Old 10-26-2015, 04:28 PM   #701 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Wink
It's here!
I had to reassemble it so I could roll it out of the street and into the driveway...which was a better choice than trying to drag it.
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following 2 Users Say Thank You to BamZipPow For This Useful Post:
aerohead (10-26-2015), deejaaa (10-26-2015)
Old 10-26-2015, 06:11 PM   #702 (permalink)
it's here
Looks like an oil well to me!
BamZipPow (10-26-2015)
Old 10-26-2015, 06:52 PM   #703 (permalink)
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
So here is the history of that trailer. Bruce purchased the components and put it together in 1996, to tow behind his motorhome. He made one round trip of approximately 200 miles with it. Then he had an injury of unknown cause, and suffered a broken back.
He never drove that motorhome again, or towed the trailer. It sat, and one day a common thief stole the tire off it, and many other things from his shop.
Bruce is able to walk OK but is quite limited. he was in good enough shape to hold the guy at gunpoint when he came strolling back nonchalantly with wheel in hand. he had taken it to air it up so he could steal the trailer and whatever else he could load in it!
So that's it, one trip and parked for nearly two decades.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
The Following 2 Users Say Thank You to skyking For This Useful Post:
aerohead (10-27-2015), BamZipPow (10-26-2015)
Old 10-27-2015, 08:01 PM   #704 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
Trying out a placement fer the rear camera...
The Following User Says Thank You to BamZipPow For This Useful Post:
aerohead (10-28-2015)
Old 10-27-2015, 08:44 PM   #705 (permalink)
That hat again.
What happens to the field of view if it's on the cab in the wind-shadow of the 3rd brake light? There's already wires up there.
BamZipPow (10-28-2015)
Old 10-27-2015, 10:12 PM   #706 (permalink)
Not banned yet
deejaaa's Avatar
Blue - '03 Chevy S-10, LS
That hat again.
looks like it's covered up.
this will make your stress level go way down while driving.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
The Following User Says Thank You to deejaaa For This Useful Post:
Old 10-28-2015, 10:43 AM   #707 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
Fer this backup camera, it had a very poor low light performance along with a terrible glare issue when used a wide-field camera.
I ended up putting it under the hatch so it would perform best in the environment that it was designed fer.
Hatch closed...
Hatch opened...
I will have to look into a bigger camera that will have better performance fer a wide-field rear camera. Fer now, this camera will just fine to see directly behind the tailgate.
Old 11-13-2015, 03:31 PM   #708 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Had some time to work on the next belly pan since the weather was so nice.
Built up the support structure similar to the previous one. I think I figured out how to install the wheel belly pan since the air bag support is extended out. It will be based on the bolts that hold the air bag in place and will use spacers to build in an upper support rail to secure the wheel belly pan in place. The rail will not move up in down with the wheel fork but the rail will allow the wheel fork to move without interfering with the fork's movement.
I was able to use an aluminum window frame as my crossbeam to attach my support rails fer the main belly pan.
Piccies to follow...
aerohead (11-14-2015), deejaaa (11-13-2015)
Old 11-13-2015, 11:12 PM   #709 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
A quick piccie of the updated belly pan...
Old 11-15-2015, 12:52 AM   #710 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
Here's a quick fab of the front support system...
The front spacer bar will be removed as I'm only using it to git the correct height fer the support rails. The belly pan will git installed under the support rails.
