Old 08-15-2012, 03:42 PM   #61 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
its looking good!
I used a foam pipe insulation to act as my mating surface with the car. Would that work for you?
Old 08-15-2012, 03:59 PM   #62 (permalink)
MPG Militia HMV-25E80+A
JethroBodine's Avatar
FrankenJetta D - '90 Volkswagen Jetta GL
Diesel
90 day: 64.35 mpg (US)
Looking good, Man. Frustration just means you're doing it right.
It is always very amusing how our imagination is put to the test when overcoming reality. Redyaris
Boat tail project
How to gently bump start during EOC
Old 08-15-2012, 04:47 PM   #63 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
Very nice work, Jim.
All I can say is you'd better get a spacer between the aluminum and steel or that thing's going to be rusting like crazy.
Old 08-15-2012, 10:26 PM   #64 (permalink)
HydroJim's Avatar
Aerofocus (retired) - '00 Ford Focus ZX3
90 day: 44.66 mpg (US)
The Red Baron (sold) - '93 Geo Metro
90 day: 44.1 mpg (US)
I've made pretty good progress today. I've attached all of the panels except for the bottom panel because I've still being going up inside the tail to do some work. I still have to add a lot of self tappers just to make sure this thing is secure. I bought some metal to make some flashing to try and seal the boat tail to the car.
weather spotter- how did you attach the pipe insulation. That was actually my first thought, but I wasn't sure how well it would hold up with the hatch being opened and closed all the time.
Jethrobodine- I don't think that means i'm doing it "right" but I'm definitely having fun, so I guess that's what it's all about. not to mention I'm helping save the world
Sven7- that's a pretty good point. Any ideas as what a good space material would be?
Aerospace Controls Engineer.
Currently driving a mostly stock 2014 Mitsubishi Mirage DE hatchback.
Old 08-15-2012, 10:40 PM   #65 (permalink)
Sven7's Avatar
On its Rabbit, VW used a simple paper-thick film between its aluminum bumpers and steel mounts. I'm guessing you could use anything from frisket to polycarb. The important thing is preventing contact between the metals.
Old 08-15-2012, 10:50 PM   #66 (permalink)
HydroJim's Avatar
Thanks for the info Sven. I'll have to see what I have lying around. Maybe all my coroplast scraps would do. Hopefully I can loosen everything enough to slip some spacers in there.
Old 08-15-2012, 11:13 PM   #67 (permalink)
Diesel
Sven7 is talking about Galvanic corrosion. Coroplast would be a good isolator.
Looking forward to the first test flight.
Boat tail project
The Following User Says Thank You to JethroBodine For This Useful Post:
Sven7 (08-17-2012)
Old 08-16-2012, 05:07 AM   #68 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Looking good !
Any plans to add something to disguise the asymmetry ?
Old 08-16-2012, 08:25 AM   #69 (permalink)
HydroJim's Avatar
Originally Posted by Cd View Post
Looking good !
No plans to hide the asymmetry. It came about due to sagging when I removed the carboard box supports from the end of the tail during construction. Everything on the left side ended up being about 1 inch longer and not everything is in the same place. Not to mention my hatch has always been crooked with different gaps on both sides. I planned on disguising it when I cut out the back sheet of metal, but evidently I didn't do a very good job. It's good that it has a homemade look to it because everyone seems to assume I built this using a kit. Whenever someone says that, I can't help but think "I wish"
Old 08-16-2012, 10:07 AM   #70 (permalink)
EcoMod Proof of Concept
WD40's Avatar
WD-40's Insight - '00 Honda Insight
Gen-1 Insights
90 day: 56.04 mpg (US)
WD-40's Mirage - '15 Mitsubushi Mirage ES
90 day: 46.05 mpg (US)
WD-40's Sonata Hybrid - '17 Hyundai Sonata Hybrid Limited
I'll take MPG over looks any day.. I wish I was 16 again and had your balls to "Just Do It"
My hats off to you, and I look forward to seeing the results.
2000 Insight MT 106K Citrus A/C
