05-29-2013, 10:55 PM
#11 (permalink)
You don't see real Moon disks Mickey-Moused onto the lug nuts. Drill the lip of the rim for sheet metal screws. There's ~1/2" of rubber behind the rim before you'd nick the cable in the tire's bead. Off-roaders call it a bead-lock.
It's swap meet season, why not real Moons?
05-29-2013, 11:06 PM
#12 (permalink)
The clip-ons would not fit, which is why I mailed back the ones that I had bought. Everybody seems to lose those anyway. I would need to find the screw ones.
05-30-2013, 01:53 AM
#13 (permalink)
I got a set of 4 at a swap a few years back for $5. But they have big notches where the three holes used to be.
05-30-2013, 05:42 AM
#14 (permalink)
How about I tap the discs into the rims?
Does that ever go poorly? If the discs were notched, what would have happened to the rims?
05-30-2013, 09:58 AM
#16 (permalink)
had a set 1x
I am also going your route Im guessing you have 14" wheels also so the 15 " pan after drilling hole for the valve will fill the rim inside.
I had a purchased set with clips one time before and clips broke over time and would not seat on old American racing wheels so I removed wheels from truck drilled through safe portion then transferred holes into hubs.
Next I tapped wheel holes to 6-32 and picked up circuit board stand off from radio shack. screwed into wheels and used nylock nuts on hub caps.
the wheel covers squeek slightly at low speeds to resolve that I used some silicon and squeezed a dab here and there before bolting covers on.
this combo served me well for another 3 years of service.
rust coated them so I painted them red to match the truck and sold vehicle for a ten year moonie service life.
standoffs were really cheap and come in different sizes and can also be screwed together to effect length and mounting issues.
FYI. not all standoffs are male or female or 1/2" or 3/4" etc. look into it before ya start, and dont run drill into aired sections of your wheel..
The Following User Says Thank You to justme1969 For This Useful Post:
05-30-2013, 12:06 PM
#17 (permalink)
I never saw the rims, it looks like the disks were removed and reattached repeatedly (?) All three holes were worn out the same amount. Standard attachement is three sheet metal screws maybe 3/8" long.
A hose clamp 50" long? You can chain them together, but i can't see gripping the edge of the disk and rim working and the air would be seeing a step the width of the hose clamp.
Here's a picture that's on topic.
Oversized disks, stand-offs, valve stem hole.
05-30-2013, 08:17 PM
#18 (permalink)
Is there a reason that moon discs are convex? Wouldn't you want the rim\cover to extend as far as the sidewall, but not any further?
My trays arrived today. It turns out that my fifteen-inch wheels have sixteen-inch rims and these are about an inch and a quarter small. I think that I will go to that restaurant supply store and see if they have sixteen-inch discs. I just paid $11.50 to mail back the hubcaps. If I pay the same amount to return these trays, I would only get half of my money back.
What else can I do with these things?
05-31-2013, 01:13 AM
#19 (permalink)
The tire has 15" holes and the rim has (apparently) a 5/8" lip.
Moon disk are convex for strength, spindle clearance (sometimes you'll see them with a hole or bullet in the middle) but mostly so they *catch the light* better.
Overhanging the lip? Everyone opines that the disk would wear on the tire sidewall and simply destroy it. I think the tire and the disk are moving together and it would be more of a press and release, at the bottom where the sidewall deforms. The guys that run the Mariani Farms roadster know the facts.
When I try to process that I have a halting problem.
05-31-2013, 01:28 AM
#20 (permalink)
I wonder if everybody but me knew that hubcaps were an inch and a quarter bigger than the rims. Moon disks are mostly convex to catch the light better? I was not sure if the hole or bullet was to catch the light better.
Is a round shape better than a flat one if it has a larger frontal area? I continue to think that you would want the sides to be flat, although if you are going to have the caps bigger than the rims, it does not make sense to me to have them smaller than the middle of the sidewall, so that you have one curve, as in the picture that you shared. I would think that if the edge of the moon disk is level with the widest part of the sidewall, when it flattens against the ground, it would push against the disk, which would flex away, to whatever extent is possible, but if the disk reaches the inner portion of the sidewall, towards the center, the rubber would also push against the edge of the disk, which could cause more wear, but I do not know anything.
I was asking if anyone had any idea what to do with aluminum discs, these trays that I bought. If I return them I would only receive eleven or twelve dollars if shipping charges are the same as they were for my hubcaps.
If moon disks are convex for strength, but they creak because they flex, are they too convex or not enough?
Would they creak if they were attached to the lugnuts, like mine? I know that exposing the holes would make them less aerodynamic, but I imagine that can be fixed.
