Old 07-04-2013, 12:52 PM   #1 (permalink)
Camry - '99 Toyota Camry
90 day: 39.84 mpg (US)
Aero hubcaps or rims?
I've been researching hubcaps and rims. Moon discs? pizza pans? but I want to go with a lighter wheel(steel wheels as of now) but thinking hubcaps till I get new wheels and tires. I have a 99 Camry with these hubcaps
http://hubcapsonwheels.com/images/61...mry_hubcap.jpg
I've been looking at moon discs but they aren't completely flat right? I found these that may be a little better and slightly cheaper
http://grumps-garage.com/images/bhc01.jpg
73 with shipping
Ideas? Suggestions?
Old 07-04-2013, 01:32 PM   #2 (permalink)
The Dirty330 Modder
Gealii's Avatar
CruzeRS - '15 Chevy Cruze LT RS
90 day: 41.29 mpg (US)
73 with shipping
Ideas? Suggestions?
I have 3 ideas
Most to least expensive
1) buy new rims that are more aero and lighter
2) buy moon discs and yes they are not flat
3) make flat circles out of coroplast for smooth wheel covers, and beings you have steelies they fit inside of the lip around the outer edge of the wheel and can be easily install with zipties
"The only real mistake is the one from which we learn nothing."
- Henry Ford
The Following User Says Thank You to Gealii For This Useful Post:
sully06 (07-04-2013)
Old 07-04-2013, 03:52 PM   #3 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
4) cut a disc out of some material (coro, or whatever) and affix it to the existing hubcap.
PS: your OEM hubcaps look pretty good (they're not air blenders). I don't think you'll get a big enough savings from buying aftermarket discs to make up the cost in a reasonable amout of time (if that's your goal).
Old 07-04-2013, 03:57 PM   #4 (permalink)
Thanks yeah I may try and make something cheap
Old 07-04-2013, 07:51 PM   #5 (permalink)
mikeyjd's Avatar
Matchbox - '93 Ford Festiva L
Team Ford
Last 3: 70.16 mpg (US)
Salamander - '99 Chrysler Concorde LXI
Team Dodge
90 day: 30.3 mpg (US)
Urquhart - '97 Toyota Tacoma 4x4 V6 3.4L DLX
Pickups
90 day: 25.81 mpg (US)
Smudge - '98 Toyota Tacoma
90 day: 40.65 mpg (US)
Calebro - '15 Renault Trafic 1.25 dci
90 day: 39.39 mpg (US)
here's how I did mine. http://ecomodder.com/forum/showthrea...ers-25933.html
The Following User Says Thank You to mikeyjd For This Useful Post:
Old 07-04-2013, 08:41 PM   #6 (permalink)
Originally Posted by mikeyjd View Post
Thanks helps alot what did you use to measure and cut them?
Old 07-04-2013, 09:21 PM   #7 (permalink)
The Dirty330 Modder
Gealii's Avatar
when i did mine i matched some spare pizza pans up until i found 1 that fit inside the lip of the wheel then traced em to the coroplast then cut very slowly with a razor knife
- Henry Ford
Old 07-04-2013, 10:58 PM   #8 (permalink)
Alright I got the material today(old advertising signs from work) I think I can trace my current hubcap and cut just a hair inside of my trace line. I'm going to try putting them on without taking the wheels off tho. Gonna use zip ties like you did and go around the holes in the steelies.
Old 07-05-2013, 12:05 PM   #9 (permalink)
mikeyjd's Avatar
Team Ford
Team Dodge
Pickups
same
Old 07-05-2013, 12:14 PM   #10 (permalink)
The Dirty330 Modder
Gealii's Avatar
i tried doing the hubcap tracing and it turned out not very circular and not the rite size as the hubcap overlaps the lip of the wheel and at least on my caps they angle at the end so neither the outside or inside of the cape was the correct size
- Henry Ford
