Old 07-12-2010, 09:03 PM   #471 (permalink)
Jeep Ecomodder
JeepNmpg2's Avatar
Daddy's Jeep - '00 Cherokee SE
90 day: 19.66 mpg (US)
Mama's Kia - '06 Sedona LX
I don't know XJguy, Basjoos drives a lot faster than Darin and he hasn't related anything to us about relative "takeoffs". If anything he writes about how stable his car drives. I digress that sidewinds will plague him more with his increased lengthwise cross-section, but there is always a trade off right?
Old 07-12-2010, 10:27 PM   #472 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Zombie Insight - '00 Insight MT
90 day: 62.82 mpg (US)
If crosswind stability becomes a hazard, there is a remedy:
Designing a tail extension for the first-gen Insight
Old 08-18-2010, 10:37 PM   #473 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
Matt - just saw your question. Probably to late to be useful on your project, but I could shake the car pretty vigorously wiggling from the tail.
Low frequency shaking though. I probably would have pulled some tape off with fast shaking.
Old 09-29-2010, 03:00 PM   #474 (permalink)
3-Wheeler's Avatar
AlienMobile - '00 Insight
90 day: 98.7 mpg (US)
Originally Posted by Blogpostwriter View Post
Nice project. I suggest you use a thin plywood for your tail.Its better than plastic because its more durable. It is best also to use contact adhesive in joining ends than to use epoxy. Contact adhesive sticks harder.
I'm a little reluctant to agree about with the statement above about contact adhesive.
Is this the same stuff that you spray on and let set for 20 minutes before bringing the two halves together?
I use epoxy on all sorts of stuff such as wood and foam, and once you get a good bond, it is permanent.
My experience with contact cement has not been as highly rated, due to delamination of layers over time, and the forces were low to-boot.
Jim.
Old 01-08-2011, 12:07 AM   #475 (permalink)
3-Wheeler's Avatar
Actually, MetroMPG's project gets my vote for mod of 2010.
There are several reasons:
1) First complete tail extension that I remember reading for last year.
2) First example of the video cam-on-a-stick. I was amazed upon seeing this.
3) Beautifully done rear wheel strakes.
4) Showed the true worth of the tail addition in the form of a 15% mileage increase.
5) Fabulous tuft testing, showing the air efficiency gains of the structure.
6) Very well designed AND lightweight structure from, what else, cardboard !!
7) Nicely crafted tight fit around the leading edge of the tail piece.
---- this is not easy, since if you cut too much off, it's hard to add back on.
8) This tail was the motivation to make one for the Insight.
Overall, an excellent example of how to build a beautiful tail extension.
Jim.
We do not inherit the earth from our ancestors, we borrow it from our children - Ralph Emerson
Old 01-09-2011, 01:24 PM   #476 (permalink)
Thanks for the kind words, Jim!
But my tail doesn't qualify on a technicality: I did all the building/testing in the early winter of late 2009.
This is my only picture of the tail I took in 2010, when it went out with the recycling.
(OK, I kept the aluminum tubing.)
Darin
Old 01-09-2011, 08:20 PM   #477 (permalink)
3-Wheeler's Avatar
...But my tail doesn't qualify on a technicality: I did all the building/testing in the early winter of late 2009....
Darin,
Then let's hope that I get a chance to vote on your project for 2011 !!
Jim.
Old 04-23-2011, 10:16 PM   #478 (permalink)
ZX - '97 ZX Monaco
OldContinents
90 day: 55.93 mpg (US)
Originally Posted by Funny View Post
Fortunately, Darin's need for speed brings him up to a whole 55 mph....
Therefore I see zero possibility of catastrophic incidents at this time, at least caused by D.
Sorry for being late from the party. I have been reading these threads with great interest, have been learning many things from all of you.
This quoted comment above deserves bit more thinking, imo.
Speed of driving is one thing, then we have the wind.
If driving against the wind, in gusts it is not rare to reach total aero speed of 100mph and violent gusts are really sudden danger to be aware of.
That is reason why I think mods should be planned speeds above 100mph in mind, to avoid any possible problems, parts becoming loose or car becoming airborne.
In here roads mostly have only one lane to each direction and nothing separating lanes instead of paint on tarmac, so I have to take account of gusts that oncoming big rigs are causing, it is easy to hear and feel that air which they move.
So I think it is misleading to think that driving at low speed does not require design to be working at higher speeds, but of course driving higher speeds say 100mph requires designer to think how to make shape work in speeds around 150-160mph because of normal wind, add storm and wind speeds of 100mph to be absolutely sure and there starts to be a challenge to design working mod.
What do you think, will it be effort wasted or is my thinking reasonable?
Old 04-24-2011, 01:19 PM   #479 (permalink)
basjoos's Avatar
Aerocivic - '92 Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Civic CX
90 day: 72.29 mpg (US)
I've tested my aeromods at speeds up to 100mph.
aerocivic.com
Old 04-25-2011, 08:14 AM   #480 (permalink)
Whereas my car's unaeromodded flat-out top speed is 100 mph. (~50 hp. )
There's no way I'd be attempting to drive 50 mph into a 50 mph headwind - accelerator floored in 3rd or 4th gear or whatever it would take. I never need to drive anywhere that badly.
Of course if someone else is planning to mod a car to drive in those conditions, then of course higher apparent wind speeds need to be taken into account and/or tested. I only drove this proof-of-concept tail at road speeds up to 100 km/h, in let's say ~15 km/h winds (guess).
boat tail, testing
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/project-geo-metro-boat-tail-prototype-15-mpg-10691.html
Posted By For Type Date
AeroProject: Prototipo Punto "Economy power" This thread Refback Yesterday 11:59 AM
AeroProject: Impressioni da una gita fuori porta This thread Refback 01-10-2012 11:34 AM
BlogYueNMe: Aerodynamic tail makes Geo Metro even cooler This thread Refback 01-01-2012 04:20 PM
Club smart Car > The 100 MPG Challenge 2.011 This thread Refback 12-20-2011 08:20 AM
achieving an optimal shape This thread Refback 12-15-2011 12:39 PM
Elektromos Auto - Index Frum This thread Refback 11-22-2011 03:25 AM
Keversite.NL • Toon onderwerp - Dakspoiler This thread Refback 11-20-2011 02:49 PM
The ten nerdiest ways to modify your car This thread Refback 11-11-2011 12:10 PM
AeroProject: Pressione degli pneumatici This thread Refback 11-06-2011 05:20 PM
Raw video for: "Testing aerodynamic boat tail +15% MPG" - YouTube This thread Refback 11-03-2011 10:57 AM
17 DIY Cars Hacked for Fuel Efficiency : Page 6 : TreeHugger This thread Refback 11-02-2011 01:50 PM
DonsDeals: Aerodynamic tail makes Geo Metro even cooler - Hack a Day This thread Refback 11-01-2011 07:19 AM
BlogYueNMe: February 2010 This thread Refback 10-31-2011 04:28 AM
Hypermiling | Autopia | Wired.com This thread Refback 10-22-2011 08:54 AM
Energy News This thread Refback 10-17-2011 11:08 AM
MAKE | Green This thread Refback 10-10-2011 05:34 AM
"Offtopic-posts-topic" NSFW - Page94 This thread Refback 10-01-2011 05:41 PM
Project: Geo Metro boat tail prototype - 15% MPG improvement @ 90 kph / 56 mph - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 09-28-2011 04:35 PM
Testing an aerodynamic boat tail - 15% better MPG - Geo Metro - YouTube This thread Refback 09-26-2011 10:21 AM
Attention, Greenies: Your Geo Metro Needs A Boattail This thread Refback 09-18-2011 09:09 PM
MAKE | DIY Projects This thread Refback 09-11-2011 05:12 AM
AeroProject: Aerodinamica ruote (parte 2) This thread Refback 08-30-2011 04:57 PM
AeroProject: Flow Illustrator Moviemaker This thread Refback 08-24-2011 05:10 PM
kamm back and golfball texture on rear of car. any design info? : engineering This thread Refback 07-27-2011 02:21 PM
‪Testing an aerodynamic boat tail - 15% better MPG - Geo Metro‬‏ - YouTube This thread Refback 07-20-2011 11:57 AM
Streamlined? - Page 2 This thread Refback 07-05-2011 07:40 AM
YouTube - ‪Testing an aerodynamic boat tail - 15% better MPG - Geo Metro‬‏ This thread Refback 06-29-2011 04:18 AM
Bil Hjemmelaget Båt Tail Car modifikasjonssett Gir Geo Metro Amazing Fuel Economy This thread Refback 06-09-2011 04:57 PM
archives for 04/2010 This thread Refback 05-14-2011 08:55 PM
Enterprising DIYer adds boat tail to Pontiac Firefly to boost mileage - Autoblog Green This thread Refback 04-11-2011 01:56 PM
The 100 MPG Challenge 2.011 - Club smart Car This thread Refback 04-09-2011 09:47 PM
Make: Online | MPG boosting tail cone This thread Refback 04-09-2011 03:19 PM
Pointes arrires This thread Refback 03-28-2011 06:36 PM
Motórum • Toon onderwerp - funny fototopic This thread Refback 03-17-2011 04:53 PM
Search Results firefly Hack a Day This thread Refback 03-11-2011 05:08 PM
impressive s2k mpg! - S2KI Honda S2000 Forums This thread Refback 03-01-2011 11:27 PM
AeroProject: Giusto per chiarirsi. This thread Refback 02-13-2011 07:38 PM
oldsmobile aerotech | Le Pics This thread Refback 02-10-2011 03:00 PM
Auto Home made boat tail Auto Retrofit Geeft Geo Metro Amazing Fuel Economy This thread Refback 02-01-2011 04:51 AM
Motórum • Toon onderwerp - funny fototopic This thread Refback 01-22-2011 01:25 PM
DIY automobile aerodynamic modification This thread Refback 01-14-2011 03:13 AM
Weight loss program for a Class B motorhome on an '89 E250 SD chassis - Page 3 - Ford Truck Enthusiasts Forums This thread Refback 01-09-2011 12:21 AM
Jullie mening gevraagd?? Onzin of waarheid?? - Focusclub.nl | Forum This thread Refback 12-15-2010 06:04 PM
Wind tunnel testing This thread Refback 11-24-2010 10:16 PM
Pointes arrières This thread Refback 11-09-2010 01:08 PM
Geo Metro: Geo Metro Photos, Wallpapers, Galleries, metro boat This thread Refback 11-05-2010 10:46 PM
Nopeusrajoituksia alennetaan 20-40 km/h! This thread Refback 10-03-2010 12:52 PM
Weekly Archive for January 3, 2010 : TreeHugger This thread Refback 09-17-2010 02:08 PM
Steel Aero Wheels For MoreMPG - RecycleBlog - RecycleBills This thread Refback 09-05-2010 06:40 AM
Coches eficientes y aerodinamicos sin comprar uno nuevo This thread Refback 08-26-2010 03:02 PM
Boat Tail - Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback 08-17-2010 06:35 PM
S2000 Forums -> impressive s2k mpg! : S2KI This thread Refback 08-14-2010 08:08 PM
geo metro - Jalopnik This thread Refback 08-10-2010 09:52 AM
Energy News This thread Refback 07-20-2010 05:27 PM
Enterprising DIYer adds boat tail to Pontiac Firefly to boost mileage - Autoblog Green This thread Refback 07-15-2010 06:54 AM
Project: Geo Metro boat tail prototype - 15% MPG improvement @ 90 kph / 56 mph - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 07-11-2010 08:44 PM
Aerodynamic tail makes Geo Metro even cooler | PS2Cover.com News This thread Refback 07-09-2010 02:25 PM
????, ?????(??) : monogocoro ????? - Part 10 This thread Refback 06-23-2010 05:31 AM
cool but ugly Archives : TreeHugger This thread Refback 06-20-2010 11:13 AM
Detto | Motorcafè il blog dei motociclisti dalla mente aperta This thread Refback 06-01-2010 03:00 AM
Keversite.NL • Bekijk onderwerp - Dakspoiler This thread Refback 05-31-2010 05:24 AM
Jalopnik: Obsessed With The Cult Of Cars This thread Refback 05-29-2010 05:04 PM
Autoblog Green This thread Refback 05-21-2010 01:36 PM
Bike Hugger: DL Byron: January 2010 Archives This thread Refback 05-14-2010 12:06 PM
citrina/straisniai/aerodinamika This thread Refback 05-06-2010 04:57 AM
ifeelgassy - Jalopnik This thread Refback 05-05-2010 05:58 PM
Home made boat tail auto Retrofit Geeft Geo Metro Amazing Fuel Economy Cars Transportation buildaroo.com This thread Refback 05-01-2010 06:27 AM
????, ???? : monogocoro ????? - Part 7 This thread Refback 04-25-2010 03:56 AM
17 DIY Cars Hacked for Fuel Efficiency : TreeHugger This thread Refback 04-23-2010 01:03 PM
Walden Effect: Homesteading and Simple Living Blog This thread Refback 04-19-2010 08:14 PM
Aerocivic - Honda Civic modifications for maximum gas mileage - aerocivic.com This thread Refback 03-31-2010 10:09 PM
Project: Geo Metro boat tail prototype - 15% MPG improvement @ 90 kph / 56 mph - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 03-31-2010 04:56 PM
Ricerca Aerodinamica | Motorcafè il blog dei motociclisti dalla mente aperta This thread Refback 03-30-2010 12:52 PM
How To Change A Tail Light In Geo Prizm - Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback 03-27-2010 10:31 PM
Stop Aerodinamica | Motorcafè il blog dei motociclisti dalla mente aperta This thread Refback 03-22-2010 05:06 PM
2009 December 25 | PS2Cover.com News This thread Refback 03-21-2010 05:17 AM
How To: Paritial Kammback This thread Refback 03-19-2010 10:00 PM
2010 January 07 | The Entertainment Blog This thread Refback 03-19-2010 04:00 PM
Fuel Economy | Autopia | Wired.com This thread Refback 03-06-2010 07:57 AM
La Cacharrería: un blog de tecnología diferente - Part 2 This thread Refback 02-18-2010 12:41 PM
S2KI - S2000 Forums -> impressive s2k mpg! This thread Refback 02-04-2010 02:28 AM
cars Archives : TreeHugger This thread Refback 01-30-2010 12:58 PM
Transportation-buildaroo.com This thread Refback 01-20-2010 04:54 AM
Kawasaki Triples WorldWide • View topic - Bike maintaining Tips .... This thread Refback 01-18-2010 01:53 PM
Anno | Motorcafè il blog dei motociclisti dalla mente aperta This thread Refback 01-16-2010 12:36 PM
????, ???? : monogocoro ????? This thread Refback 01-12-2010 10:26 PM
Slashdot Submission | Aerodynamic tail on Geo Metro boosts MPG 15% This thread Refback 01-12-2010 07:13 PM
Slashdot - News for nerds, stuff that matters This thread Refback 01-12-2010 06:57 PM
Autopia - Part 5 This thread Refback 01-12-2010 05:47 PM
Cool Cars | Autopia | Wired.com This thread Refback 01-11-2010 04:28 PM
????, ?????(??) : monogocoro ????? This thread Refback 01-10-2010 01:04 AM
????? ??????????? ?????? ????? • ???????? ???? - ???????(????) This thread Refback 01-09-2010 10:03 AM
Ingeniøren Mobil This thread Refback 01-09-2010 06:27 AM
Spar 15 procent med en grim hale - Motorbloggen | Ingeniøren This thread Refback 01-08-2010 05:04 AM
Difícil de aparcar, sí; ¡pero gasta como un mechero! | La Cacharrería This thread Refback 01-07-2010 02:34 PM
monogocoro ????? - Part 4 This thread Refback 01-07-2010 10:58 AM
Motorcafè il blog dei motociclisti dalla mente aperta - Part 2 This thread Refback 01-07-2010 10:00 AM
Chuck Squatriglia | Autopia | Wired.com This thread Refback 01-06-2010 08:25 PM
Project: Geo Metro boat tail prototype - 15% MPG improvement @ 90 kph / 56 mph - Topic Powered by Social Strata This thread Refback 01-06-2010 07:00 PM
Design & Architecture Archives : TreeHugger This thread Refback 01-05-2010 12:58 AM
insidE of jaXonz This thread Refback 01-04-2010 11:02 PM
Buzz Punching: "Boat Tail" Increases Car's Miles Per Gallon by 15.1% This thread Refback 01-04-2010 10:47 PM
Guy Adds Boat Tail to Car, Increases MPG by 15.1% : TreeHugger This thread Refback 01-04-2010 03:28 PM
TreeHugger This thread Refback 01-04-2010 03:18 PM
Cars & Transportation Archives : TreeHugger This thread Refback 01-04-2010 02:16 PM
Items Tag RIT Make Club Idea Stream This thread Refback 01-04-2010 01:16 PM
Oszcz?dzaj paliwo z aerodynamicznym ogonem! (wideo) | Gad?etomania.pl This thread Refback 01-04-2010 12:14 PM
Teemu's planet This thread Refback 01-02-2010 10:15 AM
Bike Hugger This thread Refback 01-02-2010 08:55 AM
Daily DIY Network - Science Projects Plans Guides Blog Archive MPG boosting tail cone This thread Refback 01-02-2010 01:08 AM
Daily DIY Network - Science Projects Plans Guides This thread Refback 01-01-2010 08:22 PM
Make: Online This thread Refback 01-01-2010 08:11 PM
Autopia - Part 2 This thread Refback 01-01-2010 08:06 PM
siani_hedgehog's Friends This thread Refback 01-01-2010 06:09 PM
Make: Online : MPG boosting tail cone This thread Refback 01-01-2010 05:21 PM
Make: Online This thread Refback 01-01-2010 05:13 PM
A New Years Resolution - Bike Hugger This thread Refback 01-01-2010 12:17 PM
Firefly efficiency mods - MetroMPG.com This thread Refback 01-01-2010 02:42 AM
green hacks - Hack a Day This thread Refback 12-31-2009 04:02 PM
FFFFOUND! | flea-boat-tail-collage.jpg (JPEG Image, 500x363 pixels) This thread Refback 12-31-2009 10:56 AM
PWnT 2009 - (P)ost (W)hori(n)' (T)hread - Page 10598 - CarForums.net - Automotive Chat Forum This thread Refback 12-30-2009 08:08 PM
GeenStijl : Sneller, Scherper, Beter (maar eigenlijk komt hier een betere tagline) This thread Refback 12-30-2009 03:01 PM
Enterprising DIYer adds boat tail to Pontiac Firefly to boost mileage — Autoblog Green This thread Refback 12-29-2009 10:01 PM
Jalopnik - Attention, Greenies: Your Geo Metro Needs A Boattail This thread Refback 12-29-2009 09:46 PM
Interesting New Products and Inventions: Boat Tail improves Mileage This thread Refback 12-29-2009 08:25 PM
Autoblog Green — We Obsessively Cover The Green Scene This thread Refback 12-29-2009 08:09 PM
Attention, Greenies: Your Geo Metro Needs A Boattail - hypermiling - Jalopnik This thread Refback 12-29-2009 06:17 PM
Jalopnik: Obsessed With The Cult Of Cars This thread Refback 12-29-2009 06:16 PM
YouTube - EcoModderDOTcom's Channel This thread Refback 12-29-2009 05:19 PM
GeenStijl This thread Refback 12-29-2009 03:19 PM
GeenStijl : Tendentieus, ongefundeerd en nodeloos kwetsend This thread Refback 12-29-2009 12:41 PM
GeenStijl : Tendentieus, ongefundeerd en nodeloos kwetsend This thread Refback 12-29-2009 11:46 AM
GeenStijl : 15% zuiniger rijden met iedere auto! This thread Refback 12-29-2009 11:35 AM
GeenStijl This thread Refback 12-29-2009 11:16 AM
GeenStijl : 15% Zuinig rijden met iedere auto! This thread Refback 12-29-2009 11:16 AM
GeenStijl : Tendentieus, ongefundeerd en nodeloos kwetsend This thread Refback 12-29-2009 11:15 AM
La Cacharrería: un blog de tecnología diferente This thread Refback 12-29-2009 11:04 AM
Aerodynamic long tail improves fuel efficiency 15 percent This thread Refback 12-29-2009 04:24 AM
Autopia This thread Refback 12-29-2009 01:37 AM
Aerocivic - Honda Civic modifications for maximum gas mileage - aerocivic.com This thread Refback 12-28-2009 07:55 PM
DIY ‘Boat Tail’ Gives Little Car Big Fuel Economy | Autopia | Wired.com This thread Refback 12-28-2009 02:22 PM
Geo Metro boat tail prototype - 15% MPG improvement @ 90 kph / 56 mph - Madshrimps Forum Madness This thread Refback 12-28-2009 08:16 AM
R4 DS Cards, R4 DS and Wii Modchip News And Reviews This thread Refback 12-27-2009 04:21 PM
Mike Szczys - Hack a Day This thread Refback 12-26-2009 06:51 PM
transportation hacks - Hack a Day This thread Refback 12-26-2009 08:35 AM
mpg - Hack a Day This thread Refback 12-26-2009 08:05 AM
Friends This thread Refback 12-26-2009 07:57 AM
Hack: Aerodynamic tail makes Geo Metro even cooler -> ASTALAVISTA.com - the hacking & security community This thread Refback 12-26-2009 04:36 AM
the other end of the spectrum... This thread Refback 12-25-2009 11:44 PM
YouTube - Raw video for: "Testing aerodynamic boat tail +15% MPG" This thread Refback 12-25-2009 10:51 PM
YouTube - Testing an aerodynamic boat tail - 15% better MPG - Geo Metro This thread Refback 12-25-2009 07:07 PM
You put WHAT on your car? Stupid shit we've seen people put on their cars - The Something Awful Forums This thread Refback 12-25-2009 07:03 PM
Hack a Day This thread Refback 12-25-2009 05:24 PM
Geo Metro Mpg - Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback 12-24-2009 07:07 AM
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 152 10-27-2011 01:28 PM
How to get instant fuel consumption from Megasquirt TELVM Instrumentation 11 08-29-2011 03:47 PM
