Go Back   EcoModder Forum > AltModding > Alternative Transportation
Old 10-07-2016, 12:33 PM   #221 (permalink)
Drive less save more
ecomodded's Avatar
90 day: 60.42 mpg (US)
Here's a pic of a couple local high boy racers
there is never a dull moment riding one of these
Here is my daily driver its a '99 RM Element with its 26x 1.25" street tread on.
I run the tires between 95 and 100 PSI , the shocks make the ride soft as ever even at that psi.
Save gas
Old 10-10-2016, 02:22 AM   #222 (permalink)
Jack-Lee's Avatar
Partygurke - '90 VW Polo 2F
Rodi - '04 Smart Roadster Coupe
Drive a lot this hier with my DIY Bike (i build it completly, incl. the frame itself)
The Following 2 Users Say Thank You to Jack-Lee For This Useful Post:
Frank Lee (10-11-2016), oldtamiyaphile (11-03-2016)
Old 10-10-2016, 01:55 PM   #223 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Where'd you put the rear brake? Under the bottom bracket?
I'm up to three bikes right now, because I bought a new time trial bike in 2014:
I'm thinking of converting my 2006 P2C into a singlespeed, possibly fixed gear, to use around town, since I don't race on it anymore.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
Old 10-10-2016, 09:57 PM   #224 (permalink)
order99's Avatar
A new (to me) Kent Traveller folding bike. A co-worker gave it to me when the derailleur rusted shut and snapped in half...rather than just purchasing a new derailleur he decided to purchase an entirely new bike. Not that fond of derailleurs myself in this coastal salt air, I broke and shortened the chain, placed it on the third of five gears and made a nimble one-speed hill-climber out of it! Top speed no more than about 12MPH or so, but I can maintain that speed up moderate hills and slopes and stay fresh as a daisy doing it...
I do have a Sturmey-Archer internal 3-speed hub and shifter lying about-i'll probably build a nice 20" wheel around it later this month and see which configuration I prefer.
Old 10-11-2016, 08:04 PM   #225 (permalink)
I am upgrading my Sturmey-Archer internal 3-speed hub by fitting two gears from a freewheel 13T and 16T to give a six speed set up with a 44T chain ring. Some work with the die grinder and a spacer for the narrower chain so all fit on the hub . A short derailleur and shifter work with the 3 spd lever. The key is to use gears that are 3 teeth apart.
Old 10-11-2016, 09:50 PM   #226 (permalink)
Toyota - '94 Toyota Pickup
90 day: 29.91 mpg (US)
Scooter - '06 Yamaha Majesty
90 day: 31.65 mpg (US)
Interesting. What makes 3t the magic combo? The ratio difference just plays well with the AW, or easy shifting, or...?
Old 10-28-2016, 11:03 AM   #227 (permalink)
It is definitely the the gear spacing for the ratios. The internal gearing is 0.75, 1.00, and 1.33. If you want to use a double chain ring the spacing is 4 teeth (40/44T) for half step gearing or 10 teeth (40/50T) for the step and a half gearing. The idea is to get even spacing when plotting the gear-inch ratios on the natural log scale or a even percent increase progression.
Old 11-14-2016, 04:42 AM   #228 (permalink)
Jack-Lee's Avatar
@Vman : Yea, the rear brake is under the Bottombraket.
Old 11-29-2016, 12:28 PM   #229 (permalink)
I just found the thread.
It's a Schwinn Collegiate. I also have a lime-green Dyno with a springer front end. It's in storage because it's too long to fit the inside rack on the EMX bus.
Old 10-06-2017, 01:33 AM   #230 (permalink)
Jack-Lee's Avatar
Little bit faster then my upright
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1041 07-28-2014 09:19 AM
Hub cap drag versus weight and heat bryan11 Aerodynamics 7 01-13-2010 02:37 AM
EcoModder 100,000th Post Giveaway Spectacular!!! SVOboy Forum News & Feedback 35 05-09-2009 01:58 PM
Battery Post Repair bennelson Fossil Fuel Free 4 10-17-2008 03:35 AM
So you DO need collision insurance for a bicycle!!! Peakster Alternative Transportation 11 05-14-2008 12:32 AM
