10-08-2019, 10:55 AM
#11 (permalink)
Wannabe hyper..., miler !
Originally Posted by Noitoen
Diesel engine on a Toyota hybrid is just plain heresy
ARGH. !
Yup, just like the Diesel was at the turn of last century,
just like the Toyota hybrid system was in the mid 80's,
just like the first human on the moon...
Glad you are in this forum but...
(not to get YOU upset), crawl under that rock you are comfortable with. New technology is not as easy to aquire, work to getting there can be tough and lots of bruised knuckles...just FYI
10-10-2019, 12:10 PM
#12 (permalink)
Originally Posted by vskid3
Ya, you won't have any issues with bolting up to the Prius' transmission because you won't be using it.
Weight savings won't make nearly as much difference in cruising mileage as aero. The Prius' aero will more than make up for its extra weight (most of which will be removed when you gut the hybrid system).
Are you looking for maximum mileage or minimum overall expense? A TDI swapped Prius would give max mileage, but I think getting a running Prius and using it as is would be cheapest. TDI into your Jetta would probably be the cheapest/best swap.
I do long distance delivery work and I'll be looking for maximum fuel economy and the smallest size I can reasonably use would be four-door hatchback although a wagon would be more ideal but less aerodynamic...
I thought the diesel Prius would be cool because you see so many videos with Ford's rolling coal against a Prius they will be fun to give them a taste of their own medicine a Prius rolling coal on the ford!
A Prius rolling coal against a regular Prius would also be kind of funny!
With YouTube videos actually paying money I would imagine possibly being paid more on YouTube videos than actually driving! Ha
Of course with my Twisted sense of humor I would like to buy a Tesla sell all the guts out of it and turn it into a gasser and go to a Tesla dealer complaining of it running roughly and watching their jaws drop to the floor when they see a big ol V8 in it... or maybe not a V8 necessarily just an internal combustion engine of some sort..
Anyways I am keeping my eyeball open for a relatively low-cost Prius to try to do a swap...
Theoretically diesel would be cheapest to run because you can actually make your own fuel whether it be black diesel straight vegetable oil or biodiesel...
Andrew
2003 Jetta TDI Wagon, 5 sp, 210K miles, Stock.....for now!
The Following User Says Thank You to Andyinchville1 For This Useful Post:
10-10-2019, 06:38 PM
#13 (permalink)
I like Diesel engines, and some of those coal-rolling videos are somewhat funny, but honestly I'm not into it. I have been more inclined to Diesel due to the efficiency and the alternate fuels usage.
Some hybrid setup maybe...
Yesterday I had a talk about converting Volkswagen engines to use vegetable oils with an Argentinian who owns a T4 Transporter.
10-10-2019, 09:27 PM
#14 (permalink)
home of the odd vehicles
Many states add additional taxes onto “hybrids”
Be sure to check your registration fees before you get too far into this.
10-11-2019, 03:16 PM
#15 (permalink)
You want viral?
If getting your project on as many blogs/forums/sites as possible is the goal, then a manual transmission diesel drivetrain in a Prius is unquestionably the way to go.
Also, it'd be pretty fun to see what kind of numbers you could get -- Prius Cd is 0.24-0.25 if memory serves, and frontal area is probably similar to the Golf. Do a few more well-known aero mods to it and you could be knocking MPG out of the park with a sufficiently tall top gear taking advantage of the low drag.
And the hatchback means it's still utilitarian for your needs.
Please keep us posted!
10-11-2019, 10:25 PM
#16 (permalink)
Not so sure if a manual would really be the way to go. Easier than trying to integrate the TDI with the stock powertronics of a Prius, but not so impressive.
When it comes to aerodynamics and its impact to the mileage, sure a TDI Prius might beat both a Golf and a stock Prius. I'd also not disconsider some mild-hybrid approach similar to GM's eAssist and Mercedes-Benz' EQ-Boost.
10-13-2019, 01:48 PM
#17 (permalink)
A 6 speed 1 liter Honda Insight motor inside a Prius would be good fun,
Just to put IMA and VTEC logos on the Prius.
Though it would be unlikely to impress in other ways
I am told some old “Toyota” manual transmissions like the one in the mr2 or Daihatsu charade mount up to a Prius motor as well
10-14-2019, 10:35 PM
#18 (permalink)
Maybe if you trim it down to get rid of some dead weight, it could serve quite reasonably. Some compact sedans in Brazil, even though seemingly still a little smaller than a Prius, are available with 1.0L 3-bangers nowadays. But they're AFAIK shorter-geared than an Insight...
The only application of the HSD with a more conventional transmission (actually an automated-manual without a clutch) is on those Hino 300-series hybrid trucks.
