Old 01-11-2017, 04:00 PM   #51 (permalink)
Volvo-driving MachYeen
Fingie's Avatar
Neo Volvo - '98 Volvo S70 10V
90 day: 24.98 mpg (US)
Had a brainstorm here a couple days ago.
Me and my friend would like a water vehicle. The problem is that I am piss poor.
If you don't make any mistakes in your life,
life itself will be a f*ckup.
With Volvo to Valhalla and back!
Old 01-11-2017, 04:23 PM   #52 (permalink)
ScanGauge <3
ThermionicScott's Avatar
This one is pretty low-emission.
Best tank (so far): 32 MPG
The Following User Says Thank You to ThermionicScott For This Useful Post:
Fingie (01-12-2017)
Old 01-11-2017, 04:51 PM   #53 (permalink)
We could start a club.
Use case: Maybe somewhere between an inner tube fisherman's float and a 23ft sail boat?
Build-your-own Teardrop Camper Kit and Plans
DIY stitch-and-glue. Two cargo canoes with decking and the teardrop suspended between them, with a wood gas outboard motor on the stern of one canoe.
A project with four major components, each of which is useful on it's own. Roadable FWIW.
Old 01-12-2017, 06:57 AM   #54 (permalink)
Fingie's Avatar
I have an idea. Towable boat!
It wouldn't be able to run wood gas though.
EDIT: it could, but gasoline must be kept as backup. Or run it on E85
Old 01-12-2017, 01:45 PM   #55 (permalink)
Once wood gas is out of the picture, the choice is easy:
Florida Figured Out How To Hoverboard While Sitting
Fingie (01-13-2017)
Old 01-12-2017, 09:51 PM   #56 (permalink)
Originally Posted by Fingie View Post
And if the expensive car tax reform happens here, i'll import a Piaggio APE and modify it too with a engine swap
I've been also considering to do a similar project. So, what engine would you be more likely to swap into a Piaggio Ape?
Old 01-13-2017, 08:22 AM   #57 (permalink)
Fingie's Avatar
a 4-stroke, with focus on torque.
Old 01-16-2017, 01:31 AM   #58 (permalink)
Either some 3-cyl 1.0L out of some random subcompact or the parallel-twin out of a Honda NC (eventually the engine of a CB 500 if you can get it cheaper and more easily) seem to be the most suitable. Unless you'd have easy access to some source of BMW R-series or Ural motorcycles which flat-twin engine would probably become an easier fit under the loading bay's floor.
Old 01-16-2017, 10:48 AM   #59 (permalink)
how about 1/2 VW air cooled bug engine. use late model waterboxer cylinders, EFI, and if you must: aftermarket racing cat.
Old 01-16-2017, 01:45 PM   #60 (permalink)
Dunn-Right Incorporated
Home of the "Volks-Air" Air Compressor
"When it has to be Dunn-Right"
Instead of cutting down the engine, do a Dunn-Right air compressor conversion. Add a 60 gallon compressed air tank, twinned alternators and a battery bank.
Wherever you go, you are the local utility company.
Use hemp oil lubricants.
Edit: Why I like this idea: It ties the vehicle to specific functions, but if you had the air tank and batteries between the driver and rear axle, then you could have a 4ft tall tool chest behind the axle that could drop down onto it's own casters. They you'd have a shop truck that you could drive indoors on compressed air.
Instead of an APE or Cushman, I'd want a fiberglass Ed Roth tricycle body. Maybe a C-cab. Here's an (admittedly rear-) Ed Roth VW engine:
http://justacarguy.blogspot.com/2012/04/ed-big-daddy-roth-tribute-trike-and.html
