Old 07-09-2011, 08:05 AM   #11 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 214.18 mpg (US)
Send a message via MSN to jakobnev
An alternative (no pun intended) is to carry a battery with slightly higher nominal voltage than the car:
I'm getting a 5A boost at the beginning of a trip and then it goes down towards 2A in an hour.
Old 07-09-2011, 10:49 PM   #12 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
Originally Posted by Arragonis View Post
The "Blue" (named after the VW/Merc "Blue" eco technology - well they don't want to give the Green Party any credit do they ?) failed for me because it's too expensive for what it is.
At least you have more than 2 distinctly different parties :/
___
I really want to try this mod on Teggy -- I have a switch for the transmission/TC, why not for the alternator as well?
My biggest concern is the extended time the vehicle remains parked up to a week or 2 outdoors -- is there a minimum recommended voltage on a stock batt? I'm sure after time, it can really wear on an average battery -- any thoughts there???
-RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
Old 07-10-2011, 04:56 AM   #13 (permalink)
The PRC.
We have at least 4 large ones in Scotland - be careful what you wish for, the choice and variety is no better...
Old 07-10-2011, 09:10 AM   #14 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by sixpackdan View Post
What about one of those "flexable" solar panels on the roof to keep the battery charged?
I have been "planning" on this idea for a while. My 98 Civic has a roof large enough for a 120w panel that would generate 18v at peak (I'm still learning). I want to install an alternator kill switch and LED lights as well. I think I could run the car possibly all day with the alternator off, and then turn it on as the sun weakens. One thing would be great... my extended EOC usage would not kill my battery because the panel would still be recharging even though the engine was off.
@rgathright: those batteries are heavier than stock, no? I was hoping for a lighter deep cycle battery to contribute to my weight-reduction program too.
Old 07-11-2011, 12:00 PM   #15 (permalink)
Question What % of total engine load is alternator?
rgathright,
What percentage increase in mileage do you get with the alternator off?
Do you re-engage the alternator when braking or coasting down a hill?
Did you replace your starter battery with a deep cycle battery which is built to not expect immediate recharge?
If you replaced you battery, how has it effected your cold weather starting?
CatbusMike
Old 07-11-2011, 03:08 PM   #16 (permalink)
...beats walking...
...connecting the brakelights to electronically "re-engage" the alternator field would cause charging only when decelerating.
...simply replace the "hot" (+12VDC) line going to the regulator device/module with a wire connected to the brakelights = field engergized only during breaking.
Old 07-11-2011, 03:39 PM   #17 (permalink)
My idea for an alternator modification is to replace the shaft pulley with an Air Con-type clutch/pulley. With a circuit sensing batter voltage, while the voltage is adequate, the clutch would allow the pulley on the alternator to spin freely. When the voltage reaches a pre-determined low, the clutch would kick in, turn the alternator and recharge the battery. You'd only spin the alternator when you needed to on long trips, and could top the battery at home via a trickle charger between trips.
Old 07-11-2011, 03:42 PM   #18 (permalink)
This could work on stop-start urban trips, but would be problematic on long journeys with little stopping.
Old 07-11-2011, 06:31 PM   #19 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
another paper
Automotive Power Generation and Control
The Following User Says Thank You to ConnClark For This Useful Post:
t vago (07-13-2011)
Old 07-11-2011, 07:53 PM   #20 (permalink)
MPG Militia HMV-25E80+A
JethroBodine's Avatar
FrankenJetta D - '90 Volkswagen Jetta GL
Diesel
90 day: 64.35 mpg (US)
The alternator on my car will continue to charge, once the field is energized, until the engine stops and power is removed from the field. As I don't know if this is damageing in some way, I leave the switch on until my next EO(ff)C. I monitor my battery voltage and tend to leave the alternator on when in stop and go traffic. If on a longish trip, I engage the alternator when my battery voltage gets to 12.0vdc at rest( seems to stay around 12.2 for quite a while). I do charge my battery at night, except when thunder showers are going on). I also turn the alternator on (and injectors off) when engine braking.
It is always very amusing how our imagination is put to the test when overcoming reality. Redyaris
Boat tail project
How to gently bump start during EOC
