Old 10-14-2014, 04:44 PM   #81 (permalink)
90 day: 49.01 mpg (US)
I do have the occasional hot brake nowadays despite the extra springs. Time to get it all cleaned and running free again. In for winter tires and brake service next 22nd.
Old 10-14-2014, 05:13 PM   #82 (permalink)
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 18.97 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
A hot brake indicates the beginning of a stuck caliper. Brake fluid absorbs water. This will form a rusty deposit in the bottom of the caliper cylinder as the piston moves out as the pads wear. When you put new brake pads in and push the piston back into the cylinder, it will ride over this deposit and stick. It may not be noticeable at first, but they will begin to drag as the piston binds in the cylinder. An older caliper can seize as the deposits work under the piston and fuse it to the cylinder. It is very important to remove the piston from the cylinder when replacing brake pads to ensure the cylinder is clean. Brake fluid should be flushed yearly as should power steering fluid. If your fluid looks dirty, it is. It should be clear or amber colored.
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
The Following 3 Users Say Thank You to IsaacCarlson For This Useful Post:
101Volts (06-13-2017), j12piprius (10-14-2014), Piwoslaw (05-14-2022)
Old 10-14-2014, 05:45 PM   #83 (permalink)
cowmeat's Avatar
Princess Carriage - '20 Ford Explorer Limited
Silver - '22 Ford Maverick Hybrid XLT w/tow pkg
Maverick Hybrids
90 day: 41.3 mpg (US)
I doubled up on the brake clips on the Black Widow back in the day, and bent the clips farther out so they'd have even more tension, and that car would roll forever. When I had it up in the air adding the extra clips, I spun the front wheels, and they spun for a looooong while!
Never got around to adding any for the drums in the rear, but the front clips definitely gave me extra roll for P&G/EOC
The Following User Says Thank You to cowmeat For This Useful Post:
Old 10-14-2014, 06:47 PM   #84 (permalink)
Never gonna happen. My brake and power steering fluid gets changed once a decade, whether it needs it or not.
Nobody else is going to change their brake fluid once per year either. It's either too costly, or too time consuming.
Brake calipers are cheap, and it's less costly if they have to be replaced once in the course of vehicle ownership than to do a yearly fluid change.
My car is approaching 9 years and 100,000 miles, and I'll be replacing the coolant, power steering fluid, brake fluid, and gear oil. After that, I probably won't touch it again until 200,000 miles.
The Following 2 Users Say Thank You to redpoint5 For This Useful Post:
Frank Lee (10-15-2014), Joggernot (02-29-2016)
Old 10-14-2014, 09:16 PM   #85 (permalink)
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
No other pictures, but they are still doing their job..after a year and a half.
Originally Posted by johnlvs2run View Post
Do you have a photo of these before you put them in the pads?
Is that a U shape that goes in the hole, and how do you make sure they don't pop back out?
- Tony
Old 10-15-2014, 04:26 AM   #86 (permalink)
Annual brake fluid change? Overkill, I think. Lucky if I do it every 10 years.
Old 10-15-2014, 04:52 AM   #87 (permalink)
Are we sure the OEM clips pictured are not just anti-rattle clips? My first car had them too, they lightly push the pads into the piston/caliper side to made sure they don't flop about and make a rattling noise.
They're nowhere near strong enough to push in the piston, thats for sure.
Old 10-29-2014, 09:56 PM   #88 (permalink)
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
anti rattle clips
I looked at the front brakes today.
Initially the wheel spun only 1/2 a turn, and stopped very quickly. The pads were locked in by the anti seize compound and not able to move freely. I removed the compound and installed the drag reduction clips in the proper manner, but they were flimsy, causing immediate drag and not working as expected. I took them off, removed the anti rattle clips, and the pads were completely free.
The wheel now spins 2 full turns, and the car appears to coast better than it did.
The Following User Says Thank You to j12piprius For This Useful Post:
RedDevil (10-30-2014)
Old 02-28-2016, 12:41 AM   #89 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
On dirt track we used a 1psi check valve to keep the caliper from draining into rhe master cylinder witch was mounted lower than the caliper. If this positive pressure was not maintained all mighty Gravity would push the fluid down and out thw master cylinder sucking the pistons open as well.during the week between races. 1psi for disk and 5psi for drum. Diesel Dave. Did you find some for your Dodge.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
Old 05-14-2022, 04:13 PM   #90 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
I checked that PSA does not seem to offer brake clips for any Peugeot model
I recently had a glimpse of my brakes (without disassembling anything) and did not see any mounting points or holes.
So, in general, any ideas how to attach these clips (assuming DIY, made of bicycle spokes) to brakes that where not made for them?
