Old 11-29-2010, 06:09 PM   #51 (permalink)
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
Here is the one on my 86 vw. A standard Garmin Fortrex 101 with a switched power supply. I have been keeping it in direction speed and trip odometer and have several other screens.
My standard Odometer is broken and the tach doesn't work after the owner installed a new alternator without a W terminal.
Noah Webster, 1787
Old 11-29-2010, 06:43 PM   #52 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
Heh, I have a Garmin Foretrex 101 on my bicycle. The most annoying thing about it is swapping out the batteries. Your SMPS solution is a better one. Though I bet you could get away with a linear regulator instead. The Foretrex doesn't draw much current.
Old 11-29-2010, 11:35 PM   #53 (permalink)
Do more with less
I agree... I had not used my Fortrex for years as I thought that the battery was too short lived for even bicycling. I didn't consider using it at first because of the battery issue and was going to purchase a specific car unit but the then thought why don't I investigate a regulated voltage supply and use my old but functional Fortrex. The Fortrex was not modified in any way and could be used with the wrist strap and batteries almost instantly.
I chose a ka317 regulator. My build thread was here: http://ecomodder.com/forum/showthrea...elp-15135.html
I was an electronics technician for 5 years about 40 years ago and still do little projects.
Thanks.
Noah Webster, 1787
Old 12-01-2010, 04:36 PM   #54 (permalink)
JacobAziza's Avatar
Big Orange Work Truck - '83 Ford F-250
90 day: 27.54 mpg (US)
Jessica's - '04 Toyota Matrix
90 day: 41.21 mpg (US)
Ninjette - '01 Kawasaki Ninja EX250R
a little high-tech; mostly cobbled together
1 Electric brake booster override
2 Highbeam switch (moved from floor switch which conflicted with using parking brake and clutch - also changed to use high and low beam simultaneously)*
3 Luxeon LED DRL/ driving lights
4 While doing all these changes, I accidentally broke the needle off the speedometer. Replaced with a sewing needle stuck into a matchstick
5 Voltmeter
6 Glow plug manual controller
7 Alternator disconnect (no longer used, as alternator has been removed)
8 GPS (with real time traffic avoidance)
9 Fuel log and note system
10 Electric brake controller (for towing)
11 Solar panel
12 A/C
13 iPod hiding place (connected to stereo behind dash, and is controlled directly by stereo faceplate)
14 Engine kill switch
15 Engine start
*As soon as I get around to it, I plan to reuse the floor switch to activate an "AOooOGA" style horn
I recently gave my girlfriend's friend a ride, who was very impressed that I have a bracket on the roof to hold a broom, but didn't seem to notice anything else.
Originally Posted by Piwoslaw View Post
A few months ago I returned home just as my neighbor pulled into his driveway. It was cold (around freezing) with some rain and sleet, and he yells to me: You rode your bike? In this weather?!?
So the other day we both returned home at the same time again, only now the weather is warm, sunny, with no wind. And I yell to him: You took the car? In this weather?!?
The Following User Says Thank You to JacobAziza For This Useful Post:
dennyt (12-01-2010)
Old 12-01-2010, 05:15 PM   #55 (permalink)
in tents
dennyt's Avatar
The Adventure Wagon - '94 Subaru Loyale Wagon 4x4
Subaru
90 day: 33.43 mpg (US)
Electro-Monkey - '11 Surly Karate Monkey BMC V2S Front Hub Motor
90 day: 694.1 mpg (US)
Jacob, love your setup with switches on the shifter. 30mpg out of an F250, wow! I drove a '73 F250 with a 390 and a 4-speed in high school... yeeha.
Old 12-02-2010, 02:57 AM   #56 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Take that as a compliment! It shows how well integrated everything is
Old 12-02-2010, 10:35 AM   #57 (permalink)
The PRC.
I just want that wood effect... Cool.
Old 12-02-2010, 10:53 AM   #58 (permalink)
aero guerrilla
Piwoslaw's Avatar
ID:	7453   Click image for larger version
ID:	7454   Click image for larger version
The Following 2 Users Say Thank You to Piwoslaw For This Useful Post:
cfg83 (12-02-2010), Sven7 (01-31-2012)
Old 12-02-2010, 10:59 AM   #59 (permalink)
The PRC.
Tempting...
EDIT : Or maybe
Old 12-02-2010, 11:54 AM   #60 (permalink)
JacobAziza's Avatar
I stole the idea from somebody here, don;'t remember who. It makes EOC SO MUCH EASIER!!!!
Hmm, thats actually a nice way to think of it. Thank you.
Still, you'd think that EOC would leave at least a little impression, what with a big 6.9L diesel V8 cutting out and starting up again
The camera lies. It looks like cheap plastic IRL. However, the block that the kill and start switches are mounted in is real wood. It's held to the shift column with a bracket I made by cutting a tin can lid to shape.
The Enclosure Thread, Show Yours Off!! americasfuture2k OpenGauge / MPGuino FE computer 87 04-24-2016 01:45 PM
2010 Washington Auto Show: "A Green Machine" - Jan 27-31 MetroMPG General Efficiency Discussion 10 01-30-2010 07:40 PM
Build Thread Key Postings Index Experiment. TestDrive Forum News & Feedback 7 02-15-2009 08:53 PM
STUFF HAPPENS TV Show bennelson The Lounge 2 10-17-2008 10:05 AM
