10-09-2015, 01:05 PM
#682 (permalink)
T-100 Road Warrior
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following 3 Users Say Thank You to BamZipPow For This Useful Post:
10-16-2015, 11:28 AM
#683 (permalink)
T-100 Road Warrior
I've pulled the latest belly pan and wheel pant assembly off of Dark Aero. Looking at the belly pan where I painted it white, there wasn't any indication of any streaks in the recessed areas from the dirt flow modeling during the last run in the rain. I guess this tells me no turbulent air was gitting up into the recessed area.
The wheel pant assembly was taking a pretty good beating from the road vibrations. All of my steel pop rivets were loose, some had fallen out. Two screws had snapped off while two more had backed out some. I will have to rethink this setup if I go back in this direction. I will eventually have something that will have the "1WD" on each side of the wheel assembly again.
After taking the wheel pant off, the wheel had a good covering of fine powdered dust similar to brake dust on the outer part of the rim which I guess it sucked up from the road and the rotating force of the wheel deposited it on the rim...rather interesting. No grease marks which tells me that my felt liners are doing their job of keeping the grease in the hub. I did have to add a few pumps of grease into the hub.
I'm going back to a belly pan similar to my original setup and see what I can improve. I guess I'm down to scraps of Coroplast now...
The Following User Says Thank You to BamZipPow For This Useful Post:
10-16-2015, 04:50 PM
#684 (permalink)
...and the election is still over a year away.
So some stuff works and some stuff doesn't. Who'd have guessed.
What happened to that trailer for sale?
10-16-2015, 06:38 PM
#685 (permalink)
T-100 Road Warrior
It's being stripped down to the frame and being prepped fer shipping to Texas.
Git ready fer Dark Aero II...
The Following 2 Users Say Thank You to BamZipPow For This Useful Post:
10-16-2015, 08:23 PM
#686 (permalink)
Are you going to go with the hitch mount again, or just weld two tabs on the back bumper?
10-16-2015, 08:36 PM
#687 (permalink)
T-100 Road Warrior
Staying with the hitch setup. The hitch will git upgraded to the same level as I have with Dark Aero now. If tabs were welded to the bumper, I would lose the ability to lower the tailgate with the trailer hooked up. To load or unload anything from the bed would require me to unhook the trailer everytime.
10-17-2015, 08:51 PM
#688 (permalink)
Driving home today, I had this nagging feeling. I checked the side mirrors. Nothing.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
The Following 2 Users Say Thank You to skyking For This Useful Post:
10-17-2015, 09:06 PM
#689 (permalink)
It was still there, this creepy feeling. Like something was shadowing me....
I checked the inside mirror, you know, the one truckers NEVER use, and there it was!
This ghostly grayish white thing barely peering up over my tailgate!
WTFBBQ! OVer!
2003 TDI Beetle
2002 TDI Beetle
10-17-2015, 09:07 PM
#690 (permalink)
Ultimate Fail
Skyking, what are we looking at in the pics ?
As large as those mirrors are, I'm surprised they don't have mini wipers.
The Following 2 Users Say Thank You to Cd For This Useful Post:
