Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 06-12-2009, 05:11 AM   #51 (permalink)
Alty-magnet - '06 Nissan Altima SE
90 day: 33.83 mpg (US)
maxi-magnet II - '12 Nissan Maxima S
Frank Lee, good post, I think there's free cake and ice cream tomorrow!
Old 06-12-2009, 10:25 AM   #52 (permalink)
Originally Posted by hondo434 View Post
Mr C, in your opinion what would cause a car to increase milage to 8 mpg over epa estimates for the car without changing anything?
A generous application of snake oil :-)
Old 06-12-2009, 10:43 AM   #53 (permalink)
MR C., Mctimson has graciously offered to help with verfication of results. He will test on his vehicle and I will remove magnet and drive to endicott this sat. for a mini test to see if milage drops.
Old 06-12-2009, 12:13 PM   #54 (permalink)
Objectivel prove using OBD-II data logger
Doax, Thank you for your reply. I have stated I would remove the magnet to see if there is a difference in milage. I am just as interested in making sure that the magnet is the source. If you have any tests you want me to do I would be glad to try. As the magnet is a small investment it is not worth doing expensive outsourced tests to prove a point.
Hondo434, an objective way to prove gains is to log your OBD-II data without the magnet and then log OBD-II data with the magnet. You can use CarChip to log your data. Carchip has software to export these data. Once exported the data can be further analyzed and compared "OBD-II Data Easy Viewer". Google this text "greenfuelbooster OBD-II data easy viewer". I wrote the program and made it free for download. It will show exactly the difference.
Old 06-12-2009, 02:05 PM   #55 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
What would cause your car to have 8 MPG better than EPA estimates... without changing anything... Hm. Don't drive like the EPA expects you to.
Regardless of any side argument you can come up with, I'm sure no one at this point is even paying attention except enough to see if you actually come up with a valid set of test data to prove your claims.
If you can't at least do that, then to you I say, "Good Day."
Old 06-12-2009, 03:25 PM   #56 (permalink)
Ha Ha, testing magnets.
It's a waste of fuel, but at least it keeps em busy.
Old 06-12-2009, 04:59 PM   #57 (permalink)
Mctimson, If you get online today email me at hondo434@cs.com
Old 06-12-2009, 06:57 PM   #58 (permalink)
Greenfuelbooster, Thankyou for you post, I'm thinking I would have to buy some equipment to use that software? I do have a question for you. I can get a ob II unit at autozone. They lend it out as courtesy. I don't remember the model, Could something like that get the info and be able to download to computer?
Old 06-12-2009, 08:56 PM   #59 (permalink)
Vibe - '07 Pontiac Vibe
90 day: 47.11 mpg (US)
Informative piece on magnets in general How do magnets work?
Might as well learn something.
Old 06-12-2009, 11:31 PM   #60 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Toyota Echo 4D Auto
90 day: 34.45 mpg (US)
New Galaxy - '07 Toyota Prius
90 day: 42.15 mpg (US)
What if you took those magnets and glued them over the stop light sensors
Might save gas when you hit all those green lights
Past Present Future?
Magnetic engine returns BillWhedon The Unicorn Corral 22 03-13-2013 03:09 AM
Uk ford transit, economy increase? chipX EcoModding Central 14 10-11-2012 02:38 AM
Magnets (as attachment method) jmonroe Aerodynamics 10 03-07-2009 01:12 AM
New Report of 20% milage increase by reducing viscosity of fuel htaylor EcoModding Central 29 01-27-2009 12:35 AM
magnets use for permanent mods ? groar EcoModding Central 5 09-08-2008 03:52 PM
