Old 08-08-2012, 11:17 PM   #11 (permalink)
HydroJim's Avatar
Aerofocus (retired) - '00 Ford Focus ZX3
90 day: 44.66 mpg (US)
The Red Baron (sold) - '93 Geo Metro
90 day: 44.1 mpg (US)
Originally Posted by Weather Spotter View Post
I hope you can make it to the tail meet
Right now it's not looking too good. I fractured one of my vertebra back in June
and I'm still in physical therapy and I'm not sure what my schedule will be looking like around that time. It sucks
Old 08-09-2012, 11:12 AM   #12 (permalink)
HydroJim's Avatar
Setting Angles
What do you guys think of this angle? sorry its not the right angle for a template overlay, but it's the best I could do until I can roll the car out of the garage.
It's nice to get a glimpse of the tail's final form.
The Following User Says Thank You to HydroJim For This Useful Post:
HHOTDI (12-13-2012)
Old 08-09-2012, 01:38 PM   #13 (permalink)
jalmir's Avatar
Avante - '02 Hyundai Elantra GT
90 day: 32.07 mpg (US)
cool project!!! Good luck!
Old 08-09-2012, 02:18 PM   #14 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
That doesn't look bad though.
Do you want to make it that long ?
Old 08-09-2012, 02:28 PM   #15 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Are you just eyeballing the angles or are you using math ?
Once you lay the template over the line drawing ( and have it at the correct spot ), you can simply print it onto a grid and use a yard-stick to scale up and measure the heights you need to be at at a given length.
This is of course with a perfectly level car on a flat surface.
I'm sure you were already using this method, but wasn't sure.
Old 08-09-2012, 03:12 PM   #16 (permalink)
HydroJim's Avatar
euromodder-It won't be as long as the metal pictured. The aluminum bar came in 8 ft lengths so I'm going to be trimming quite a bit off. I believe the tail will end up being about 3.5 feet from the end of the bumper.
I was just using the string hold method so I could make a rough cut of the aluminum bars. I'm currently using the clamp method the get all the bars to the exact same length so that the back of the tail is perfectly flat.
Old 08-09-2012, 03:19 PM   #17 (permalink)
Please post the materials used and construction technique for those of us who may follow you in the path of many tails.
Wow, i gotta stop planning and start doing! But then i've never constructed anything like that in my life.
I try to be helpful. I'm not an expert.
Old 08-09-2012, 06:49 PM   #18 (permalink)
HydroJim's Avatar
26" x 46" unknown gauge of aluminum sheet(Dad picked it off a job site)
x15 1/8"x1"x8' aluminum bar(not all 15 used in boat tail)
x3 1/8"x1"x8' aluminum angle( only used 1 so far but planning to use more)
x10 4'x8'x4mm black/white coroplast from home depot($110 and free shipping)
countless 3/8" fasteners and 1/4" self-tappers
planning on using:
acrylic window
automotive tape
foam sticky-backed weatherstripping
krylon fusion paint
This is all just for the boat tail.
That's what I've used so far. I'll add stuff as I think of it and use it. I'll be converting the first post to a sort of project summary when I'm done so I'll list materials and techniques there
Old 08-09-2012, 07:00 PM   #19 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
sorry to hear about the injury, our meet is planned for the afternoon or evening of labor day (Monday sept 3)
Old 08-09-2012, 07:08 PM   #20 (permalink)
HydroJim's Avatar
weatherspotter- I'll know more when the time comes.
