Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 03-12-2012, 01:20 PM   #221 (permalink)
I have worked with magnetic fields for racing slot cars and as a lab tech for a research scientist. Magnetic field strength decreases by the inverse square law. Molecules are aligned in a magnetic field and then return to other positions outside the field. One would expect any magnetic particles to collect at the magnet site. Fuel molecules are are collections of short and long chain hydrocarbons so polarizing them should have little affect on how the oxygen reacts. We are testing to find if a cause/effect mechanism exists. What are the differences in the fuel before it is in the field versus after it. Is anything removed by the magnets? Is the chemistry of the fuel altered permanently? Do the magnets affect the performance of vehicle is some other way by altering electical signals? This the difference between experiment design and guess work.
Old 03-28-2012, 11:14 PM   #222 (permalink)
I have tested a couple of different magnet devices on my 1994 Ford Aspire and did test runs with them keeping control over as many variables as I could and time after time I saw absolutely nothing for results.
Old 03-29-2012, 04:21 AM   #223 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Because magnets, and many other things in the Unicorn Corral, are like dis/proving the existence of God (or any other Deity) - just because you looked and didn't see doesn't it's not there. The effect of magnets on FE is not something that can be easily measured, it goes much deeper. Metaphysical. Mystical. Transcendental.
(Fade away to weird music in the background)
Old 03-29-2012, 04:31 AM   #224 (permalink)
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
What sort of music are we talkin? The final outcome of this thread hinges on your music selection.
Old 03-29-2012, 04:41 AM   #225 (permalink)
aero guerrilla
Piwoslaw's Avatar
Whatever the music, it's definitely being played from a magnetic tape, not a CD.
Old 03-29-2012, 04:48 AM   #226 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 587.16 mpg (US)
Send a message via MSN to jakobnev
I've heard that some types of music can be improved by holding a strong magnet close to the tape.
The Following 2 Users Say Thank You to jakobnev For This Useful Post:
orangustang (04-23-2012), Piwoslaw (03-29-2012)
Old 03-29-2012, 12:21 PM   #227 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
This music!!!
The Following User Says Thank You to t vago For This Useful Post:
Cd (06-05-2012)
Old 06-05-2012, 08:50 AM   #228 (permalink)
Alty-magnet - '06 Nissan Altima SE
90 day: 33.83 mpg (US)
maxi-magnet II - '12 Nissan Maxima S
Grant-53, I am the owner of this thread. I am interested in how you are testing the magnets effects.
I have stated that I don't advocate that magnets change gas, I say that I installed magnets and my milage increased substantially. I would be interested in experimenting with you with the magnets and testing the effects on the vehicle. I'm only 50 miles away, so It may be feasible to coordinate some kind of collaboration. Hondo434
Old 06-05-2012, 11:31 AM   #229 (permalink)
Drive less save more
ecomodded's Avatar
90 day: 60.42 mpg (US)
A magnet enhanced car should not need gasoline at all. A simple plug in to recharge the electric cars battery pack is all that is needed. Electric motors, the real magnet mpg saver.
Save gas
Old 06-05-2012, 02:42 PM   #230 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
Starting from a conclusion and working backwards towards a theory is slightly problematic. Perhaps you can review your test results and rule out your independent variables before jumping to such conclusions.
I'm not coasting, I'm shifting slowly.
Magnetic engine returns BillWhedon The Unicorn Corral 22 03-13-2013 03:09 AM
Uk ford transit, economy increase? chipX EcoModding Central 14 10-11-2012 02:38 AM
Magnets (as attachment method) jmonroe Aerodynamics 10 03-07-2009 01:12 AM
New Report of 20% milage increase by reducing viscosity of fuel htaylor EcoModding Central 29 01-27-2009 12:35 AM
magnets use for permanent mods ? groar EcoModding Central 5 09-08-2008 03:52 PM
