9 - WAI completed. Sheesh, I stared at that filter box all winter, thinking I had to remove it to cut the hole. It turned out I just used a hole saw from the *inside* instead of the outside. $7 for aluminum dryer-vent tubing.
I spent a lot of time under there thinking about the belly pan (and it wasn't even on my todo list). I think I've got the attachment worked out. And I built a cardboard mockup for front-tire air deflectors.
So I need to add to my todo list:
11. power steering delete
12. belly pan w/ tire deflectors
Roll on,
Stew
Old 01-01-2009, 10:37 PM   #45 (permalink)
90 day: 51.82 mpg (US)
So, 2008 just expired. How'd everyone do?
And don't forget to head on over to the new thread: http://ecomodder.com/forum/showthrea...ions-6608.html
My 2008 reality check:
2008 Metro goals:
- properly affix rear skirts (brackets)
- make permanent partial kammback
- experiment with front air dam
- develop front wheel skirts
- test airtabs
Metro wish list:
- lowering
ForkenSwift goals:
- dissassemble, clean & repaint everything (motor, racks, engine compartment)
- install battery pack LED monitor
- add DC/DC converter (sort of - it's duct taped in place)
ForkenSwift wish list:
- add 2 more batts on a controller bypass circuit for 60v turbo mode
Old 01-02-2009, 01:57 AM   #46 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
I was able to achieve #1 on my list: change the ATF over to Synth.
The order of importance is still the same, but the year is different
The overall goal remains the same: achieve an average FE in the 30's, and keep Teggy on the road
-Rick
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
