View Poll Results: which should I use
small hinge (picture A) 9 75.00%
bracket (picture B) 0 0%
somthing else 3 25.00%
Voters: 12. You may not vote on this poll
Old 08-10-2010, 07:46 AM   #11 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
Originally Posted by BamZipPow View Post
You'll have to shim between the hinge and the fender so the curved part of the fender becomes flat fer the entire hinge.
Then the gap between the skirt and car body gets too large. But a good idea.
Piwoslaw: you are right that having to move the car to get a the valve stems would be a pain! I was thinking of that with Frank Lee's post, so I think that a hinge is the better idea for now.
So for my only cost has been for the primer http://forum.ecomodder.com/images/smilies/biggrin.gif
I had the galvanized sheet steel, brackets, hinges, lots of mic screws, I had to re-purpose a metal yard stick for the brace and will have to buy some stock metal for the other side. I also have the paint to match on order.
Old 08-10-2010, 08:29 AM   #12 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Originally Posted by Nevyn View Post
So don't start it - just push a little!
I'd love to, but I've tried and pushing 1.5 tons over sand is too much for me
Old 08-10-2010, 11:54 AM   #13 (permalink)
The Crimson Crawler - '04 Hyundai Elantra GLS
90 day: 36.71 mpg (US)
Oh, on SAND? Well no wonder. For that, you'd have to put cardboard under the wheels so it rolls easier. Or dig the sand up a little so that you're rolling into a divot.
(I enjoy being a goof)
Old 08-10-2010, 12:21 PM   #14 (permalink)
Lil Sulf - '94 Toyota Corolla
90 day: 47.62 mpg (US)
Hah, that's usually what I do. Just sit in the driver's seat and let down the ebrake for a second or two on the driveway.
And that's without a Scangauge o.O
Old 08-10-2010, 12:28 PM   #15 (permalink)
Just found these while taking a quick look online. With these hinges, I believe there is no reason for springs, since they close by themselves . . .
Old 08-10-2010, 10:02 PM   #16 (permalink)
kgwedi's Avatar
Atos - '05 Hyundai Atos Prime AT
90 day: 21.33 mpg (US)
The Lexan skirts on my Metro are held on with 6 screws. I can easily roll the car forward to get to the valve stems.
I live in a dry warm area. One thing I didn't think about was static electricity. I can wash them, and in half a mile they are filthy. They seem to suck up dirt. I can feel the hair on my hand raise when I get near them.
Old 08-10-2010, 11:54 PM   #17 (permalink)
Wiki Mod
Update:
My paint came in today!
I have got the first skirt painted and clear coated (4 coats each). No picts will upload tomorrow.
I made the second skirt today, it took at lot less time than the first! It is fitted and has 2 coats of primer on it.
I epoxied on the the front brackets (drivers and passenger sides), but I ran out of epoxy so they are not on all that well. I found some more stuff but it will have to wait till tomorrow to put on.
I might get a test run of them tomorrow (11th). Then on to testing!
The Following User Says Thank You to Weather Spotter For This Useful Post:
COcyclist (08-11-2010)
Old 08-11-2010, 03:43 AM   #18 (permalink)
Sounds great, thanks for the update.
Old 08-11-2010, 10:00 AM   #19 (permalink)
...beats walking...
...a W-I-D-E hinge is both stronger and more stable (wind-induced vibration) than a small, narrow hinge.
Old 08-11-2010, 10:07 AM   #20 (permalink)
Wiki Mod
these hinges are 2 inches wide. I think that they are large enough.
DIY: plastic rear wheel skirts (Geo Metro) MetroMPG DIY / How-to 57 06-12-2014 09:16 AM
Rear Wheel Skirt using water heater drain pan cfg83 Aerodynamics 45 02-20-2012 02:08 AM
2000 Mazda Protege Rear Wheel skirts Walk Through Blue Bomber Man Aerodynamics 13 08-29-2009 02:12 AM
Rear wheel skirt / cover question pasadena_commut Aerodynamics 5 02-16-2009 04:50 AM
Dream Wheel Skirt. Am I Crazy? 2003protege Aerodynamics 7 05-21-2008 01:40 PM
