Old 08-22-2013, 11:11 AM   #21 (permalink)
The PRC.
please read first post.
Old 08-22-2013, 11:18 AM   #22 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Originally Posted by LeanBurn View Post
Simply look up if the car can be flat towed. If it can or can't you have your answer.
wow.......really!
Can you read?
do you read?
1. your answer reflects a complete lack of understanding or comprehension.
2. Flat towing REALLY has NOTHING to do with the issue.
The question has to do with DAY TO DAY use of the car....not a short tow one time in a cars life!
I am constantly amazed at what posters will post without even thinking.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 08-22-2013, 11:20 AM   #23 (permalink)
Got MPG?
The Car - '09 Toyota Corolla CE Enhanced
Wow dude, calm down.
I was actually referring to the first post. I simply wouldn't do otherwise to compromise the mechanics of the car. There is a reason they stipulated 50km/hr, I would follow it. People flat tow cars all the time, they are behind diesel pushers and other RV's regularly. Every auto I have ever owned has fluid pumping only when the engine is on.
2013 Honda Civic Si - 2.4L
OEM front to back belly pan from the factory.
Old 08-22-2013, 01:27 PM   #24 (permalink)
The PRC.
Calm down all please. And yeah, I'm one to talk getting annoyed at people with DSG advice
@Lean - I think the instructions in the manual assume the engine is off when the car is towed and states specifically that the limits on speed and distance and due to no lubrication of the gearbox.
My question is if I leave the engine on can I shift to N and coast as much as I like.
Or basically if the engine is on, is the gearbox lubricated ?
Thanks though.
EDIT - also remember this is a Quattro so towing with an axle off the ground makes no difference, it would have to be on a trailer.
Old 08-22-2013, 01:51 PM   #25 (permalink)
EcoPlotting
night9's Avatar
Sliver - '12 Hyundai Elantra limited
90 day: 35.1 mpg (US)
t-ruck - '06 chevy Colorado Lt
90 day: 21.88 mpg (US)
Bob - '09 Harley Sportster Nightster
90 day: 38.88 mpg (US)
Pearl - '14 Toyota Prius C 3
90 day: 48.1 mpg (US)
x guage
I realize this info may not be useful because our cars are very different. I have an x gauge programmed for transmission temp, thanks to one of the programmers of the scan gauge. What I noticed was that the temp of the transmission, would decrease a little from neutral coasting. I would take this a positive sign of decreased friction and therefore decreased heat.
I have almost 30,000 miles on my Elantra with a lot of neutral coasting! No problems to report. I will know more when I go to have the transmission serviced at 60,000 miles. That the recommended service interval for heavy duty use.
The Following User Says Thank You to night9 For This Useful Post:
user removed (08-22-2013)
Old 08-22-2013, 02:12 PM   #26 (permalink)
Got MPG?
Audis have one of the best Awd systems out there. I would consult an Audi forum before listening to anything said on here, unless they are an Audi guru.
Old 08-22-2013, 04:13 PM   #27 (permalink)
mcrews's Avatar
ok Im calm.......
You have AGAIN posted about
ENGINE OFF TOWING
SO let's recap.
1. you don't read the thread "ENGINE ON" !!@!!!!!!
2. you post a completely irrelevant post.
3. you get called out........
and then.......
4. you post AGAIN about engine off towing......
am I missing anything??????
ECO MODS PERFORMED:
First: ScangaugeII
Old 08-22-2013, 04:18 PM   #28 (permalink)
mcrews's Avatar
I had to run a separate gauge for my tranny temp because I couldn't crack the code on the scangauge....
ECO MODS PERFORMED:
First: ScangaugeII
Old 08-22-2013, 04:27 PM   #29 (permalink)
Got MPG?
Cool
Yeah, your blood pressure meds...its the internet man, not life and death...go take a nap.
Old 08-22-2013, 04:52 PM   #30 (permalink)
The PRC.
Originally Posted by Arragonis View Post
...Or basically if the engine is on, is the gearbox lubricated ?...
*Cough
