Old 12-17-2010, 02:47 PM   #31 (permalink)
90 day: 51.82 mpg (US)
If I'm not mistaken, I think people in the know will tell you that the LLR qualities of the size spec'd for the Insight were different from other sizes.
Old 12-17-2010, 02:53 PM   #32 (permalink)
A madman
brucey's Avatar
Pequod - '17 Subaru Outback
90 day: 22.79 mpg (US)
Send a message via AIM to brucey
See what I mean? If you had subaru sized tires you could get these all day long for free
Old 12-17-2010, 02:59 PM   #33 (permalink)
I'm going to wager you guys don't like the traction not because of the tires, but because you have "AWD syndrome" - driving around like lunatics thinking your car will save you.
(Ducks for cover! )
Old 12-17-2010, 07:10 PM   #34 (permalink)
A madman
brucey's Avatar
You should see how hard of a time I have convincing people that low rolling resistance does not equal low grip. They'll hear nothing of it while simultaneously recommending 740A/B tires.
Old 12-18-2010, 01:51 PM   #35 (permalink)
wdb
lurker's apprentice
PlainJane - '12 Toyota Tacoma Base 4WD Access Cab
90 day: 20.98 mpg (US)
(Ducks for cover! )
Not at all! I drive around like a lunatic in ALL my vehicles, not just the AWD models. But I truly have never heard anything good about RE92's, in all my years of Subaru ownership and enthusiasm. So I went searching.
According to TireRack, the OEM tire on 2010 Insights is the Dunlop SP31, which is indeed LRR and very nice tire. They were original equipment on the Fit; I took them down below the wear bars before replacing them. Never surprised me once, in many K's of 'lunatic' driving. So-so in wet conditions but nowhere near scary. Not good at all in the snow, but most all seasons aren't, so eh. 51psi sidewall max, relatively high load rating. A nice, sturdy tire.
Old 12-18-2010, 02:15 PM   #36 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
The OE tire on the Insight appears to be a different formulation than RE92's in any other size. Just check out the specs sheet on The Tire Rack. Similarly, the 2010 Insight has almost nothing in common with the Insight but the name.
I am not aware of ANY commercially available passenger car tire with lower rolling resistance than the OE Insight RE92's, nor have I heard any reports on InsightCentral where someone installed different tires and saw better FE or LB. That's a shame, because tire technology has improved greatly in the past 12 years. It's just that nobody is anywhere near as dedicated to efficiency as Honda was in 1999.
Old 04-17-2011, 10:54 PM   #37 (permalink)
RE92 baggage
Well, I finally got myself a set of used RE92's...
Unfortunately, they came attached to a sizeable hunk of radioactive-snot-green aluminum and plastic.
So I'm actually still looking for another set of RE92's for team Suzukiclone.
There are four RE92's available in AZ, if anyone's interested. I don't think they're worth shipping up to upper NY state for what it'll cost to get them there.
Old 04-17-2011, 11:55 PM   #38 (permalink)
Wonderboy's Avatar
The Fruit Bat - '01 Honda Insight
Last 3: 54.26 mpg (US)
Current - '21 Subaru Impreza Wagon
90 day: 34.36 mpg (US)
Wait, so you bought an insight?! Mazel tov!
I am also looking for at least 2 RE92s still as well. There were 2 good ones on the insight rims I bought, 1 dry rotted and worn beyond use, and one very borderline, probably no good as well. Got 2 good ones on the front of the crx though! Dem tires are tough to come by!
Old 04-18-2011, 12:08 AM   #39 (permalink)
Yeah, I guess that's what they call an "up-sell": stop in to ask about tires, leave with a whole car.
It needs a battery pack. And I have no time for yet another project, but couldn't resist.
What Frank Lee said was right when I got the shack: you will always increase the amount of junk you have to fill the space available.
Old 04-18-2011, 01:41 AM   #40 (permalink)
You can't beat the laws of nature!
roflwaffle (04-18-2011)
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 69 12-27-2014 01:17 PM
Full set of Potenza RE92 R14 - Toronto Area Wonderboy For Sale 5 05-25-2010 11:32 PM
Bridgestone Tires and LRR gone-ot EcoModding Central 30 05-04-2010 12:31 PM
FS: Set of (5) VX Rims with LRR Tires XFi For Sale 2 02-16-2008 02:49 PM
