Old 12-11-2016, 01:26 PM   #141 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Originally Posted by Fingie View Post
Anyone know if the block heater is beneficial to use at warm temperatures?
Yes... The benefits are the same as winter, easyer starting, takes less fule to reach operating temp. I use my factory block heater in summer some times (when I realize that I am going somewhere early enough )
My truck will reach aprox 80-90°f in mild winter and 135°f in summer 80-90°f ambant. Down in Las Vegas, Nevada it would read 113°f before starting, no plug.
Just .be shure if it is a remote (in-line instead of in the block) that its not over heating it self. A frind of mying hear in Montana, installed a remote on his full size Ford Bronco went in the heater line and had an internal Circ pump that failed . So now it will boils off the water and gets hot enough to burn the paint off the outside of the heater. I had expected convection to keep it supplied with -20°F water. But his heater core is a high point ,both lines go downhill to the engine trapping air in the unit
Do your fellow northerners use "parking heaters"? https://www.eberspacher.com/products...d-heaters.html
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following User Says Thank You to gumby79 For This Useful Post:
Fingie (12-11-2016)
Old 12-11-2016, 03:26 PM   #142 (permalink)
Volvo-driving MachYeen
Fingie's Avatar
Neo Volvo - '98 Volvo S70 10V
90 day: 24.98 mpg (US)
Got a definite answer to that. I fired up the OBD reader to check the temp before starting the engine, the engine temp was 85F with a hour of using the block heater
This'll be a nice thing when combined with a battery charger
If you don't make any mistakes in your life,
life itself will be a f*ckup.
With Volvo to Valhalla and back!
Old 12-11-2016, 03:33 PM   #143 (permalink)
Fingie's Avatar
Also, I've been in the process of planning a multifueled two-wheel tractor.
The tractor itself would run on gasoline or ethanol while using tools in the yard.
And then i'd make a wood gas unit that'll fit on a small trailer.
There is a plenty of engines on the market. It'd be easiest to use some small motorbike engine coupled with a gearbox and drive the wheels with a chain.
Old 12-14-2016, 05:16 PM   #144 (permalink)
Fingie's Avatar
buut that's another thread.
Old 12-17-2016, 08:45 AM   #145 (permalink)
Fingie's Avatar
A friend's friend has a 112 for sale, a lot of things done on it.
It might also have a bigger engine than my War Wagon. But almost every 112 has a 16V head.
The consumption is a bit bigger, but I think the body type has a lot of potential for aero mods.
Old 12-18-2016, 02:20 AM   #146 (permalink)
Renee - '92 Renault 50 Series
90 day: 21.21 mpg (US)
EscortEstate - '97 Ford Escort mk6 ANL
90 day: 37.66 mpg (US)
For some reason these Vazs are starting to grow on me, they remind me alot of my old Citröen ZX, now that was a car I loved and loathed in equal amounts at the same time.
I can see your dilemma as it does look aero moddable.
How much difference is there in the consumption ?
Old 12-18-2016, 09:51 AM   #147 (permalink)
Fingie's Avatar
the 16v 1.6 is a thirstier engine. but I wonder if it's just because the 1.6 seems to use the same air filter. (aka needs intake mods)
the 1.5 16v breaks valves if the cam belt breaks, but is very economic.
1.5 8V doesn't brake due to the piston being shaped for valves
and the 1.6 16V has enough clearance so the valves don't break.
Old 12-19-2016, 08:22 PM   #148 (permalink)
Have you already figured out if their engines are based in the 124-series (same used in earlier Brazilian Fiat cars) or the 128-series engines (known here as Sevel or "Argentinian" engine)?
Old 12-20-2016, 03:59 PM   #149 (permalink)
Fingie's Avatar
The newer engines are VAZ-Design
Old 12-20-2016, 04:01 PM   #150 (permalink)
Fingie's Avatar
Googled around a crapton, it was developed in-house with the assistance of Porsche designing the head.
