08-13-2015, 01:27 PM
#231 (permalink)
Lean Burn Cruiser!
Originally Posted by MetroMPG
Nice! Hangin on by your fingernails.
How well dialled in is your SG to actual numbers at fill-up time?
I got down to 50.1 yesterday before the phenomenal trip last night. This feels like plenty of cushion!
The SG has been within 1% of actual mileage the past few tanks, so this should be my first 50 I'm hoping for another 55-60 mpg trip tonight. That should solidify this tank!
The Following 2 Users Say Thank You to BabyDiesel For This Useful Post:
08-13-2015, 01:41 PM
#232 (permalink)
Good luck!
08-13-2015, 02:56 PM
#233 (permalink)
Not bad for a machine
I knew the new belt would do the trick
The Following User Says Thank You to dirtydave For This Useful Post:
08-14-2015, 11:36 AM
#234 (permalink)
Lean Burn Cruiser!
08-21-2015, 09:13 PM
#235 (permalink)
Lean Burn Cruiser!
The last two fills have been 50.88 and 51.02 mpg for the Ecoscort. These are 103.5% and 104.1% over EPA
Lean burn will be going on tomorrow. This should put me into the 50's for good, and I have a shot at getting into the 60's this year before the cold sets in.
08-21-2015, 11:02 PM
#236 (permalink)
In Lean Burn Mode
Nice can't wait for your results!!!
Pressure Gradient Force
The Positive Side of the Number Line
The Following User Says Thank You to pgfpro For This Useful Post:
08-24-2015, 12:58 AM
#237 (permalink)
Lean Burn Cruiser!
Yesterday marked one year since I logged my first fill into Ecomodder. Woohoo!
I decided to retire Ecoscort. It had a spectacular run with 2 50+ mpg tanks to finish out its first year.
61 fills later, I have averaged 43.45 mpg the past year. That is 73.8% over the EPA combined average!
I think that I will continue this thread, but this will be the changing point. Now that lean burn is a reality, it is time to see just what this ZX2 can do! I can't wait to see the results!
Enter in the Era of the Ensightscort ZVX2
The Following 5 Users Say Thank You to BabyDiesel For This Useful Post:
08-28-2015, 09:32 PM
#238 (permalink)
Lean Burn Cruiser!
Update!
So I have a confession. There was no lean burn miles on this tank life has been so hectic that I have been unable to even install it this week! I am going to get to it tonight, come hell or high water!
I was able to put down 50.74 mpg on this tank. My 3rd tank over 50 mpg! I consider this one to be a baseline for the new year. I will be working from this point on up with a goal of a 60 mpg fill before the cold come back to NC!
For whom ever is reading this, I want you to know that these mpgs do not come easily. A lot of work has to be done off the road with modifications and on the road with strict attention to conditions, the ScanGauge, and the right foot. I am usually travelling between 40-45 mph, and sometimes slower than this. Living out in the country means lots of stop signs, so I have to plan accordingly by coasting over 0.5 a mile to each stop sign in order for my mpgs to balance out. This means I start coasting to a stop @ 40.5 mpg, stop, accelerate, and by the time my torque converter locks up @ 42 mph, the Trip Mpg is back to 40.5 mpg.
Hopefully with LB my average speed can increase along with my mpg
The Following User Says Thank You to BabyDiesel For This Useful Post:
08-28-2015, 11:35 PM
#239 (permalink)
In Lean Burn Mode
For whom ever is reading this, I want you to know that these mpgs do not come easily. A lot of work has to be done off the road with modifications and on the road with strict attention to conditions, the ScanGauge, and the right foot. I am usually travelling between 40-45 mph, and sometimes slower than this. Living out in the country means lots of stop signs, so I have to plan accordingly by coasting over 0.5 a mile to each in order for my mpgs to balance out, meaning I start coasting to a stop @ 40.5 mpg and by the time my torque converter locks up @ 42 mph, the Trip Mpg is 40.5.
BD could you explain this a little more? I'm not understanding it.
08-29-2015, 12:04 AM
#240 (permalink)
Lean Burn Cruiser!
Sure Russell! I edited the original post to make more sense. Let me know if it is!
What I meant is a half mile or more before a stop sign, I start engine on coasting in neutral. Coasting for this length of time gives me enough of a mpg boost to counteract the losses of having to get back up to speed. For the ZX2, it is 42 mph until I have lock up in top gear, and then my mpgs can go back to around 60 cruising.
This is the way I handle my routes that have stop signs every so often
