Old 06-24-2008, 08:46 PM   #21 (permalink)
Old Retired R&D Dude
Little Red - '12 Toyota Prius c 2 Two
90 day: 57.82 mpg (US)
"Whitey" Bulger - '14 Toyota RAV4 LE
Please! Not the big H
I tried to pry mine off, but it was on there really tight!
Once you get rid of that H, I'll bet a piece of plastic or coroplas could be placed on top of that mesh. RTV it. Tape to hold it down while the glue cures.
It's bound to be a bit more aerodynamic.
Cheers,
Rich
Current ride: 2014 RAV4 LE AWD (24 MPG)
Wife's Pizza Transporter
Old 06-24-2008, 08:48 PM   #22 (permalink)
Loving my blueberry
cwarnar's Avatar
Altimax - '98 Nissan Altima GXE
90 day: 32.88 mpg (US)
The Wan - '07 Toyota Sienna CE
90 day: 22.81 mpg (US)
Originally Posted by cookie96civic View Post
I have a 96 civic, small upper grill and large lower intake, at speeds over 45 is there enough air to cool the engine if I block both?
My temps are up only 9-10 degrees celsius. My rad fans still have not kicked on. The highest I got was 90 (194 F)
Old 06-24-2008, 09:18 PM   #23 (permalink)
EP3
EP3's Avatar
02WhiteEp3 - '02 Honda Civic Si
90 day: 28.35 mpg (US)
Send a message via AIM to EP3
Yeah I might put some kind of tape on the front and start with some kind of silcone or RTV from the back. Smooth it out as best I can. Put some painters tape to hold till it sets up. Then sand and paint with some black spray. Heck if it turns out too bad I could always buy some replacement insert that they make for about a $100.
"There is no such thing as a dumb question.. Just dumb people".
Old 06-24-2008, 10:15 PM   #24 (permalink)
Good question. Blocking the entire air inlet area may be risky on hot days. Keep a very close eye on the temperature gauge.
Could you make at least one opening "operable" with a choke cable from the driver's seat? Close it up on cool days or at high speeds, and leave it open for city and hot weather driving. Best of both worlds.
Old 06-25-2008, 01:38 AM   #25 (permalink)
Future EV Owner
Wannabe - '05 Honda Civic LX
90 day: 40.53 mpg (US)
Originally Posted by malibuguy View Post
for the people who run grille blocks, how much did you pick up in mileage???
i want to make 'em for the Caliber...but they would have to be behind the grille, since its technically my mothers car & she loves the grille, so are they worth it??
I'll have to try to sneak some behind the grille if they are worth it
I got about 2 percent on the lower grill block. I created a thread on the topic and documented my results. http://ecomodder.com/forum/showthrea...ivic-1822.html
The Following User Says Thank You to Arminius For This Useful Post:
beluga (01-08-2014)
DIY Vibe Grille / Fog Deletes trikkonceptz DIY / How-to 20 04-27-2011 02:27 PM
How does a grille block improve warmup time? fanamingo EcoModding Central 30 05-03-2010 05:13 PM
Video: active aero (grille block) via shape memory alloy MetroMPG Aerodynamics 7 01-30-2010 11:21 PM
Hybrid Grille Block/ HGB Hybrid Effects Aerodynamics 0 03-22-2008 08:53 PM
Full Grille Block: Upper Grille DifferentPointofView Aerodynamics 12 02-28-2008 10:14 AM
