Originally Posted by svt98t
Crazy Jerry,
I'd like to meet you folks as well! I have a navigator for this event already. We're primed and ready to go!!
-ryan s.
Will you be running the tank in the
Exhibition: class
You. Have a "race only" rig NOT STREET LEGAL as per the EPA /CAEB:
1. No cat in down pipe as per your garage profile NOT CARB approved as wouldNOT pass visual smog inspection.if it cant pass that it is for off-road (race) use only
2. HAI/CAI is it off the shelf CARB # xxxx or as mying will be home made custom as "I" want it. If no sticker Exhibition class required because not street leagal. Can it pass an enhanced smog test(underload on a dino) with the hot air intake active or are the NOXX too high from an over heated communication temp too far above 2500°f
This is mostly for clarification of what they mean by "STREET LEGAL". Street leagal safty ,and or macanical, and or EPA
Hearis a better example Diesel_Dave
White Whale: 2007 Dodge Ram 2500 ST Quad Cab 2wd, short bed
Modds:
Removed diesel particulate filter (DPF)
Removed diesel oxidation catalyst (DOC)
Removed NOx adsorber
Removed EGR system
Removed intake throttle plate
Re-routed CCV vent to atmosphere
Smarty Jr tuner: fuel economy tune, most advanced timing
Ect ect
Would this 2000+ on 35usg be in the stock 6cylinder class or Exhibition not "STREET LEGAL" most of theas modds cary a $10,000 fine each from the EPA/CARB. For use "on road"
Theas Questions is for all ecomodders ,me inclided
If someone frome the GGP could pipe in that would be kool as well
I'm not trying to single out any one modder.
Thanks in advance
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg :
31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
